NVMe-oF Target Offload: initiator reports "genctr mismatch" / "bad command_id" only when attr_offload=1 (ConnectX-6 Lx, FW 26.43.8016)
Is NVMe-oF target offload a supported and validated feature on ConnectX-6 Lx?
With NVMe-oF target offload enabled on the target (attr_offload=1), the initiator logs completion-validation failures and enters error recovery, which resets the controller and stalls I/O.
With target offload disabled (attr_offload=0), the exact same hardware, fabric and backend drive run cleanly with no errors.
Errors observed
On the initiator
nvme nvme0: request 0x1b genctr mismatch (got 0x2 expected 0x3)
nvme nvme0: got bad command_id 0x201b on QP 0x2b4
nvme nvme0: starting error recovery
block nvme0n1: no usable path - requeuing I/O
Item Value
Adapter NVIDIA ConnectX-6 Lx
NIC firmware 26.43.8016
Kernel Debian 12 & 6.1.123
OFED VERSION 24.10-2.1.8
Transport RoCE (RoCEv2)
Target IOMMU amd_iommu=off on kernel cmdline
Please help us to debug further
NVMe-oF target offload on ConnectX-6 Lx is not a validated or officially supported configuration.
Thanks,
Suo
Hi ,
Thanks for your reply
https://network.nvidia.com/files/doc-2020/pb-connectx-6-lx-en-card-lenovo.pdf based on this data sheet, NVIDIA Mentioned it support target offload
Could You share list of Mellonax NIC that support NVMeoF RDMA Target offload
Thanks,
Mohamed
