NVMe triggers IOMMU faults on TX2
$ sudo lspci -vv # from TX1 with kernel 3.10.x (working)
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 130
        Bus: primary=00, secondary=01, subordinate=08, sec-latency=0
        I/O behind bridge: 00001000-00002fff
        Memory behind bridge: 13000000-136fffff
        Prefetchable memory behind bridge: 0000000020000000-00000000203fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
                Mapping Address Base: 00000000fee00000
        Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0
                        ExtTag+ RBE+
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
                        ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
                        Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Off, PwrInd On, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet+ LinkState+
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
                RootCap: CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [140 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
        Kernel driver in use: pcieport
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane] (rev bb) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 547
        Region 0: Memory at 13600000 (32-bit, non-prefetchable)
        Bus: primary=01, secondary=02, subordinate=08, sec-latency=0
        Memory behind bridge: 13000000-135fffff
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [48] MSI: Enable+ Count=1/4 Maskable+ 64bit+
                Address: 000000017d95e000  Data: 0000
                Masking: 0000000f  Pending: 00000000
        Capabilities: [68] Express (v2) Upstream Port, MSI 00
                DevCap: MaxPayload 2048 bytes, PhantFunc 0
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                        MaxPayload 128 bytes, MaxReadReq 128 bytes
                LnkCap: Port #1, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM L1 Enabled; Disabled- CommClk-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
        Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane]
        Capabilities: [100 v1] Device Serial Number aa-86-00-10-b5-df-0e-00
        Capabilities: [fb4 v1] Advanced Error Reporting
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 1f, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [138 v1] Power Budgeting <?>
        Capabilities: [148 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending- InProgress-
        Capabilities: [950 v1] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?>
02:00.0 PCI bridge: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane] (rev bb) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 548
        Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
        Memory behind bridge: 13000000-130fffff
                Address: 000000017d95e000  Data: 0001
        Capabilities: [68] Express (v2) Downstream Port (Slot+), MSI 00
                        ExtTag- RBE+
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
                        ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive+ BWMgmt- ABWMgmt-
                        Slot #0, PowerLimit 25.000W; Interlock- NoCompl-
                        Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported ARIFwd+
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=4
                Status: InProgress-
                VC0:    Caps:   PATOffset=06 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32+ WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=WRR32 TC/VC=ff
                        Port Arbitration Table <?>
        Capabilities: [448 v1] Vendor Specific Information: ID=0000 Rev=0 Len=0cc <?>
        Capabilities: [520 v1] Access Control Services
                ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
02:04.0 PCI bridge: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane] (rev bb) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 549
        Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
                Address: 000000017d95e000  Data: 0002
                        ExtTag- RBE+
                LnkCap: Port #4, Speed 5GT/s, Width x8, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                LnkCtl: ASPM Disabled; Disabled- CommClk-
                LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
                        Slot #4, PowerLimit 25.000W; Interlock- NoCompl-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
                        Changed: MRL- PresDet- LinkState-
                Status: InProgress-
                        Status: NegoPending+ InProgress-
02:05.0 PCI bridge: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane] (rev bb) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 550
        Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: 00001000-00001fff
        Memory behind bridge: 13100000-132fffff
        Prefetchable memory behind bridge: 0000000020000000-00000000201fffff
                Address: 000000017d95e000  Data: 0003
                        ExtTag- RBE+
                LnkCap: Port #5, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                SltCap: AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise-
                        Slot #5, PowerLimit 25.000W; Interlock- NoCompl-
                        Control: AttnInd Unknown, PwrInd On, Power- Interlock-
                Status: InProgress-
02:06.0 PCI bridge: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane] (rev bb) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 551
        Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
                Address: 000000017d95e000  Data: 0004
                        ExtTag- RBE+
                LnkCap: Port #6, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                        Slot #6, PowerLimit 25.000W; Interlock- NoCompl-
