afhel
December 19, 2019, 8:15am
1
I want to convert bayerGB → rgba → NvVideoEncoder. My code is:
The code based on cudaBayerDemosaic and frontend
Thank you!
init()
initCUDA(&cudaContext_);
cuMemAlloc(&rgba_buffers_, bufferSize);
process()
unsigned char *bayer_buffer = static_cast<unsigned char *>(imagePtr->GetData());
cudaBayerDemosaic((CUdeviceptr) bayer_buffer,
CAMERA_IMAGE_WIDTH,
CAMERA_IMAGE_HEIGHT,
CAMERA_IMAGE_WIDTH * 4,
CU_EGL_COLOR_FORMAT_ARGB,
(CUdeviceptr)rgba_buffers_);
Raw2NvBuffer((unsigned char *)rgba_buffers_, 0, CAMERA_IMAGE_WIDTH, CAMERA_IMAGE_HEIGHT, m_argb_dmabuf_fd);
DaneLLL
December 19, 2019, 8:37am
2
https://devtalk.nvidia.com/default/topic/1068234/jetson-agx-xavier/how-can-i-convert-rgb8-to-h264-/post/5410820/#5410820
Please call NvBufferTransform() to convert NvBufferColorFormat_ABGR32 to NvBufferColorFormat_YUV420.
NvBufferColorFormat_ABGR32 should be pitch linear and NvBufferColorFormat_YUV420 is block linear.
afhel
December 19, 2019, 8:47am
3
hi,
My problem is bayerGB → rgba(because spinnakersdk convert it too slow). So I use cudaBayerDemosaic to convert.
rgba → NvVideoEncoder is ok now. Thanks for your help in the past.
afhel
December 19, 2019, 1:12pm
4
I use nppiCFAToRGBA_8u_C1AC4R fix the problem
cudaMemcpy2D(vesc_bayer_dev_, resv_bayer_step_, bayer_buffer, CAMERA_IMAGE_WIDTH, CAMERA_IMAGE_WIDTH,
CAMERA_IMAGE_HEIGHT, cudaMemcpyHostToDevice);
NppiSize size = { CAMERA_IMAGE_WIDTH, CAMERA_IMAGE_HEIGHT };
NppiRect roi = { 0, 0, CAMERA_IMAGE_WIDTH, CAMERA_IMAGE_HEIGHT };
NppStatus npp_convert_status = nppiCFAToRGBA_8u_C1AC4R(vesc_bayer_dev_, resv_bayer_step_, size, roi, resv_rgba_dev_,
resv_rgba_step_, NPPI_BAYER_RGGB, NPPI_INTER_UNDEFINED, 0xff);
DaneLLL
December 20, 2019, 1:46am
5
Good to hear that and thanks for sharing your finding.
