I am trying to use SASSI.
My set-up has cuda 7.0. When I try to run the matrixMul.cu available in SASSI git repo, I get following error:
/path/to/sassi/bin/nvcc -o matrixMul matrixMul.o -gencode arch=compute_20,code=sm_20 -Xlinker "--wrap=main" -Xlinker "--wrap=exit" -L../instlibs/lib -lbranch -L/path/to/sassi/extras/CUPTI/lib64 -lcupti -lcudadevrt -Xlinker -rpath,/path/to/sassi/extras/CUPTI/lib64 -L/usr/include/boost/lib -lboost_regex -lcrypto -Xlinker -rpath,/usr/include/boost/lib
nvlink fatal : Internal error: duplicate relocations at same address
make: *** [matrixMul] Error 1
I am not able to figure out what the error is. Can anyone provide some solution? Thank you.
from the sassi page:
https://github.com/NVlabs/SASSI
“Programs currently have to be compiled with -rdc=true, which affects performance.”
Note that even apart from SASSI, this is always true when you require the following link specification:
-lcudadevrt
Still same error:
make
make: Warning: File `Makefile' has modification time 2.8 s in the future
/path/to/sassi/bin/nvcc -I./inc -c -gencode arch=compute_20,code=sm_20 -Xlinker "--wrap=main" -Xlinker "--wrap=exit" -lineinfo -Xptxas --sassi-inst-before="cond-branches" -Xptxas --sassi-before-args="cond-branch-info" -g -O3 -rdc=true -o matrixMul.o matrixMul.cu
* SASSI Instrumentation Details
* For the settings you passed in, you'll need to make sure that you have
* an instrumentation library with the following properties:
* - It MUST BE compiled using only 16 registers!! To accomplish this
* simply compile your library with the nvcc flag, --maxrregcount=16
* - It must define the following functions:
* __device__ void sassi_before_handler(SASSIBeforeParams*,SASSICondBranchParams*)