                Status: InProgress-
02:08.0 PCI bridge: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane] (rev bb) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 552
        Bus: primary=02, secondary=07, subordinate=07, sec-latency=0
        Memory behind bridge: 13300000-133fffff
                Address: 000000017d95e000  Data: 0005
                        ExtTag- RBE+
                LnkCap: Port #8, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive+ BWMgmt+ ABWMgmt-
                        Slot #8, PowerLimit 25.000W; Interlock- NoCompl-
                Status: InProgress-
02:09.0 PCI bridge: PLX Technology, Inc. PEX 8624 24-lane, 6-Port PCI Express Gen 2 (5.0 GT/s) Switch [ExpressLane] (rev bb) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 553
        Bus: primary=02, secondary=08, subordinate=08, sec-latency=0
        I/O behind bridge: 00002000-00002fff
        Memory behind bridge: 13400000-135fffff
        Prefetchable memory behind bridge: 0000000020200000-00000000203fffff
                Address: 000000017d95e000  Data: 0006
                        ExtTag- RBE+
                LnkCap: Port #9, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                        Slot #9, PowerLimit 25.000W; Interlock- NoCompl-
                Status: InProgress-
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a804 (prog-if 02 [NVM Express])
        Subsystem: Samsung Electronics Co Ltd Device a801
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
        Region 0: Memory at 13000000 (64-bit, non-prefetchable)
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Capabilities: [70] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us
                        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
                        ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
        Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
                Vector table: BAR=0 offset=00003000
                PBA: BAR=0 offset=00002000
        Capabilities: [100 v2] Advanced Error Reporting
        Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
        Capabilities: [158 v1] Power Budgeting <?>
        Capabilities: [168 v1] #19
        Capabilities: [188 v1] Latency Tolerance Reporting
                Max snoop latency: 0ns
                Max no snoop latency: 0ns
        Capabilities: [190 v1] L1 PM Substates
                          PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
        Kernel driver in use: nvme
        Kernel modules: nvme
07:00.0 Memory controller: Xilinx Corporation Device 7024
        Subsystem: Xilinx Corporation Device 0007
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
        Interrupt: pin ? routed to IRQ 560
        Region 0: Memory at 13300000 (64-bit, non-prefetchable)
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
        Capabilities: [48] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 000000017d95e000  Data: 000b
        Capabilities: [60] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
        Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
        Kernel driver in use: ********-v4l2
Hi danieel,
We would like to ask you to share all the drivers and patch you have added to this.
Since there is a PLX switch, I believe we don’t have stress test under such case before.
Hi danieel,
Is the FPGA between the Tegra and PCIE switch? TX2 <-> FPGA <-> PEX8624 <-> NVMe SSD
Hi WayneWWW, the FPGA is behind the switch:
TX2 <–> PLX8624 <–> FPGA, NVMe, 10GE, unused x8 slot
What we actually see in the FPGA is a completion timeout. I am trying to get hold of a dump of addresses to which the reads were issued.
Using a test pattern generator which produces different amount of FPS (137 instead of 60) did not lead to any crash. This is happening really on random basis and can be exploited only when test is ran on all 4 nodes of the cluster. Trying it on one, the wait time is often too long.
I have hacked the kernel driver:
/sources/kernel/kernel-4.4/drivers/nvme/host/pci.c
static void nvme_dev_remove(struct nvme_dev *dev)
@@ -3205,6 +3212,8 @@
        dev_warn(dev->dev, "Device failed to resume\n");
        kref_get(&dev->kref);
+       dev_warn(dev->dev, "RZSN: NOT removing dead controller\n");
+        return;
        if (IS_ERR(kthread_run(nvme_remove_dead_ctrl, dev, "nvme%d",
                                                dev->instance))) {
                dev_err(dev->dev,
in order to get rid of the kernel panic / crashes involving the nvme_remove_dead_ctrl being in the backtrace.
The behavior is now clearer. There is no MC ERR nor SMMU violation in the dmesg after the crash. Only the NVMe drive has its FATAL status set, and therefore is being reset and I/Os being cancelled to it. No crash.
This allowed to do a lspci -vvv with the NVMe, which supports AER, and the result is:
        Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin A routed to IRQ 390
        Region 0: Memory at 50100000 (64-bit, non-prefetchable)
                DevSta: CorrErr+ UncorrErr+ FatalErr- UnsuppReq- AuxPwr+ TransPend-
        Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
                UESta:  DLP- SDES- TLP- FCP- CmpltTO+ CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                AERCap: First Error Pointer: 0e, GenCap+ CGenEn- ChkCap+ ChkEn-
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Latency: 0
        Interrupt: pin ? routed to IRQ 464
        Region 0: Memory at 50400000 (64-bit, non-prefetchable)
                Address: 00000000d930c000  Data: 000d
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
As you can see, there is DevSta: UncorrErr+ which is detailed in UESta: CmpltTO+ . In parallel to that the FATAL STATUS is set in order to allow the driver to handle the failure situation.
