Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I am writing some unit tests around my usage of the IEP engine and getting weird errors when using sync fences. I’m not sure if my understanding or usage is somehow wrong.
Error String
I see these following errors printed out on Orin
tegraH265EncodeGetStatus: SyncPoint wait Error
Logs
Here is a sample code snippet modified slightly to remove company utilities. I’m trying to essentially test that the encoder is not processing the image until after a prefence is signaled and NvMediaIEPBitsAvailable is timed out until a prefence is signaled.
NvMediaIEPRegisterNvSciSyncObj(encoder_context_, NVMEDIA_PRESYNCOBJ, *pre_sync_obj_)
NvMediaIEPRegisterNvSciSyncObj(encoder_context_, NVMEDIA_EOFSYNCOBJ, *eof_sync_obj_)
// pre fence is used to signal the encoder to start
NvSciSyncFence pre_fence = NvSciSyncFenceInitializer;
// eof fence is used to signal the consumer that the encoder has finished
NvSciSyncFence eof_fence = NvSciSyncFenceInitializer;
EXPECT_EQ(NvSciSyncObjGenerateFence(pre_sync_obj_, &pre_fence),
NvSciError_Success);
NvMediaIEPInsertPreNvSciSyncFence(encoder_context_, &pre_fence)
NvMediaIEPFeedFrame(
encoder_context_, buf_obj, &encoder_pic_params_, encoder_instance_id_);
NvMediaIEPGetEOFNvSciSyncFence(encoder_context_, *eof_sync_obj_, fence)
// Line1:
EXPECT_EQ(NvMediaIEPBitsAvailable(
encoder_context_, &num_bytes_available,
NVMEDIA_ENCODE_BLOCKING_TYPE_IF_PENDING, 1000)), NVMEDIA_STATUS_TIMED_OUT);
// This signals encoding to start
//Line 2:
EXPECT_EQ(NvSciSyncObjSignal(pre_sync_obj_), NvSciError_Success);
// Wait for the encoder to finish
//Line 3:
NVMEDIA_ENCODE_BLOCKING_TYPE_IF_PENDING, 1000)), NVMEDIA_STATUS_okay);
std::vector<uint8_t> buffer(num_bytes_available);
EXPECT_OK(encoder_->GetEncodedData(buffer));
The previous code snippet fails and if I set the timeout for the NvMediaIEPBitsAvailable to infinite on Line 3, then it waits infinitely as if the prefence was not signaled.
If I just comment out line 1 then it works perfectly as if I’m not allowed to query if the data is ready before waiting.
I’ve also thought, maybe I’m not allowed to query before the data is signaled to be ready. So I added some waits on the eof fence, but that also doesn’t work.
EXPECT_EQ(NvSciSyncFenceWait(&eof_fence, cpu_wait_context_, 1000 * 1000),
NvSciError_Timeout);
// Line1:
//Line 2:
EXPECT_EQ(NvSciSyncFenceWait(&eof_fence, cpu_wait_context_, 5000 * 1000),
//Line 3:
Can you help me understand, if I’m misusing the encoder?
