I thought I’d bring up some issues and inconsistencies I found in the NvMedia documentation while using it, so they can be fixed and no one has to waste as many hours as I had to.
- Unclear meaning of
NvMediaBitstreamBuffer
members
Current descriptions are very roundabout and unclear when used withNvMediaIEPGetBitsEx()
It’s not obvious which parameters the user should provide and which the call itself writes to.
It would be helpful to expand on the descriptions and clarify which are in/out parameters.
From trial-and-error:
NvMediaBitstreamBuffer::bitstream
is an user-provided pointer to an output buffer. -
NvMediaBitstreamBuffer::bitstreamBytes
is the number of bytes actually written by the call (out parameter). -
NvMediaBitstreamBuffer::bitstreamSize
is the maximum number of bytes that can be written (aka the size of the user-provided buffer).
refers to a parameter namedbuffer
, which doesn’t exist.
NVMEDIA_STATUS_OK
is returned, thebuffer
is filled […]
NvMediaIEPBitsAvailable()
has duplicateNVMEDIA_STATUS_NONE_PENDING
return value explanations -
NvMediaIEPFeedFrame()
can returnNVMEDIA_STATUS_ERROR
IfNVMEDIA_ENCODER_INSTANCE_AUTO
was passed toNvMediaIEPCreate()
andNVMEDIA_ENCODER_INSTANCE_AUTO
is also passed toNvMediaIEPFeedFrame()
This behaviour doesn’t seem to be documented. Took me 10h to figure out. -
NvMediaEncodeInitializeParamsH264::enableROIEncode
deprecated?
Per comment atnvmedia_core.h:407
NvMediaROI
has been removed. I can’t find anything else related to ROI either.
Has ROI support for encoding been removed/deprecated? If so, theenableROIEncode
documentation should mention this. -
NvMediaEncoder
H265 support (separate thread)