The streaming of V4L2 stops, since we have not implemented a completion timeout timer in the FPGA yet, but we will update the design and enable AER as well. But I am pretty sure there will be a completion error as well.
The previous SMMU violation were therefore caused by the NVMe and a wrong NVMe removing code, not by our FPGA. We have also confirmed this by having logged the outbound data into the Xilinx PCIe hardblock using integrated analysis tools.
Asserting TimeoutDis (DevCtl2) on the NVMe drive will result in timed out I/O operations because they never complete and the driver has a check mechanism built-in. Deasserting TimeoutDis after that results in Completion timeout indicated in AER and device status immediately after some queue with nvme i/o is activated.
Seems like the PCIe host is refusing to respond to any read requests from NVMe, but the opposite direction works! - reads from the device registers (mmap to userspace for ease of use) still return valid data from the devices (checked on both NVMe and FPGA to read known registers).
Where can we check if the AFI-R is not stuck in some locked, inoperable state?
Under what condition the reads from devices would not be answered by Tegra X2 ?
I do not believe that the switch could block the flow in one way only and I think the Tegra just stops responding to reads. We would need a better architectural documentation than just the Parker TRM where registers are listed with no apparent logic behind them. Does anything exist like that?
I see the PCIe host in Tegra a similar mess as SATA was/is:
Does not support TLP prefixes or ECRC
page 3619 of Parker TRM v1.0p
vs. lspci:
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1) (prog-if 00 [Normal decode])
GenCap+ = ECRC Generation Capable
ChkCap+ = ECRC Check Capable
And the last proof that the reads do not work. We got that 10GE NIC whose driver was unloaded before running the stress test. After the crash, we can modprobe the driver - it shows up correctly. Until any DMA happens. The driver treats the 10GE card which can’t do reads from system memory this way:
[ 2507.163347] ixgbe 0000:08:00.1 enp8s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[ 2513.255573] ixgbe 0000:08:00.1 enp8s0f1: Detected Tx Unit Hang
                 Tx Queue             <0>
                 TDH, TDT             <0>, <2>
                 next_to_use          <2>
                 next_to_clean        <0>
[ 2513.255600] ixgbe 0000:08:00.1 enp8s0f1: tx_buffer_info[next_to_clean]
                 time_stamp           <100086e3d>
                 jiffies              <100087163>
[ 2513.255612] ixgbe 0000:08:00.1 enp8s0f1: tx hang 10 detected on queue 0, resetting adapter
[ 2513.255626] ixgbe 0000:08:00.1 enp8s0f1: Reset adapter
[ 2513.255752] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 2513.255873] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 2513.255992] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 2513.256111] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 2513.446062] ixgbe 0000:08:00.1 enp8s0f1: PCIe transaction pending bit also did not clear.
[ 2513.446068] ixgbe 0000:08:00.1: master disable timed out
[ 2513.476007] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 0 not cleared within the polling period
[ 2513.480044] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 1 not cleared within the polling period
[ 2513.484091] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 2 not cleared within the polling period
[ 2513.488155] ixgbe 0000:08:00.1 enp8s0f1: RXDCTL.ENABLE on Rx queue 3 not cleared within the polling period
[ 2513.657881] ixgbe 0000:08:00.1 enp8s0f1: detected SFP+: 6
[ 2514.011350] ixgbe 0000:08:00.1 enp8s0f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
From now on, we will operate with ASPM off, kernel option pcie_aspm=off will ensure that. There is some errata in PLX8624 about wrong DLLP packets at ASPM transitions.
