NvMediaIEP bad keyframes after 3330s
Hardware Platform: DRIVE AGX Xavier™ Developer Kit
Software Version: DRIVE Software 10
Host Machine Version: native Ubuntu 18.04
NvMediaIEP seems to return very small keyframes after 3330–3410s resulting in terrible video quality.
Normal:
Once the issue occurs the quality stays like this:
NvMediaIEP bitstream output buffer sizes plotted a bit prior to and after the issue begins:
Note that the the keyframe peaks get significantly smaller and don’t recover.
Reproducer:
#include <dw/core/Context.h>
#include <dw/core/VersionCurrent.h>
#include <dw/sensors/camera/Camera.h>
#include <nvmedia_iep.h>
#include <chrono>
#include <cstdio>
#include <cstdlib>
#include <thread>
constexpr std::uint32_t bitrate{4000000};
std::int32_t main()
	dwContextObject* context;
	dwInitialize(&context, DW_VERSION, nullptr);
	dwSALObject* sal;
	dwSAL_initialize(&sal, context);
	dwSensorObject* camera;
	dwSAL_createSensor(&camera, {.protocol = "camera.gmsl", .parameters = "camera-type=ar0231-rccb-bae-sf3324,camera-group=a,camera-count=1,output-format=yuv,isp-mode=yuv420-uint8"}, sal);
	dwSensor_start(camera);
	dwCameraProperties cam_props;
	dwSensorCamera_getSensorProperties(&cam_props, camera);
	dwImageProperties img_props;
	dwSensorCamera_getImageProperties(&img_props, DW_CAMERA_OUTPUT_NATIVE_PROCESSED, camera);
	NVM_SURF_FMT_DEFINE_ATTR(format_attrs);
	NVM_SURF_FMT_SET_ATTR_YUV(format_attrs, YUV, 420, SEMI_PLANAR, UINT, 8, BL);
	const std::uint32_t iep_format{NvMediaSurfaceFormatGetType(format_attrs, 7)};
	NvMediaDevice* nvmedia{NvMediaDeviceCreate()};
	NvMediaSurfAllocAttr surface_attrs[3]{
			.type = NVM_SURF_ATTR_WIDTH,
			.value = img_props.width,
			.type = NVM_SURF_ATTR_HEIGHT,
			.value = img_props.height,
			.type = NVM_SURF_ATTR_CPU_ACCESS,
			.value = NVM_SURF_ATTR_CPU_ACCESS_CACHED,
	NvMediaImage* block_image{NvMediaImageCreateNew(nvmedia, iep_format, surface_attrs, 3, 0)};
	NvMediaEncodeInitializeParamsH265 enc_params{};
	enc_params.encodeWidth = img_props.width;
	enc_params.encodeHeight = img_props.height;
	enc_params.frameRateNum = 30;
	enc_params.frameRateDen = 1;
	enc_params.profile = NVMEDIA_ENCODE_PROFILE_HIGH;
	enc_params.level = NVMEDIA_ENCODE_LEVEL_AUTOSELECT;
	enc_params.maxNumRefFrames = 1;
	NvMediaIEP* iep{NvMediaIEPCreate(nvmedia, NVMEDIA_IMAGE_ENCODE_HEVC, &enc_params, iep_format, 4, 6, NVMEDIA_ENCODER_INSTANCE_0)};
	NvMediaEncodeConfigH265 configuration{};
	configuration.gopLength = 30;
	configuration.rcParams.rateControlMode = NVMEDIA_ENCODE_PARAMS_RC_CBR;
	configuration.rcParams.params.cbr.averageBitRate = bitrate;
	configuration.repeatSPSPPS = NVMEDIA_ENCODE_SPSPPS_REPEAT_INTRA_FRAMES;
	NvMediaIEPSetConfiguration(iep, &configuration);
	std::uint8_t* buffer{reinterpret_cast<std::uint8_t*>(std::malloc(bitrate * 2))};
	NvMediaBitstreamBuffer bitstream{};
	bitstream.bitstream = buffer;
	bitstream.bitstreamSize = bitrate * 2;
	std::thread receiver_thread{[&]()
		// If everything's well the biggest buffer (the keyframe) is usually at least a fifth of the bitrate.
		const std::uint32_t expected_biggest{bitrate / 8 / 5};
		const std::chrono::steady_clock::time_point beginning{std::chrono::steady_clock::now()};
		std::chrono::steady_clock::time_point prev{std::chrono::steady_clock::now()};
		std::uint32_t biggest{};
		while (true)
			std::uint32_t count;
			NvMediaIEPGetBitsEx(iep, &count, 1, &bitstream, nullptr);
			biggest = std::max(biggest, count);
			const std::chrono::steady_clock::time_point now{std::chrono::steady_clock::now()};
			if (now - prev >= std::chrono::seconds{1})
				prev = now;
				std::printf("%lds %dB%s\n", std::chrono::duration_cast<std::chrono::seconds>(now - beginning).count(), biggest, biggest < expected_biggest ? " bad!" : "");
				biggest = 0;
	while (true)
		dwCameraFrame* frame;
		dwSensorCamera_readFrame(&frame, 0, 1000000, camera);
		dwImageObject* image;
		dwSensorCamera_getImage(&image, DW_CAMERA_OUTPUT_NATIVE_PROCESSED, frame);
		dwImageNvMedia* nvmedia;
		dwImage_getNvMedia(&nvmedia, image);
		NvMediaImageSurfaceMap map, block_map;
		NvMediaImageLock(nvmedia->img, NVMEDIA_IMAGE_ACCESS_READ, &map);
		NvMediaImageLock(block_image, NVMEDIA_IMAGE_ACCESS_WRITE, &block_map);
		void* planes[]{map.surface[0].mapping, map.surface[1].mapping, map.surface[2].mapping};
		std::uint32_t pitches[]{map.surface[0].pitch, map.surface[1].pitch, map.surface[2].pitch};
		NvMediaImagePutBits(block_image, nullptr, planes, pitches);
		NvMediaImageUnlock(nvmedia->img);
		NvMediaImageUnlock(block_image);
		dwSensorCamera_returnFrame(&frame);
		NvMediaEncodePicParamsH265 config{};
		NvMediaIEPFeedFrame(iep, block_image, nullptr, &config, NVMEDIA_ENCODER_INSTANCE_AUTO);
The code can be compiled as a DriveWorks sample. Requires a SF3324 attached to group A port 1 to be ran.
