我是jetpack5.1.2的版本,在使用中出现了这个dump,这可能是哪方面原因,该如何避免,是否是RT补丁的问题?
我们使用了nvjpeg用于编解码
[56609.469120] uvcvideo: Failed to set UVC probe control : -32 (exp. 48).
[56609.745957] uvcvideo: Failed to set UVC probe control : -32 (exp. 48).
[57311.980927] tegra-xusb 3610000.xhci: ERROR unknown event type 37
[58113.742278] zme_birdvision_: page allocation failure: order:7, mode:0x40dc0(GFP_KERNEL|__GFP_COMP|__GFP_ZERO), nodemask=(null),cpuset=/,mems_allowed=0
[60380.712747] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000068
[60380.712758] Mem abort info:
[60380.712759] ESR = 0x96000005
[60380.712760] EC = 0x25: DABT (current EL), IL = 32 bits
[60380.712762] SET = 0, FnV = 0
[60380.712763] EA = 0, S1PTW = 0
[60380.712763] Data abort info:
[60380.712764] ISV = 0, ISS = 0x00000005
[60380.712765] CM = 0, WnR = 0
[60380.712766] user pgtable: 4k pages, 48-bit VAs, pgdp=000000025e314000
[60380.712768] [0000000000000068] pgd=00000003b3391003, p4d=00000003b3391003, pud=0000000000000000
[60380.712773] Internal error: Oops: 96000005 [#1] PREEMPT_RT SMP
[60380.712777] Modules linked in: nf_conntrack_netlink nfnetlink br_netfilter lzo_rle lzo_compress zram overlay ramoops reed_solomon loop bnep hid_sensor_gyro_3d hid_sensor_accel_3d hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_custom hid_sensor_iio_common snd_soc_tegra210_ope snd_soc_tegra186_dspk snd_soc_tegra186_asrc snd_soc_tegra186_arad snd_soc_tegra210_iqc snd_soc_tegra210_mvc snd_soc_tegra210_afc snd_soc_tegra210_dmic snd_soc_tegra210_adx ch341 usbserial hid_sensor_hub snd_soc_tegra210_amx rtk_btusb btusb btrtl btbcm snd_soc_tegra210_i2s btintel snd_soc_tegra210_mixer snd_soc_tegra210_admaif snd_soc_tegra210_sfc snd_soc_tegra_pcm aes_ce_blk crypto_simd cryptd aes_ce_cipher ghash_ce sha2_ce sha256_arm64 sha1_ce snd_soc_spdif_tx snd_soc_tegra_machine_driver ip6table_filter fusb301 ip6_tables xt_state snd_soc_tegra210_adsp xt_conntrack iptable_filter snd_soc_tegra_utils tegra_bpmp_thermal snd_soc_simple_card_utils nv_imx219 xt_MASQUERADE userspace_alert nvadsp
[60380.712838] xt_addrtype snd_hda_codec_hdmi iptable_nat snd_soc_tegra210_ahub tegra210_adma nf_nat snd_hda_tegra snd_hda_codec nf_conntrack rtl8822ce snd_hda_core nf_defrag_ipv6 nf_defrag_ipv4 cfg80211 libcrc32c r8168 spi_tegra114 nvidia(OE) binfmt_misc uvcvideo videobuf2_vmalloc ina3221 pwm_fan nvgpu nvmap ip_tables x_tables [last unloaded: mtd]
[60380.712863] CPU: 0 PID: 147821 Comm: right_loop Tainted: G OE 5.10.120-rt70-tegra #11
[60380.712866] Hardware name: Unknown NVIDIA Orin NX Developer Kit start dev0220/NVIDIA Orin NX Developer Kit start dev0220, BIOS 4.1-33958178 08/01/2023
[60380.712869] pstate: 20400009 (nzCv daif +PAN -UAO -TCO BTYPE=--)
[60380.712871] pc : nvmap_free_handle_from_fd+0xd0/0x260 [nvmap]
[60380.712891] lr : nvmap_free_handle_from_fd+0x80/0x260 [nvmap]
[60380.712900] sp : ffff80002717bd60
[60380.712900] x29: ffff80002717bd60 x28: ffff081a8026bb00
[60380.712902] x27: 0000000000000000 x26: 0000000000000000
[60380.712904] x25: 0000000000000000 x24: 0000000000000000
[60380.712906] x23: 0000000000000000 x22: 0000000000000000
[60380.712908] x21: 00000000800000e1 x20: ffff08190df9c100
[60380.712910] x19: ffff0819b59acc00 x18: 0000000000000000
[60380.712911] x17: 0000000000000000 x16: ffffaf6e9ea8f140
[60380.712913] x15: 0000000000000000 x14: 0000000000000000
[60380.712915] x13: 0000000000000000 x12: 0000000000000000
[60380.712916] x11: ffff80002717bce8 x10: 0000000000000002
[60380.712918] x9 : 0000000000000001 x8 : 0000000000000238
[60380.712920] x7 : 0000000346cd2000 x6 : 0000000000000018
[60380.712921] x5 : ffffaf6e5b03b8a0 x4 : 0000000000000003
[60380.712923] x3 : 0000000000000002 x2 : ffff0819b59ace00
[60380.712925] x1 : 0000000000000003 x0 : 0000000000000000
[60380.712927] Call trace:
[60380.712928] nvmap_free_handle_from_fd+0xd0/0x260 [nvmap]
[60380.712937] nvmap_ioctl_free+0x44/0x90 [nvmap]
[60380.712946] nvmap_ioctl+0x1c4/0x500 [nvmap]
[60380.712955] __arm64_sys_ioctl+0xac/0xf0
[60380.712963] el0_svc_common.constprop.0+0x80/0x1d0
[60380.712974] do_el0_svc+0x38/0xb0
[60380.712978] el0_svc+0x1c/0x30
[60380.712985] el0_sync_handler+0xa8/0xb0
[60380.712988] el0_sync+0x16c/0x180
[60380.712995] Code: b40000c2 f9400440 f00000a5 912280a5 (f9403404)
[60380.712999] ---[ end trace 0000000000000002 ]---
[60381.148792] usb 2-1.3.1: Process 148118 (cameras_streams) called USBDEVFS_CLEAR_HALT for active endpoint 0x82
[60381.149147] usb 2-1.2: Process 148234 (cameras_streams) called USBDEVFS_CLEAR_HALT for active endpoint 0x84