A new type of message was noticed in the kernel log:
[  393.979318] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x00000000, fsynr=0x60001, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[  394.108845] irq 55: nobody cared (try booting with the "irqpoll" option)
[  394.108854] CPU: 0 PID: 2255 Comm: dd Tainted: G           O    4.4.38+ #22
[  394.108857] Hardware name: quill (DT)
[  394.108860] Call trace:
[  394.131148] [<ffffffc000089a10>] dump_backtrace+0x0/0xe8
[  394.131153] [<ffffffc000089b0c>] show_stack+0x14/0x20
[  394.131159] [<ffffffc0003c1bd0>] dump_stack+0xa0/0xc8
[  394.131164] [<ffffffc0000f6a38>] __report_bad_irq+0x38/0xe8
[  394.131168] [<ffffffc0000f6dc8>] note_interrupt+0x210/0x2f0
[  394.131171] [<ffffffc0000f4204>] handle_irq_event_percpu+0x224/0x2a0
[  394.131174] [<ffffffc0000f42c8>] handle_irq_event+0x48/0x78
[  394.131177] [<ffffffc0000f7860>] handle_fasteoi_irq+0xb8/0x1b0
[  394.131179] [<ffffffc0000f367c>] generic_handle_irq+0x24/0x38
[  394.131181] [<ffffffc0000f397c>] __handle_domain_irq+0x5c/0xb8
[  394.131184] [<ffffffc0000815b8>] gic_handle_irq+0x68/0xf0
[  394.131188] [<ffffffc000084740>] el1_irq+0x80/0xf8
[  394.131192] [<ffffffc0000a70d0>] irq_exit+0x88/0xe0
[  394.131194] [<ffffffc0000f3980>] __handle_domain_irq+0x60/0xb8
[  394.131196] [<ffffffc0000815b8>] gic_handle_irq+0x68/0xf0
[  394.131199] [<ffffffc000084740>] el1_irq+0x80/0xf8
[  394.131204] [<ffffffc000258c44>] ext4_mark_inode_dirty+0x64/0x208
[  394.131207] [<ffffffc00025c3ac>] ext4_dirty_inode+0x44/0x70
[  394.131213] [<ffffffc0002030f4>] __mark_inode_dirty+0x74/0x4b0
[  394.131217] [<ffffffc00020c5ac>] generic_write_end+0x74/0xd0
[  394.131220] [<ffffffc00025b010>] ext4_da_write_end+0x178/0x2d0
[  394.131225] [<ffffffc0001735b8>] generic_perform_write+0x110/0x198
[  394.131228] [<ffffffc000175568>] __generic_file_write_iter+0x170/0x1d0
[  394.131231] [<ffffffc00024f8b0>] ext4_file_write_iter+0xd8/0x378
[  394.131236] [<ffffffc0001d5014>] __vfs_write+0x9c/0xd0
[  394.131238] [<ffffffc0001d58e8>] vfs_write+0x90/0x1b8
[  394.131241] [<ffffffc0001d648c>] SyS_write+0x44/0xa0
[  394.131244] [<ffffffc000084ff0>] el0_svc_naked+0x24/0x28
[  394.131245] handlers:
[  394.131251] [<ffffffc000964e48>] tegra_mcerr_hard_irq threaded [<ffffffc000964e90>] tegra_mcerr_thread
[  394.131257] Disabling IRQ #55
[  394.166622] unknown mcerr fault, int_status=0x00001040, ch_int_status=0x00000200, hubc_int_status=0x00000000
[  394.808481] nvme 0000:03:00.0: Failed status: 3, reset controller
[  394.808590] nvme 0000:03:00.0: Cancelling I/O 130 QID 5
What could this unknown mcerr fault, int_status=0x00001040, ch_int_status=0x00000200, hubc_int_status=0x00000000 mean ? It happened before the hang (starting with the nvme Failed status: 3). Interesting enough, there is some IOMMU violation even before that, with the zero address, coming from an unknown source, since the buggy nvme reset code is still masked out.
I think this is the moment when something is dying, not that the zero request would be a legal transaction.
We have checked the AFI configuration in /sys/kernel/debug/pcie/dump_afi_space before/after the hang and has no differences.
We have implemented a similar dump_rp_space to see the RP registers and status flags, and the reading there is again same before/after the hang.
I can confirm now that there is no safe kernel or hardware version. The TX1 with 3.10 kernel (R24.1) and both TX1 and TX2 with 4.4 kernel (R28.1) do hang when there is significant traffic on the PCIe bus.