The reproducer will print the biggest bitstream buffer received from NvMediaIEP every second.
The GOP length is set to 30 frames so there will be a keyframe per second.
The keyframes are usually at least 1/5th the bitrate. If this condition is not met the logged message will contain the text “bad”.
After 3330–3410s the size of the biggest buffer for every second drops dramatically and never recovers. Be patient as the time it takes for the issue to begin varies a bit.
This beginning of the issue coincides with a dramatical drop in video quality in our real-world application.
The symptoms are as if no more keyframes are produced.
Notably the average bitrate is still met, just the keyframes seem to be very small (and rest bigger to compensate) and as a result the resulting quality of the video is a mush.
This seems like a bug in NvMediaIEP. We’ve worked around this by recreating the encoder every 3330s (the shortest time we’ve seen for the issue to occur), but that’s obviously not an ideal solution.
Could this issue be looked into and advice be provided on how to to configure NvMediaIEP such that this doesn’t occur?
Hi @raul.tambre.clevon,
Thank you for the detailed information! We will check with the team and get back to you here.
We tried to simulate your application with our application.
Ran it for almost 2 hours but still cannot reproduce the issue.
May I know if it only happens for a particular content or content agnostic?
I believe it’s content agnostic, but much easier to notice with a higher baseline keyframe size.
Thus I would advise having the camera look at something “interesting” to make the issue more noticeable, i.e. not a blank wall or a cardboard box. A baseline of the keyframe being at least >40’000B would be very good.
Do I understand correctly you didn’t try with the minimal example code I posted? Please try with that.
I tested again am still able to reproduce this.
I’ve improved the sample with SIGINT handling, logging all bitstream buffer sizes to /var/log/nvm_repro.log and printing the real bitrate for your convenience:
#include <chrono>
#include <cstdio>
#include <cstdlib>
#include <fstream>
#include <thread>
#include <signal.h>
constexpr std::uint32_t bitrate{4'000'000}; // 4 Mbit/s
bool running{true};
void sigint(std::int32_t)
	running = false;
std::int32_t main()
	struct sigaction action{};
	action.sa_handler = &sigint;
	sigaction(SIGINT, &action, nullptr);
	dwSALObject* sal;
		std::uint32_t bytes{};
		std::ofstream data{"/var/log/nvm_repro.log", std::ios_base::out | std::ios_base::trunc};
		while (running)
			bytes += count;
			data << count << "\n";
				prev = now;
				std::printf("%lds %dB %dB/s\n", std::chrono::duration_cast<std::chrono::seconds>(now - beginning).count(), biggest, bytes);
				biggest = 0;
				bytes = 0;
	while (running)
	receiver_thread.join();
Pre-compiled: nvm_repro.tar.gz (252.4 KB)
Logs from an example run:
stdout.txt (120.7 KB)
nvm_repro.log (967.3 KB)
Graphs based on those logs:
I believe the buffer size scatter plot demonstrates the degradation pretty well.
Do let me know if you need any assistance in reproducing the issue, I’d be happy to help.
Sorry for missing this topic.
Due to the pandemic, could you try if this issue is reproducible with any files under /usr/local/driveworks/data/samples/recordings/?
BTW, DRIVE OS 5.2.0 and DriveWorks 3.5 will be released this month, so we will try on it. Thanks!
I’m afraid not. The issue takes over 3300s to manifest and none of the videos are nearly long enough.
Is simply attaching a camera and reproducing in my described manner not possible? I could probably record a long video and share that to help reproduce the issue if you so wish.
Currently my devkit is set up in house. I don’t know how to keep keyframes at least >40’000B for a long period to reproduce this issue. If the issue is reproducible by playing back a video repeatly, that will be easier.
Here’s an updated repro that uses /usr/local/driveworks/data/samples/recordings/suburb0/video_0_roof_front_120_short.h264 to reproduce the issue:
#include <chrono>
#include <cstdio>
#include <cstdlib>
#include <fstream>
#include <thread>
#include <signal.h>
bool running{true};
	running = false;
std::int32_t main()
	dwSALObject* sal;
	dwSAL_createSensor(&camera, {.protocol = "camera.virtual", .parameters = "video=/usr/local/driveworks/data/samples/recordings/suburb0/video_0_roof_front_120_short.h264,output-format=processed"}, sal);
	dwSensor_createSeekTable(camera);
		while (running)
			bytes += count;
				prev = now;
				biggest = 0;
				bytes = 0;
	while (running)
		if (dwSensorCamera_readFrame(&frame, 0, 1000000, camera) == DW_END_OF_STREAM)
			dwSensor_seekToTime(0, camera);
			continue;
Scatter plot of the sample run:
Since the virtual playback isn’t throttled I’ve discovered that the problems is actually correlated with the number of frames encoded not the encoding time.
Note from the plot that the problem appears right at the 100’000 frame mark, which correlates very well with my initial 3333s figure due to 30fps. The later variations can probably then be chalked up to dropped/skipped frames from using a real camera.
The vertical “pylons” in the graph are probably from the video beginning again as the reproducer plays it back in a loop.
Let me know if you need any other information or help building/running the reproducer.
I tried it on DRIVE OS 5.2.0 and got below output messages. It looks normal, right?
May I know how much time it takes to reproduce the issue? Thanks!
