Hello everyone,
I am encountering a persistent NVMe timeout issue on our custom carrier board designed for the Jetson AGX Orin module.
Environment:
Module: NVIDIA Jetson AGX Orin
JetPack Version: R36.4.0 (JP 6.1)
Carrier Board: Custom design (not an NVIDIA reference board)
orin_nvme_timeout_dmesg.txt (65.6 KB)
Would same NVMe hit this issue when using it on NV devkit?
Hi, @idealong
You might also want to try to disable the APST NVMe drive power-saving feature.
Disable APST by adding this to the kernel command line (/boot/extlinux/extlinux.conf) and reboot:
nvme_core.default_ps_max_latency_us=0
If it still occurs, also try disabling PCIe link power management (ASPM):
pcie_aspm=off
Daniel Chaves
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