To trigger TX1 into hang it needs a bit more effort - simultaneous recording of files (done with O_DIRECT) by our application plus eight dd in background, totaling at over 900MB/s to a Samsung 950 Pro.
To add some additional information as I believe I’m seeing a similar problem, I have a Gen2 4-lane FPGA based PCIe device which throws similar errors when performing DMA operations. The DMA operations appear to transfer good data to the appropriate addresses but dmesg shows this:
[   76.390241] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x3453060000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   76.403663] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x102450000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   76.574057] irq 55: nobody cared (try booting with the "irqpoll" option)
[   76.580753] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G           O    4.4.38-tegra #1
[   76.588393] Hardware name: quill (DT)
[   76.592046] Call trace:
[   76.594492] [<ffffffc000089860>] dump_backtrace+0x0/0x100
[   76.599880] [<ffffffc000089a28>] show_stack+0x14/0x1c
[   76.604922] [<ffffffc00033ccf8>] dump_stack+0x98/0xc0
[   76.609965] [<ffffffc0000f7d64>] __report_bad_irq+0x38/0xe0
[   76.615525] [<ffffffc0000f80bc>] note_interrupt+0x1f4/0x2b4
[   76.621087] [<ffffffc0000f55e0>] handle_irq_event_percpu+0xfc/0x290
[   76.627340] [<ffffffc0000f57b8>] handle_irq_event+0x44/0x74
[   76.632900] [<ffffffc0000f8ac0>] handle_fasteoi_irq+0xb4/0x188
[   76.638719] [<ffffffc0000f4b88>] generic_handle_irq+0x24/0x38
[   76.644453] [<ffffffc0000f4e90>] __handle_domain_irq+0x60/0xb4
[   76.650273] [<ffffffc0000815dc>] gic_handle_irq+0x5c/0xb4
[   76.655660] [<ffffffc000084740>] el1_irq+0x80/0xf8
[   76.660440] [<ffffffc0000a9150>] irq_exit+0x84/0xdc
[   76.665307] [<ffffffc0000f4e9c>] __handle_domain_irq+0x6c/0xb4
[   76.671126] [<ffffffc0000815dc>] gic_handle_irq+0x5c/0xb4
[   76.676512] [<ffffffc000084740>] el1_irq+0x80/0xf8
[   76.681294] [<ffffffc00081d154>] cpuidle_enter+0x18/0x20
[   76.686594] [<ffffffc0000e832c>] call_cpuidle+0x28/0x50
[   76.691807] [<ffffffc0000e84d0>] cpu_startup_entry+0x17c/0x340
[   76.697630] [<ffffffc000b7252c>] rest_init+0x84/0x8c
[   76.702585] [<ffffffc001128980>] start_kernel+0x3a0/0x3b4
[   76.707971] [<0000000080b78000>] 0x80b78000
[   76.712144] handlers:
[   76.714412] [<ffffffc0008b35b8>] tegra_mcerr_hard_irq threaded [<ffffffc0008b3604>] tegra_mcerr_thread
[   76.723721] Disabling IRQ #55
[   76.726790] (255) csw_afiw: MC request violates VPR requirements
[   76.732877]   status = 0x00337031; addr = 0x3ffffffc0
[   76.737972]   secure: yes, access-type: write
[   80.870475] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x3453060000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   80.883955] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x4b9402000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   83.110569] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x3453060000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   83.124053] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x4b9402000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   84.710643] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x3453060000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   84.724121] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x4b9402000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   86.950737] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x3453060000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   86.964199] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x11a0704a40, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
[   87.590764] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x3453060000, fsynr=0x40011, cb=22, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
The unhandled context fault lines in dmesg just keep piling up.
The interesting thing is if I rebuild my FPGA to only link up at Gen1 speeds, these errors all disappear.
We have implemented an PCIe packet excerciser into our FPGA device.