1s 39874B 1877747153B/s
2s 39892B -706215346B/s
3s 35396B -1605423129B/s
4s 35573B -609415273B/s
5s 36440B -1872204510B/s
6s 38073B 2062236515B/s
7s 40661B 1630132632B/s
8s 43765B 775764813B/s
9s 42520B -2083994560B/s
10s 42097B -513303033B/s
11s 38907B 243411641B/s
12s 31180B 576999467B/s
13s 30105B -1944881222B/s
14s 27255B -2142542457B/s
15s 36636B -777319558B/s
16s 37665B -1880001888B/s
17s 45506B -817840207B/s
18s 45369B 60892774B/s
19s 36010B 143202661B/s
20s 48171B 1555081527B/s
21s 43562B 1751034377B/s
22s 39717B -1448923637B/s
23s 46995B -1528321478B/s
24s 48229B 1461689322B/s
25s 48838B 1391181849B/s
26s 51465B 1874964117B/s
27s 36463B 1818571588B/s
28s 37544B -1144747437B/s
29s 36413B 1044632023B/s
30s 40401B 1808732121B/s
31s 43709B -1486100990B/s
32s 40423B -44271869B/s
33s 39262B -1690592508B/s
34s 43387B 1424007535B/s
35s 50072B 1563087027B/s
36s 48042B -1720119038B/s
37s 40428B 1843611991B/s
38s 42681B 778556474B/s
39s 34608B 331662192B/s
40s 37218B -1707037351B/s
41s 33318B 1424839621B/s
42s 35187B 55407912B/s
43s 38586B 581462001B/s
44s 47447B -1020823453B/s
45s 49117B -1042313061B/s
46s 49351B -88225835B/s
47s 50433B 1743462950B/s
48s 51602B 140577196B/s
49s 55872B -647100827B/s
50s 58834B -533622419B/s
51s 55056B 1338993714B/s
52s 43935B 20946263B/s
53s 44742B 844290941B/s
54s 43057B -529862529B/s
55s 43403B 13406909B/s
56s 44333B 252396593B/s
57s 41715B 1616426683B/s
58s 40139B 1318990057B/s
59s 39569B -1966823046B/s
60s 40462B 1274174440B/s
61s 41731B -1026471107B/s
62s 40476B 704143161B/s
63s 44903B 1071885186B/s
64s 44147B 1332147680B/s
65s 45280B -1550108496B/s
66s 36572B -500967663B/s
67s 52622B 1087010172B/s
68s 111625B 2051749925B/s
69s 112528B 2061440313B/s
70s 119250B 1450839374B/s
71s 113964B 359359821B/s
72s 101666B -602433585B/s
73s 115947B -1490517887B/s
74s 117482B -61024496B/s
75s 116096B 479404451B/s
76s 103330B -303525526B/s
77s 105544B 461062090B/s
78s 104165B -1301708711B/s
79s 115396B 2040552040B/s
80s 103624B -647740715B/s
81s 117688B 853810610B/s
82s 113348B 2021914697B/s
83s 112130B 1279689457B/s
84s 103479B -723819081B/s
85s 104627B 585654042B/s
86s 52673B -949290270B/s
87s 39820B 1087902329B/s
88s 38013B -1750586034B/s
89s 34552B 1084087490B/s
90s 34571B -320309202B/s
91s 37149B -282187111B/s
92s 41438B -705084881B/s
93s 42876B 1284104191B/s
94s 43762B -1076636201B/s
95s 41981B -1912920873B/s
96s 31868B -201068027B/s
97s 28913B 565470B/s
98s 29406B -792376759B/s
99s 27915B -56562811B/s
100s 36402B 1112600755B/s
101s 44081B -209913507B/s
102s 46018B -413773282B/s
103s 47044B -410433579B/s
104s 35470B 1418091755B/s
105s 45885B 1027714863B/s
106s 47026B 1469156160B/s
107s 39474B -1306781564B/s
108s 43103B 162836961B/s
109s 48297B 1534295652B/s
110s 51071B -1179962418B/s
111s 47922B -2099301634B/s
112s 36724B 1512567859B/s
113s 40022B -1968055193B/s
114s 39136B 1480106040B/s
115s 40617B 1475016809B/s
116s 42015B -1449540648B/s
117s 38405B 1653071795B/s
118s 37590B -1587068676B/s
119s 43095B 1946771010B/s
120s 48383B 1443359787B/s
121s 48073B -1638223737B/s
122s 39823B -1413704871B/s
123s 47375B 1103582173B/s
124s 33272B -328812196B/s
125s 41390B -799296791B/s
126s 33869B 1796165210B/s
127s 34988B 1127474448B/s
128s 37666B 1143990986B/s
129s 45068B -1175451126B/s
130s 52512B 1451170576B/s
131s 52022B -1605670295B/s
132s 53727B 1364898550B/s
133s 53880B 699391059B/s
134s 55714B 143291941B/s
135s 57844B -562648301B/s
136s 56566B -1267144443B/s
137s 39214B 127334767B/s
138s 39573B 434198673B/s
139s 43426B 559044661B/s
140s 43323B -403426427B/s
141s 41324B 1555521088B/s
142s 42620B -1394963010B/s
143s 39237B -246365826B/s
144s 39631B 466302510B/s
145s 40843B 1773322489B/s
146s 43375B -1302565606B/s
147s 45724B 1908982250B/s
148s 41049B -1795594252B/s
149s 43676B -1832543533B/s
150s 43842B -2117658671B/s
151s 41940B 669862917B/s
152s 71570B 622660099B/s
153s 101672B -1242185774B/s
154s 114924B 1412639585B/s
155s 112483B -533901071B/s
156s 124227B -1386985455B/s
157s 106293B 1473434505B/s
158s 112663B -428140224B/s
159s 113692B -852880180B/s
160s 104922B 577459408B/s
161s 119044B -396636803B/s
162s 103090B 498398746B/s
163s 102599B -1094873720B/s
164s 103264B 1360611948B/s
165s 117240B -1902780000B/s
166s 124016B 542063468B/s
167s 113491B -2059013006B/s
168s 114862B -2123960237B/s
169s 112885B 1831193858B/s
170s 113891B 1854590393B/s
171s 36589B 211503027B/s
172s 40986B 691866374B/s
173s 34968B -2078179793B/s
174s 36537B -489044696B/s
175s 38073B 562808816B/s
176s 40912B -823460101B/s
177s 39797B -1603642188B/s
178s 47114B 1528475396B/s
179s 42131B -2055882830B/s
180s 40620B 1558469421B/s
181s 34668B -1070518458B/s
182s 32355B 180038323B/s
183s 32784B 1569181934B/s
184s 27418B 977971622B/s
185s 35699B -1755581406B/s
186s 40335B -1566897419B/s
187s 45286B 966496465B/s
188s 50324B -1467753609B/s
189s 43599B 972170796B/s
190s 45851B 1962038132B/s
191s 44980B -269312580B/s
192s 36690B 1283343052B/s
193s 47770B 1299156171B/s
