README found
Here I basically find the steps I used to execute many times
Building the Massflash Blob with ONLINE method
Building the massflash blob with ONLINE method requires:
- Set up a X86 Linux host as the ``signing host'' in safe location.
See ``L4T_quick_start_guide.txt'' for detailed host setup.
- If and only if secureboot is required, take extra steps:
See ``Installing the L4T Secureboot Package'' in README_secureboot.txt
to install secureboot package.
See ``Generating the RSA Key Pair'' in README_secureboot.txt
to generate the RSA Key-pair.
See ``Preparing the DK(KEK)/SBK/ODM Fuses'' in README_secureboot.txt
to prepare the DK(KEK)/SBK/ODM keys.
To generate the massflash blob with ONLINE method:
- Enter the command `cd Linux_for_Tegra`.
- connect one target Jetson device, and put it into RCM mode.
- sudo ./nvmassflashgen.sh [<secureboot options>] <device name> mmcblk0p1
See ``Signing and Flashing Boot Files in two steps'' in
README_secureboot.txt for details of <secureboot options>.
Examples for ONLINE massflash blob generation method:
To generate clear massflash blob:
sudo ./nvmassflashgen.sh <device name> mmcblk0p1
The outcome were non functining. In a way it would generate the MFI. It would flash it , But it wouldn;t boot. I was explained that execution of these steps above doesn’t load anything from the Jetson but takes only inputs from the Host PC folder.
Should these steps work for random custom carrier board with production module also with customized OS? In which way is it supported? The blob gets system.img generated from reference files on Host PCm it doesn’t load any information from connected Jetson unit in recovery mode? Or otherwise?
I will try to supply logs [which exactly log file needs to be attached?] which commands you would like me to use to capture the log?