Results:
  • we can read NVMe registers directly from FPGA, with packets routed by the PLX chip
  • we discovered a specific behaviour of TEGRA PCIe host when in crashed state
Final findings are:
Under continuous, long, but not yet not really heavy load ( 6Gb/s write to tegra, 4 to 8 Gb/s of read from tegra) created by our camera FPGA and Samsung NVMe drive, the Tegra PCIe root complex will loose track of number of open read requests. It forgets to answer some, until future requests arrive, which cause the sooner requests to be answered. Under this situation, the devices asking for data are not getting proper responses - the completions returned are out-of-sync, they are for the requests created well in the past. None of the PCIe device IP cores (Samsung NVMe, Intel 10GE our FPGA) are able to deal with nor recover from such a situation.
When we have a look to the patches present in the source code, I should bring your attention to:
https://patchwork.kernel.org/patch/10032059/
This tells us that the Tegra can:
  • likely have 32 open transactions = has a FIFO/queue (or a reorder-pool to service multiple requests at once)
  • uses a up/down counter (which overflows - chip design error) to track number of unanswered read requests
The events happening in our case of PCIe hang is therefore this:
  • the counter indicates wrong number of unanswered read requests, count is 0, but there are queued some
  • when new read request comes in, the counter is incremented, and a request queued previously is serviced
  • after servicing the request, the counter is decremented, and since it is again zero, the execution of requests stops
Furhter details are kept in private channels.
Hi daniell,
Could you print out the result of “cat /proc/interrupts” under the case of #27?
It looks like interrupt-55 came multiple times and it wasn’t served. wondering what this interrupt is?
Are you still using rel-28.1 BSP?
Yes, we are using L4T 28.1 and there is no customization as our test tools run on the supplied Ubuntu.
The interrupt 55 in question belongs always to memory controller error handler:
$ cat /proc/interrupts | grep 55:
55:          0          0          0          0     GICv2 255 Level     mc_status
Hi danieel,
Few question and experiments for you.
  1. Based on experiments done by you, it looks like after system hangs, responses/completions for read requests initiated by FPGA end point don’t reach FPGA end point in timely fashion (rather delayed fashion). Now, This could be because Tegra didn’t respond in time or Tegra responded but switch has some issue (probably in its USP - Upstream port) and couldn’t really forward completion downstream. Can we rule out the possibility that, in the hang state, switch is not caching completions and delaying them? One experiment to do to confirm this is to connect PCIe protocol analyzer between Tegra and switch and see if Tegra responds immediately with correct Tag or not.
2.If system console is accessible in hang state, can we dump ‘sudo lspci -vvvv’ and see if there are any completion timeouts observed at switch level? Our current understanding is that, when FPGA requests for read, it observes completion timeout in the hang state. We are wondering if switch is also observing completion timeout?
  1. In the hang state, Can we try to issue a read to FPGA end point’s BAR? that would flush out any completions stuck in that path. This would be a good data point.
  2. When the system is working fine (probably just after boot), need to initiate read using bbt application and record read time, and do the same after hang. we would like to see if there is any pattern observed there in terms of how much time it takes to get the completion?
Hi WayneWWW,
  1. The packet generator controlled by bbt tool can also issue write requests. This way, we already checked, that the writes are executed immediately (separate AFIW path in Tegra?) and the read requests are returned with the written value. The reads are definitely queued, and the front of the queue is executed at the moment when a new read request is received by the Tegra.
Since our FPGA advertises infinite completion credits, the switch shall work in cut-through mode and pass every completion without buffering, which we believe it does. And if it would buffer the completions, then the write packets would not change the value of already executed reads. It is not the case - the reads are really executed late.
  1. The switch ports do not check for Completion timeouts, it is a bridge, not an end-point. Only the SSD and FPGA does assert this flag.
  2. How is that possible? Does lspci -vvv read the config space live from hardware or uses a cached version? We saw that the access-methods are not like on a PC (direct hardare, BIOS, ACPI).
  3. I will check the timing, but it has quite large spread (probably first access has to load the SMMU page table as well).
lspci reads data live from hardware. This is possible only if the console is accessible in the hang state of your system
In that case, the answer to #34 question 3 is that reading bars through lspci -vvv does not change anything. The queued read requests are serviced when a new one is submitted, nothing is lost, only that the completion comes for a read request submitted 2 to 4 packets sooner, which might be few seconds/minutes ago.