194s 49048B 948742328B/s
195s 51857B -1842369500B/s
196s 48466B 1073849784B/s
197s 37445B -1406191304B/s
198s 41537B -506811367B/s
199s 42933B -128905465B/s
200s 40748B 929804164B/s
201s 40163B -1276108326B/s
202s 40790B 787789480B/s
203s 37745B 1519393249B/s
204s 43871B -1053840503B/s
205s 48137B -1150212644B/s
206s 42076B 1680141393B/s
207s 39459B -671299701B/s
208s 45960B 610493069B/s
209s 35540B -1124961744B/s
210s 37097B 95524213B/s
211s 32908B -455881633B/s
212s 36478B 535844985B/s
^[[5~213s 37680B -1077458639B/s
^[[5~^[[5~^[[5~214s 48377B -1228744315B/s
^[[5~215s 48696B -1109127848B/s
216s 53748B -717210807B/s
217s 51133B 226127664B/s
218s 51889B -938028811B/s
219s 58744B 1147524955B/s
220s 63374B 1684255577B/s
221s 44615B 1809292261B/s
222s 39773B -2059523638B/s
223s 44146B -1456822923B/s
224s 43603B -946975426B/s
225s 42707B 1366835680B/s
226s 38580B -899696986B/s
227s 43615B -141566014B/s
228s 43712B -1132452544B/s
229s 40383B -1450700371B/s
230s 44490B -2563041B/s
231s 42522B -37239610B/s
232s 43859B -94243231B/s
233s 45647B 1197738244B/s
234s 44271B -1856581245B/s
235s 42707B 692718304B/s
236s 38223B -1388026277B/s
237s 66086B 1891703905B/s
238s 98799B -1490024932B/s
239s 114346B 1692794703B/s
240s 113690B -790608193B/s
241s 113992B 1086481163B/s
242s 115133B -1561267392B/s
243s 114018B 937729379B/s
244s 107023B 2147194824B/s
245s 113191B 1543601861B/s
246s 114697B -969264090B/s
247s 103928B 723469657B/s
248s 104914B -887054489B/s
249s 120428B 1693406347B/s
250s 112720B 1866068850B/s
251s 113640B -875200349B/s
252s 118263B -1880592440B/s
253s 111964B 2031520620B/s
254s 101992B 432134871B/s
255s 113172B -1762497303B/s
256s 37073B -1212086792B/s
257s 42394B 658475307B/s
258s 35227B -441801713B/s
259s 34687B 20225766B/s
260s 38242B -1676028366B/s
261s 38984B 438519341B/s
262s 36726B 1393838136B/s
263s 47258B -1000731794B/s
264s 44193B -182067801B/s
265s 38656B -1807006143B/s
266s 30915B -1247241999B/s
267s 36241B 1405474877B/s
268s 28485B 1533741676B/s
269s 35508B -254391239B/s
270s 38246B 217589367B/s
271s 46435B -399937704B/s
272s 44988B 1089721454B/s
273s 47963B -295413321B/s
274s 45856B 547789467B/s
275s 44825B 2044920251B/s
276s 40595B -1057771329B/s
277s 35881B 1968163235B/s
278s 48435B -682471467B/s
279s 48357B -60583663B/s
280s 51241B -1722229296B/s
281s 48492B 1822303735B/s
282s 36954B 675988486B/s
283s 38533B -1032009417B/s
284s 38435B 1332783347B/s
285s 41195B -1181661374B/s
286s 42084B -287017024B/s
287s 41442B -1623530831B/s
288s 44131B 1308030059B/s
289s 45869B -1356481104B/s
290s 47457B -1574589302B/s
291s 40243B -1062476670B/s
292s 40126B 1617237225B/s
293s 48829B -181023818B/s
294s 34081B -961185816B/s
295s 40298B 292380693B/s
296s 35622B -259041994B/s
297s 37335B 717410101B/s
298s 38592B -1819084080B/s
299s 48011B -2078822802B/s
300s 50203B 1248911412B/s
301s 48205B -1062676881B/s
302s 51510B 1671576613B/s
303s 48368B 931621883B/s
304s 57488B 586155871B/s
305s 62496B -266301046B/s
306s 39725B -1974705181B/s
307s 42529B -1490002014B/s
308s 43546B -587625197B/s
309s 43293B 956905540B/s
310s 39010B 744788301B/s
311s 38832B -133110728B/s
312s 35897B -914925798B/s
313s 44959B -392725683B/s
314s 42458B 663209775B/s
315s 39635B -2136826277B/s
316s 45654B -344379655B/s
317s 45563B 839455981B/s
318s 40729B -2143187417B/s
319s 46789B -80230557B/s
320s 42178B -1003128557B/s
321s 53392B 1277017959B/s
322s 79137B -1994336004B/s
323s 100774B -1143510009B/s
324s 112924B -1013208597B/s
325s 124929B 721128009B/s
326s 124929B -2144280166B/s
327s 112832B -1346911490B/s
328s 103514B 252839521B/s
329s 132589B 297759593B/s
330s 124381B -58387916B/s
331s 105858B 739817521B/s
332s 108091B -1268239340B/s
333s 113144B -911002824B/s
334s 114409B -667704308B/s
335s 111744B -677399877B/s
336s 116849B -1404925120B/s
337s 113129B -1654075509B/s
338s 102314B -1994925098B/s
339s 104180B 236743103B/s
340s 96538B 79086379B/s
341s 38250B -1200854133B/s
342s 37190B 1213424249B/s
343s 35940B -2056740273B/s
344s 32878B 215997709B/s
345s 39389B 807598302B/s
346s 40744B -236507527B/s
347s 46203B 672674541B/s
348s 43471B 2095817825B/s
349s 40043B -1685104047B/s
350s 36159B 1415813314B/s
351s 32424B 1165658410B/s
352s 32843B 657615929B/s
353s 30244B -798573384B/s
354s 32279B -1913131325B/s
355s 36107B 225643931B/s
356s 46217B 45378164B/s
357s 49229B 2107193567B/s
358s 35720B 1244581435B/s
359s 49265B 1316799003B/s
360s 47574B 110918252B/s
361s 41163B -1882754896B/s
362s 42606B 1745815659B/s
363s 47976B -2104332383B/s
364s 49101B 679751483B/s
365s 50676B 772488549B/s
366s 51889B -87828459B/s
367s 37535B 776909585B/s
368s 40403B -627673582B/s
369s 41190B 1777954251B/s
370s 38884B 1769031027B/s
371s 40549B -788971136B/s
372s 37120B 1441960606B/s
373s 44004B 880497645B/s
374s 49102B 1631900164B/s
375s 47365B 1534528507B/s
376s 41568B -593678309B/s
377s 39355B 415757250B/s
378s 44023B 578349587B/s
379s 39693B -2025406685B/s
380s 38256B 294460516B/s
381s 35040B 264706352B/s
