Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.0.8846
other
Host Machine Version
native Ubuntu 18.04
other
We experienced the following nvmedia camera related errors,
after the error happened the related cameras does not send new image frames.
This error happens after variable number of frames grabbed successfully (100 - 1600).
We saw this error on all of the three camera groups that has camera connected to it.
group A IMX490 on GMSL link: 3
group B IMX390 on GMSL link: 0
group B IMX390 on GMSL link: 1
group C IMX390 on GMSL link: 2
Can you help us to find the root cause of this problem?
MAX96712: Revision 4 detected
MAX96712: SetCMU2Default
MAX9295: Revision 8 detected!
Sensor IMX490 Rev 5 RGGB detected!
Module_id 22 Severity 6 : NvMediaICPCreateEx 76
Module_id 22 Severity 6 : T19x VI version 0x000019
Sensor IMX390 Rev 0 RGGB detected!
nvmedia: ERROR: MAX96712: Register 0x0006 I2C read failed with status 7
DEVBLK_MON_0: CNvMMax96712.cpp: 444: DetectErrors: MAX96712GetErrorStatus failed! with NvMedia error: 7
DEVBLK_MON_0: CNvMDeviceBlock.cpp: 416: DetectErrors: Deserializer DetectErrors failed in CNvMDeviceBlock::DetectErrors
failed! with error: 7f
DEVBLK_MON_0: CNvMDeviceBlockMgr.hpp: 236: ThreadFunc: DetectErrors failed. status:7f
DEVBLK_WORKER_0: pwr_utils.cpp: 288: PowerControlSetPower: PowerControlSetPower: nvccp_set_aggreg_pwr_off failed with status (2)
Dear @laszlo.finta,
Is it using any NvMedia sample? If so, could you share the command?
We executed the following command and get the same result after some time:
./nvsipl_camera -c IMX490_RGGB_CPHY_x4 --link-enable-masks ‘0x0100 0x0000 0x0000 0x0000’ -d 0 -w 1
root@tegra-ubuntu:/home/nvidia/drive-t186ref-linux/samples/nvmedia/nvsipl/test/camera# ./nvsipl_camera -c IMX490_RGGB_CPHY_x4 --link-enable-masks '0x0100 0x0000 0x0000 0x0000' -d 0 -w 1
nvsipl_camera: Opened NITO file for module "IMX490_RGGB"
Enter 'ld' to list display-able outputs.
Enter 'e' followed by 'ID' to enable display for specific camera group
Enter 'p' followed by '0 (NV) or 1 (SAMPLE) or 2 (CUSTOM)' and 's' followed by sensors ID to enable specific plugin
Enter 'q' to quit the application
nvsipl_camera: ERROR: Pipeline: 2, NOTIF_ERROR_ICP_BAD_INPUT_STREAM
nvsipl_camera: ERROR: Pipeline failure
EngineStatusError (2), Detailed Error Code: 00000002 at StreamId:0 vcId:0 CSIFrameId:0 notified-bits:4000000
Dear @laszlo.finta,
I don’t see IMX490 camera module in supported sensor list given at DRIVE Ecosystem - Hardware and Software | NVIDIA Developer.
Dear Siva Rama Krishna,
As I mentioned in the ticket description we saw the same issue with all the cameras not just the IMX490.
The IMX390 cameras are listed in the supported sensor list, aren’t they?
Dear @laszlo.finta,
Any update can be provided?
