NVLINK GPU Metrics Breakdown
NVLINK has separate links for transmit (nvltx) and receive (nvlrx).
NVLINK metrics distinguish between request and response, so a developer can determine if traffic is initiated by the observed GPU or from a remote GPU.
NVLINK transfers data in 16 byte flits. The counters are converted from flits to bytes by the metrics library multiplying by 16 bytes/flit. NVLINK can collapse protocol and data into a single packet. I believe in this case it will show as user data, not as protocol (but I could be wrong and I don’t have a setup to test at the moment).
In the table below 1 means 1 flit so final metric (__bytes) is multiplied by 16.
EXAMPLE 1 : GPU0 WRITES TO GPU1
-- gpu0 sends write command and data
1   gpu0.nvltx__bytes_packet_request_data_protocol      0 or >0 depending on complexity of write
2   gpu0.nvltx__bytes_packet_request_data_user          >= 1 depending on the size of the transfer
-- gpu1 receives write command and data
3   gpu1.nvlrx__bytes_packet_request_data_protocol      0 or >0 depending on complexity of write -- matching 1
4   gpu1.nvlrx__bytes_packet_request_data_user          >= 1 depending on the size of the transfer -- matching 2
-- gpu1 sends write acknowledge -- these can be coalesced if there is no error
5   gpu1.nvltx__bytes_packet_respone_data_protocol      1
-- gpu0 receives write acknowledge
6   gpu0.nvlrx__bytes_packet_response_data_protocol     1
EXAMPLE 2 : GPU0 READS FROM GPU1
- gpu0 sends read command
1   gpu0.nvltx__bytes_packet_request_data_protocol      >= 1 including address and length
- gpu1 receives read command
2   gpu1.nvlrx__bytes_packet_request_data_protocol      >=1 - matching 1
- gpu1 sends read response
3   gpu1.nvltx__bytes_paket_response_data_protocol      >= 0 - may be collapsed into data response
4   gpu1.nvltx__bytes_paket_response_data_user          >= 1, based upon size of requested data
-- gpu0 receives read data from gpu1
5   gpu1.nvlrx__bytes_paket_response_data_protocol      >= 0 - may be collapsed into data response
6   gpu1.nvlrx__bytes_paket_response_data_user          >= 1, based upon size of requested data
  1. Can you explain precisely what Responses[User Data|Protocol Data] and R> equests[User Data|Protocol Data] mean, specifically the reason for the inconsistency among the above metrics?
Inconsistency can exist as (a) the sample period is misaligned, or (b) the clock rate at the perfmon is slightly different rate.
  1. Definitively, which of the two indicates bandwidth and protocol overhead?
    For a GPU
  • bytes received = nvlrx__bytes
    • in UI sum NVLINK RX* % to get % of theoretical receive bytes - these will not exceed 100%
  • bytes transmitted = nvtx__bytes
The current NSYS UI only shows you as % of the maximum throughput during the sample period. If you know the theoretical maximum from the white paper you can convert to throughput (bytes/sec).
There are additional public metrics for a custom configuration file that could output in terms of bytes or bytes/second.
nvl{rx,tx}__bytes.sum - bytes in sample period
nvl{rx,tx}__bytes.sum.per_second – throughput in bytes/second
nvl{rx,tx}_bytes_data{user, protocol}.sum.per_second – throughput in bytes/second broken down by user and protocol