382s 37370B 1406728295B/s
383s 39982B -1958917450B/s
384s 50319B 1774614196B/s
385s 49487B -1494051818B/s
386s 48031B 1524566831B/s
387s 58182B 1290500232B/s
388s 56484B -1175069321B/s
389s 57152B -1971720428B/s
390s 60505B 1357623934B/s
391s 42327B -188399853B/s
392s 42327B 1188767596B/s
393s 40543B 1645520968B/s
394s 43080B 2037628835B/s
395s 39930B -1182502034B/s
396s 41763B 879734488B/s
397s 41554B 1306025813B/s
398s 40923B 832125273B/s
399s 39888B -415583703B/s
400s 41208B 422819505B/s
401s 45051B 675056442B/s
402s 44195B 1580478533B/s
403s 42269B 20677623B/s
404s 46829B -1343723987B/s
405s 42423B 338029751B/s
406s 51380B -430849776B/s
407s 79349B -2112937505B/s
408s 114829B -39643369B/s
409s 113619B -1774427246B/s
410s 122802B 1343557721B/s
411s 115586B 1465141931B/s
412s 116903B -1465657462B/s
413s 116903B -1881986358B/s
414s 102630B -417886206B/s
415s 102829B -1804563617B/s
416s 105984B -406208261B/s
417s 104584B 1822382525B/s
418s 124887B 466876033B/s
419s 102790B 751749444B/s
420s 129642B -755082227B/s
421s 113464B -951777036B/s
422s 111123B -610695350B/s
423s 119821B -1383578789B/s
424s 112193B -626729186B/s
425s 57327B -665854304B/s
426s 41111B 1044179218B/s
427s 40039B 1825676264B/s
428s 38828B -327261636B/s
429s 37586B 1712846407B/s
430s 37637B 191193221B/s
431s 43344B 1118076668B/s
432s 45333B -669908526B/s
433s 43978B -1841824855B/s
434s 40420B -1762668079B/s
435s 36450B 384991883B/s
436s 31122B -1917498105B/s
437s 30937B -1489772239B/s
438s 28081B -577044557B/s
439s 34618B -280224469B/s
440s 37068B -881922469B/s
441s 46463B -1771690203B/s
442s 48910B 1360272243B/s
443s 42745B -525440702B/s
444s 48713B 1927823925B/s
445s 44095B 1614130704B/s
446s 37048B -1692355120B/s
447s 38093B -856693241B/s
448s 50460B 1637622269B/s
449s 51220B 1894304116B/s
450s 50418B -363267074B/s
451s 39193B -35091022B/s
452s 36344B -1206221048B/s
453s 38908B 101744273B/s
454s 41688B 1559718290B/s
455s 39985B 567995090B/s
456s 38826B 1528961474B/s
457s 36461B 202771124B/s
458s 43048B 699119327B/s
459s 47790B -665457883B/s
460s 46594B -84821147B/s
461s 39343B -1757954310B/s
462s 46062B -1037104083B/s
463s 36524B 504218870B/s
464s 38962B 265265854B/s
465s 35963B -695193899B/s
466s 36000B 80003856B/s
467s 34302B 1412328596B/s
468s 39789B 715450781B/s
469s 50413B 137753198B/s
470s 44275B 1827151825B/s
471s 55437B -184889831B/s
472s 49217B -1981557137B/s
473s 50663B -387901081B/s
474s 62922B -839322008B/s
475s 52524B -212870586B/s
476s 41090B -1008353072B/s
477s 38440B 1429626719B/s
478s 42812B 1675264010B/s
479s 43094B -1209840643B/s
480s 44166B -461662919B/s
481s 43150B -916608327B/s
482s 43836B -1942525532B/s
483s 35938B 2002880575B/s
484s 39861B -666777302B/s
485s 45320B 463121571B/s
486s 47283B -1330454916B/s
487s 43737B 511647081B/s
488s 42806B -912344042B/s
489s 45806B -373625022B/s
490s 36907B 1146672163B/s
491s 65722B 2004435959B/s
492s 99232B 1811536613B/s
493s 112244B 368908647B/s
494s 113846B -3790227B/s
495s 112756B 820803977B/s
496s 121457B -217010831B/s
497s 114858B -2143730039B/s
498s 114173B 1327964961B/s
499s 114649B 437623114B/s
500s 119066B -980018860B/s
501s 104948B -739954357B/s
502s 103105B 1306082156B/s
503s 117274B 664115166B/s
504s 130966B 539777657B/s
505s 112556B -1271999658B/s
506s 113157B -2076001945B/s
507s 118095B -1323438765B/s
508s 103134B -1123408274B/s
509s 112922B -1265349463B/s
510s 56466B 145321888B/s
511s 41956B 1762728923B/s
512s 37993B 2095913609B/s
513s 36874B -1258104108B/s
514s 36730B 238305518B/s
515s 38747B 951708258B/s
516s 45419B -1202103785B/s
517s 48326B -1848917880B/s
518s 40457B -612592159B/s
519s 43356B 1844150734B/s
520s 34331B -684830946B/s
521s 30607B 1461566319B/s
522s 30904B 1534613435B/s
523s 29356B -1860289201B/s
524s 32710B 2085519791B/s
525s 37671B -738758840B/s
526s 46807B 795958219B/s
527s 49194B -1677858423B/s
528s 39046B -55805878B/s
529s 53456B 401506357B/s
530s 48118B 1160791856B/s
531s 45357B 1250589679B/s
532s 47599B 17101720B/s
533s 45451B 1098399806B/s
534s 49886B -1123301797B/s
535s 50807B 1999952892B/s
536s 37693B 1668843365B/s
537s 37660B 1547539891B/s
538s 37808B -67256733B/s
539s 42453B -1507026696B/s
540s 46908B 1240080843B/s
541s 43647B 1762514075B/s
542s 40848B 982354698B/s
543s 43594B 456663485B/s
544s 47903B 712718538B/s
545s 49825B -935081374B/s
546s 40108B 28825793B/s
547s 44313B -1429883180B/s
548s 33488B -501741470B/s
549s 37292B -954259051B/s
550s 34892B 1425188455B/s
551s 36329B 1545315106B/s
552s 37652B -680584636B/s
553s 46270B 998286056B/s
554s 49560B -1309944086B/s
555s 50018B -451163731B/s
556s 49128B -1689949234B/s
557s 52997B 525907055B/s
558s 58277B 303797621B/s
559s 59840B -659805538B/s
560s 50638B -2016595617B/s
561s 39501B 261221542B/s
562s 36358B -857407635B/s
563s 43365B 1909081918B/s
564s 42564B 474550450B/s
565s 42962B -159711235B/s
566s 39348B 2020042956B/s
567s 38725B -17809177B/s
568s 40863B -57568589B/s
569s 41012B -2140468535B/s
570s 40265B 1933677112B/s