Assuming there is a fifo/queue on front of the AFI-R (completer logic in the Tegra PCIe root complex), how do we flush it (restore write/read pointers) without disturbing other portions? My understanding of this bug is that the pointers get out of sync (by a so far unidentified cause) and the count is treated as zero = not executing anything. When a new read request is submitted, it is written to end of queue, triggering the execution from the front. But since the pointers are wrong, the executed packet is few packets older.
There might be some information on how the bug behaves on the start - when submitting read requests immediately after the hang, there are X completion timeouts (which corresponds to the misalignment numbers - there might be other endpoint’s packets in the queue). After X, the X+1 request will result with servicing the 1st read request.
The system rarely hangs into unusable state, and we are able to run anything on the system. Tasks which do not require AFIR / root complex completer / are okay - register read/write access to endpoints do work correctly.
Can you please give ‘sudo lspci -vv’ output after it is hung?
Reply to #34 question 4: timing information
The timing in usec for GOOD state is:
1.1     2480
1.2     5508
1.3     746
1.4     439
1.5     486
1.6     129
1.7     187
1.8     14
1.9     7
2.0     2
2.1     1
2.4     1
For the FAIL state it is:
1.1     165
1.2     7524
1.3     789
1.4     296
1.5     545
1.6     127
1.7     349
1.8     119
1.9     25
2.0     8
2.1     22
2.3     3
2.4     24
30000   4
We have a PCIe core cycle accurate metrics (125 MHz), so the raw timing data from 10k sample size is:
GOOD
1.128   9
1.144   97
1.160   168
1.176   224
1.192   1982
1.200   7
1.208   2304
1.216   2
1.224   945
1.240   867
1.248   1
1.256   721
1.264   1
1.272   445
1.280   3
1.288   212
1.304   162
1.312   1
1.320   154
1.328   1
1.336   123
1.344   1
1.352   96
1.368   114
1.376   1
1.384   93
1.400   124
1.416   67
1.432   61
1.448   55
1.464   60
1.480   36
1.496   36
1.512   146
1.528   18
1.544   10
1.560   281
1.568   1
1.576   15
1.592   15
1.608   13
1.624   15
1.640   17
1.656   24
1.672   26
1.688   34
1.704   19
1.720   25
1.736   47
1.752   46
1.760   1
1.768   35
1.784   14
1.800   5
1.816   3
1.832   2
1.864   2
1.880   1
1.896   1
1.912   2
1.928   1
1.944   1
1.960   1
1.992   2
2.024   1
2.088   1
2.120   1
2.456   1
FAIL
1.136   3
1.152   25
1.168   48
1.184   88
1.192   1
1.200   1249
1.208   3
1.216   2474
1.224   1
1.232   960
1.240   4
1.248   957
1.264   892
1.280   603
1.296   381
1.312   248
1.328   186
1.344   120
1.360   95
1.376   76
1.392   64
1.408   75
1.424   48
1.440   36
1.456   57
1.472   46
1.488   34
1.504   24
1.520   118
1.536   25
1.552   12
1.568   309
1.584   57
1.600   7
1.616   11
1.632   18
1.648   20
1.664   24
1.680   21
1.696   26
1.712   32
1.720   1
1.728   49
1.744   80
1.760   79
1.776   69
1.792   39
1.808   28
1.824   22
1.832   1
1.840   26
1.856   22
1.872   12
1.888   8
1.904   8
1.920   6
1.936   5
1.952   1
1.968   4
1.984   1
2.000   2
2.016   1
2.032   2
2.096   3
2.112   13
2.128   7
2.160   2
2.336   1
2.368   1
2.384   1
2.464   24
30000   4
The 30000 number is our 30ms completion timeout, which indicate that the first four read-requests are not serviced due to the dead queue.