571s 40883B 1720963517B/s
572s 42628B -1691149793B/s
573s 44253B 1320134282B/s
574s 43423B 613265768B/s
575s 39043B 388677053B/s
576s 73894B -2033412736B/s
577s 113355B 1912136700B/s
578s 125130B 884117746B/s
579s 113813B 329854855B/s
580s 120197B 2082941935B/s
581s 113394B 50162710B/s
582s 113827B 68991118B/s
583s 104017B -862977990B/s
584s 127338B -1222788461B/s
585s 103800B 1340637791B/s
586s 103623B -854674955B/s
587s 105503B -534697463B/s
588s 125467B 209358238B/s
589s 113140B 2083959563B/s
590s 124723B 1126251117B/s
591s 116558B -1982338442B/s
592s 114297B 1125470483B/s
593s 114297B -1689249565B/s
594s 105275B -1816419957B/s
595s 44099B -1307597666B/s
596s 39586B 2015194254B/s
597s 36709B -1860109803B/s
598s 34378B 2074648532B/s
599s 36826B 1496631211B/s
600s 41642B 1374814679B/s
601s 47093B -1786415405B/s
602s 45065B 864941806B/s
603s 42932B -1906120098B/s
604s 39964B -764958899B/s
605s 33428B 2136766584B/s
606s 32150B 968408613B/s
607s 29440B 1741224588B/s
608s 29322B 510081006B/s
609s 35552B 1745705837B/s
610s 44667B -491618551B/s
611s 44930B 1867306790B/s
612s 49331B 2001378005B/s
613s 48372B 132496388B/s
614s 48372B 1993562893B/s
615s 41828B 989540328B/s
616s 41791B 202405127B/s
617s 47662B -498859135B/s
618s 48679B 480887997B/s
619s 49112B 1256458338B/s
620s 50029B 176248797B/s
621s 36103B -810527912B/s
622s 37472B -1953747070B/s
623s 38803B -1201439019B/s
624s 40779B -1913635253B/s
625s 39930B -1398052835B/s
626s 40245B -1427793923B/s
627s 42125B -912637532B/s
628s 45662B 1987103873B/s
629s 46581B -1253364309B/s
630s 45575B 1904292175B/s
631s 37119B 1935426422B/s
632s 41630B 388865012B/s
633s 35042B -500869194B/s
634s 37632B 1650228186B/s
635s 36122B 1098408429B/s
636s 37246B -606316260B/s
637s 38613B -1095743035B/s
638s 46388B 679026168B/s
639s 49818B -244704013B/s
q640s 49512B -316373773B/s
641s 52880B 260666507B/s
642s 51191B 136209626B/s
643s 56242B 1370225930B/s
644s 59056B -1523626668B/s
645s 55778B 1400917720B/s
646s 40624B 536125867B/s
647s 40834B -469562239B/s
648s 43093B -1398590129B/s
649s 42911B -52390017B/s
650s 41992B -1018364223B/s
651s 41352B 620804892B/s
652s 40202B -858415625B/s
653s 40097B -1742780260B/s
654s 43205B -1919915982B/s
655s 41330B -623344854B/s
656s 43621B -320707856B/s
657s 42212B 1666694816B/s
658s 44202B -1373019109B/s
659s 43006B -30894016B/s
660s 47337B 251789936B/s
661s 71424B -1078475002B/s
662s 112030B 1520980576B/s
663s 112285B -1685258957B/s
664s 111511B 1646430516B/s
665s 101627B 720276808B/s
666s 101779B 1387434154B/s
667s 114972B -754053787B/s
668s 117333B -1457571268B/s
669s 104336B -668429020B/s
670s 103164B 2074923559B/s
671s 118979B 1407731491B/s
672s 102451B 257496756B/s
673s 113802B -963109054B/s
674s 113878B 738849030B/s
675s 118046B 161359686B/s
676s 123037B 1712962511B/s
677s 123580B 246170178B/s
678s 102165B -1832347845B/s
679s 107993B -1362599819B/s
680s 39713B -1969451636B/s
681s 40121B 2024271087B/s
682s 36587B 351129070B/s
683s 34304B -1995069191B/s
684s 37164B -1006585143B/s
685s 37905B 2010528803B/s
686s 40421B 1615983613B/s
687s 49057B 1885763367B/s
688s 42143B 261548645B/s
689s 38463B 175713795B/s
690s 31426B -1582360881B/s
691s 29325B 1809870773B/s
692s 27220B -1975973195B/s
693s 26864B -183713777B/s
694s 36232B 470389942B/s
695s 44058B -1652688622B/s
696s 46135B 193635614B/s
697s 36672B 480756879B/s
698s 47793B -646307167B/s
699s 47130B -1969972021B/s
700s 42545B -1537604162B/s
701s 42443B -1930543055B/s
702s 46673B 160008044B/s
703s 48750B 1056663668B/s
704s 54398B 594085048B/s
705s 48033B -273857280B/s
706s 40943B -1151743469B/s
707s 37558B 1099282192B/s
708s 41411B -350930435B/s
709s 39436B -1147200950B/s
710s 42381B -732018012B/s
711s 40743B -1613917824B/s
712s 42941B 1046958512B/s
713s 44125B -1654404441B/s
714s 49542B 1600161928B/s
715s 45644B 1822645974B/s
716s 38802B 1804489126B/s
717s 44019B -576187546B/s
718s 35371B -1588680609B/s
719s 37853B 601818385B/s
720s 34007B -1019828231B/s
721s 34967B 1316009721B/s
722s 39131B 1885911271B/s
723s 42793B -1857616596B/s
724s 49122B 572977865B/s
725s 51758B 1574910427B/s
726s 54749B 759195613B/s
727s 52330B -313201743B/s
728s 57465B -77052504B/s
729s 58028B 133580239B/s
730s 42849B -562176498B/s
731s 39096B 978903573B/s
732s 44356B 2139590457B/s
733s 44211B -2014654492B/s
734s 39798B -2143744297B/s
735s 41380B 1579898690B/s
736s 37603B -1464861563B/s
737s 41214B 660133939B/s
738s 40835B 117067342B/s
739s 43394B 547588788B/s
740s 42294B 49715242B/s
741s 43131B -1889853206B/s
742s 42780B 1030871051B/s
743s 44334B -1721546923B/s
744s 43162B 586094932B/s
745s 37798B -189110203B/s
746s 97576B 1784242096B/s
747s 112570B -413176484B/s
748s 127264B 613478196B/s
749s 113862B 766520466B/s
750s 125353B 622462354B/s
751s 144698B 847407334B/s
752s 114369B 434093335B/s
753s 114169B 632895156B/s
754s 114308B -391865283B/s
755s 109026B -2054963194B/s
756s 103626B -456201658B/s
757s 114103B -1129009788B/s
The log doesn’t look correct.