Here it is:
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Latency: 0
	Memory behind bridge: 50100000-508fffff
	Prefetchable memory behind bridge: 0000000058000000-00000000583fffff
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
			ExtTag+ RBE+
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
	Latency: 0
	Interrupt: pin A routed to IRQ 450
	Region 0: Memory at 50800000 (32-bit, non-prefetchable)
	Memory behind bridge: 50100000-507fffff
		Address: 00000000d931f000  Data: 0000
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
		Status:	InProgress-
	Latency: 0
	Interrupt: pin A routed to IRQ 451
	I/O behind bridge: 0000f000-00000fff
	Memory behind bridge: 50100000-501fffff
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
		Address: 00000000d931f000  Data: 0001
			ExtTag- RBE+
		LnkSta:	Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive+ BWMgmt+ ABWMgmt+
		Status:	InProgress-
	Latency: 0
	Interrupt: pin A routed to IRQ 452
	Memory behind bridge: fff00000-000fffff
		Address: 00000000d931f000  Data: 0002
			ExtTag- RBE+
		Status:	InProgress-
	Latency: 0
	Interrupt: pin A routed to IRQ 453
	Memory behind bridge: 50200000-503fffff
	Prefetchable memory behind bridge: 0000000058000000-00000000581fffff
		Address: 00000000d931f000  Data: 0003
			ExtTag- RBE+
			Changed: MRL+ PresDet- LinkState-
		Status:	InProgress-
	Latency: 0
	Interrupt: pin A routed to IRQ 454
		Address: 00000000d931f000  Data: 0004
			ExtTag- RBE+
		Status:	InProgress-
	Latency: 0
	Interrupt: pin A routed to IRQ 455
	Memory behind bridge: 50400000-504fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR+ <PERR-
		Address: 00000000d931f000  Data: 0005
			ExtTag- RBE+
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout+ NonFatalErr-
		Status:	InProgress-
	Latency: 0
	Interrupt: pin A routed to IRQ 456
	Memory behind bridge: 50500000-507fffff
	Prefetchable memory behind bridge: 0000000058200000-00000000583fffff
		Address: 00000000d931f000  Data: 0006
			ExtTag- RBE+
		LnkCap:	Port #9, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
			Changed: MRL+ PresDet+ LinkState+
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd+
		Status:	InProgress-
	Latency: 0
		Address: 00000000d931f000  Data: 000d
		DevSta:	CorrErr+ UncorrErr+ FatalErr- UnsuppReq- AuxPwr- TransPend-
		DevCap2: Completion Timeout: Range A, TimeoutDis-, LTR-, OBFF Not Supported
	Capabilities: [10c v1] Advanced Error Reporting
		CESta:	RxErr- BadTLP+ BadDLLP+ Rollover- Timeout+ NonFatalErr-
08:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
	Subsystem: Intel Corporation Ethernet Server Adapter X520-2
	Region 0: Memory at 50500000 (64-bit, non-prefetchable)
	Region 2: I/O ports at 2000 [disabled]
	Region 4: Memory at 50700000 (64-bit, non-prefetchable)
	[virtual] Expansion ROM at 50580000 [disabled]
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
		Masking: 00000000  Pending: 00000000
	Capabilities: [70] MSI-X: Enable- Count=64 Masked-
		Vector table: BAR=4 offset=00000000
		PBA: BAR=4 offset=00002000
	Capabilities: [a0] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
		LnkCap:	Port #9, Speed 5GT/s, Width x8, ASPM L0s, Exit Latency L0s unlimited, L1 <32us
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
	Capabilities: [140 v1] Device Serial Number 00-1b-21-ff-ff-89-6e-38
	Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
		ARICap:	MFVC- ACS-, Next Function: 1
		ARICtl:	MFVC- ACS-, Function Group: 0
	Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
		IOVCap:	Migration-, Interrupt Message Number: 000
		IOVCtl:	Enable- Migration- Interrupt- MSE- ARIHierarchy-
		IOVSta:	Migration-
		Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 00
		VF offset: 384, stride: 2, Device ID: 10ed
		Supported Page Size: 00000553, System Page Size: 00000001
		Region 0: Memory at 0000000000000000 (64-bit, non-prefetchable)
		Region 3: Memory at 0000000000000000 (64-bit, non-prefetchable)
		VF Migration: offset: 00000000, BIR: 0
	Kernel modules: ixgbe
08:00.1 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
	Interrupt: pin B routed to IRQ 390
	Region 0: Memory at 50600000 (64-bit, non-prefetchable)
	Region 2: I/O ports at 2020 [disabled]
	Region 4: Memory at 50704000 (64-bit, non-prefetchable)
	[virtual] Expansion ROM at 50680000 [disabled]
		ARICap:	MFVC- ACS-, Next Function: 0
		IOVSta:	Migration-
		Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 01