We’re still using and testing with DRIVE SW 10, but I’ll setup a temporary machine with DRIVE OS 5.2.0 + DriveWorks 3.5 and will report back.
Seems the reproducer didn’t work properly due to a few API changes in newer releases.
Here’s an updated version:
#include <chrono>
#include <cstdio>
#include <cstdlib>
#include <fstream>
#include <thread>
#include <signal.h>
// Issue begins after 100k frames.
// 20k extra for the problem to be obvious from the data.
constexpr std::uint32_t expected_frames{120'000};
bool running{true};
	running = false;
std::int32_t main()
	dwSALObject* sal;
		std::uint32_t frames{};
		while (running)
			while (NvMediaIEPBitsAvailable(iep, &count, NVMEDIA_ENCODE_BLOCKING_TYPE_IF_PENDING, NVMEDIA_VIDEO_ENCODER_TIMEOUT_INFINITE) == NVMEDIA_STATUS_NONE_PENDING)
			bytes += count;
			frames++;
				prev = now;
				const std::uint32_t percentage{static_cast<std::uint32_t>((static_cast<float>(frames) / expected_frames) * 100.f)};
				std::printf("%04lds %05uB %07uB/s %03u%%\n", std::chrono::duration_cast<std::chrono::seconds>(now - beginning).count(), biggest, bytes, percentage);
				biggest = 0;
				bytes = 0;
			if (frames > expected_frames)
				running = false;
	while (running)
		if (dwSensorCamera_readFrameNew(&frame, 1000000, camera) == DW_END_OF_STREAM)
			continue;
		NvMediaIEPFeedFrame(iep, block_image, nullptr, &config, NVMEDIA_ENCODER_INSTANCE_0);
I’ve added a fourth column that’s the percentage of the frames encoded required for the problem to manifest and be evident from the logged data. The new reproducer exits once it reaches 100%. For me it takes about 1800s (30 minutes).
Please give it another try and let me know if you encounter any issues.
I got below printout messages. From 1558s, it got biggest size per second about 2x KB.
I guess this is also what you observed, right?
I would check it internally and then get back to you. Thanks!
0001s 39874B 1082019B/s 000%
0002s 39892B 1224180B/s 000%
0003s 35396B 1266105B/s 000%
0004s 35714B 1331714B/s 000%
0005s 38073B 1229827B/s 000%
0006s 38079B 1280083B/s 000%
0007s 43765B 1215676B/s 000%
0008s 42520B 1235276B/s 000%
0009s 42097B 1401705B/s 000%
0010s 31912B 1340585B/s 000%
0011s 31180B 1324102B/s 000%
0012s 30105B 1209932B/s 000%
0013s 36636B 0909186B/s 000%
0014s 37665B 1064951B/s 000%
0015s 45506B 1181576B/s 000%
0016s 45369B 1223524B/s 000%
0017s 48171B 1266061B/s 001%
0018s 43562B 1224988B/s 001%
0019s 41553B 1361876B/s 001%
0020s 38565B 1262363B/s 001%
0021s 48229B 1219971B/s 001%
0022s 48838B 1242480B/s 001%
0023s 51465B 1442226B/s 001%
0024s 36463B 1333620B/s 001%
0025s 37544B 1267728B/s 001%
0026s 38810B 1123520B/s 001%
0027s 43173B 1227856B/s 001%
0028s 43709B 1387130B/s 001%
0029s 39262B 1352461B/s 001%
0030s 43387B 1238274B/s 001%
0031s 50072B 1319884B/s 001%
0032s 45653B 1275610B/s 001%
0033s 42681B 1087820B/s 002%
0034s 40957B 1338422B/s 002%
0035s 37218B 1136674B/s 002%
0036s 33318B 1346071B/s 002%
0037s 35187B 1208562B/s 002%
0038s 38586B 1108493B/s 002%
0039s 47599B 1102073B/s 002%
0040s 49351B 1202584B/s 002%
0041s 50433B 1235064B/s 002%
0042s 51602B 1380437B/s 002%
0043s 55872B 1146099B/s 002%
0044s 58834B 1302322B/s 002%
0045s 55056B 1443117B/s 002%
0046s 43935B 1371903B/s 002%
0047s 44742B 1293928B/s 002%
0048s 43403B 1314877B/s 002%
0049s 44333B 1262589B/s 003%
0050s 41715B 1274329B/s 003%
0051s 40139B 1220979B/s 003%
0052s 39569B 1186111B/s 003%
0053s 40462B 1214449B/s 003%
0054s 41731B 1211249B/s 003%
0055s 44903B 1359515B/s 003%
0056s 44147B 1234075B/s 003%
0057s 45280B 1352223B/s 003%
0058s 41293B 1083692B/s 003%
0059s 66375B 1057887B/s 003%
0060s 111625B 1310423B/s 003%
0061s 119250B 1223966B/s 003%
0062s 113964B 1298610B/s 003%
0063s 101666B 1192027B/s 003%
0064s 117482B 1329312B/s 004%
0065s 114055B 1196835B/s 004%
0066s 116096B 1272407B/s 004%
0067s 97007B 1207289B/s 004%
0068s 105544B 1288611B/s 004%
0069s 115396B 1189075B/s 004%
0070s 103624B 1300092B/s 004%
0071s 117688B 1211864B/s 004%
0072s 113348B 1313738B/s 004%
0073s 112130B 1213320B/s 004%
0074s 104627B 1296953B/s 004%
0075s 103341B 1434799B/s 004%
0076s 39820B 1152031B/s 004%
0077s 38013B 1316398B/s 004%
0078s 34552B 1403136B/s 004%
0079s 34571B 1212134B/s 004%
0080s 37908B 1326074B/s 005%
0081s 42876B 1253502B/s 005%
0082s 43762B 1256762B/s 005%
0083s 41981B 1387154B/s 005%
0084s 31868B 1355268B/s 005%
0085s 29406B 1335682B/s 005%
0086s 27915B 1204513B/s 005%
0087s 27258B 0873248B/s 005%
0088s 36402B 1045646B/s 005%
0089s 44118B 1110420B/s 005%
0090s 47044B 1240252B/s 005%
0091s 35470B 1215348B/s 005%
0092s 45885B 1236422B/s 005%
0093s 47026B 1283199B/s 005%
0094s 41876B 1291542B/s 005%
0095s 48297B 1137827B/s 005%
0096s 47568B 1170478B/s 006%
0097s 51071B 1387800B/s 006%
0098s 40629B 1437422B/s 006%
0099s 40022B 1289223B/s 006%
0100s 39136B 1185384B/s 006%
0101s 40617B 1203065B/s 006%
0102s 42015B 1396839B/s 006%
0103s 38405B 1389843B/s 006%
0104s 43095B 1276056B/s 006%
0105s 44549B 1254780B/s 006%
0106s 48383B 1353006B/s 006%
0107s 39823B 1108848B/s 006%
0108s 47375B 1361123B/s 006%
0109s 41390B 1141921B/s 006%
0110s 35592B 1365883B/s 006%
0111s 34988B 1237205B/s 006%
0112s 37666B 1121178B/s 007%
0113s 45068B 1102680B/s 007%
0114s 52512B 1220706B/s 007%
0115s 53727B 1251741B/s 007%
0116s 53880B 1417610B/s 007%
0117s 55714B 1168614B/s 007%
0118s 57844B 1341377B/s 007%
0119s 56566B 1428972B/s 007%
0120s 39214B 1305216B/s 007%
0121s 43426B 1259805B/s 007%
0122s 43323B 1269254B/s 007%
0123s 42420B 1246276B/s 007%
0124s 42620B 1300464B/s 007%
0125s 39237B 1205778B/s 007%
0126s 39631B 1188102B/s 007%
0127s 43375B 1207084B/s 007%
0128s 42648B 1197923B/s 008%
0129s 45724B 1414524B/s 008%
0130s 39223B 1196503B/s 008%
0131s 43842B 1342533B/s 008%
0132s 41940B 1145606B/s 008%
0133s 71570B 1025287B/s 008%
0134s 114924B 1280326B/s 008%
0135s 112483B 1213934B/s 008%
0136s 124227B 1364651B/s 008%
0137s 102732B 1184303B/s 008%
0139s 112663B 1288241B/s 008%
0140s 113692B 1222274B/s 008%
0141s 104922B 1274212B/s 008%
0142s 119044B 1176067B/s 008%
0143s 103090B 1287319B/s 008%
0144s 102604B 1193248B/s 008%
0145s 117240B 1271943B/s 009%
0146s 124016B 1195017B/s 009%
0147s 113491B 1189679B/s 009%
0148s 114862B 1248507B/s 009%
0149s 112885B 1186968B/s 009%
0150s 113891B 1439154B/s 009%
0151s 39699B 1134630B/s 009%
0152s 40986B 1339221B/s 009%
0153s 36537B 1341715B/s 009%
0154s 38073B 1274143B/s 009%
0155s 40912B 1250269B/s 009%
0156s 39840B 1279789B/s 009%
0157s 47114B 1236807B/s 009%
0158s 42131B 1339228B/s 009%
0159s 40620B 1374270B/s 009%
0160s 34668B 1351011B/s 009%
0161s 32784B 1250723B/s 010%
0162s 27815B 1057979B/s 010%
0163s 35699B 0940063B/s 010%
0164s 44296B 1140516B/s 010%
0165s 45680B 1178121B/s 010%
0166s 50324B 1285583B/s 010%
0167s 45493B 1191906B/s 010%
0168s 45851B 1296139B/s 010%
0169s 36690B 1250880B/s 010%
0170s 47770B 1227403B/s 010%
0171s 49048B 1181401B/s 010%
0172s 51857B 1324116B/s 010%
0173s 43942B 1390724B/s 010%
0174s 41537B 1251137B/s 010%
0175s 38090B 1196080B/s 010%
0176s 42933B 1177209B/s 010%
0177s 40163B 1296277B/s 011%
0178s 40790B 1453781B/s 011%
0179s 43399B 1291467B/s 011%
0180s 44008B 1279240B/s 011%
0181s 48137B 1369896B/s 011%
0182s 39459B 1149650B/s 011%
0183s 45960B 1244933B/s 011%
0184s 35540B 1225658B/s 011%
0185s 37097B 1267592B/s 011%
0186s 34509B 1251823B/s 011%
0187s 36478B 1185525B/s 011%
0188s 41635B 1083426B/s 011%
0189s 48377B 1159378B/s 011%
0190s 53748B 1208506B/s 011%
0191s 51133B 1260496B/s 011%
0192s 51889B 1376007B/s 011%
0193s 58744B 1150327B/s 012%
0194s 63374B 1462414B/s 012%
0195s 39773B 1310056B/s 012%
0196s 44146B 1294008B/s 012%
0197s 40637B 1267715B/s 012%
0198s 43603B 1261743B/s 012%
0199s 38580B 1302205B/s 012%
0200s 43615B 1174263B/s 012%
0201s 43712B 1265388B/s 012%
0202s 40926B 1121334B/s 012%
0203s 44490B 1231844B/s 012%
0204s 43859B 1311523B/s 012%
0205s 45647B 1314016B/s 012%
0206s 44271B 1240967B/s 012%
0207s 42707B 1340726B/s 012%
0208s 58241B 0958714B/s 012%
0209s 91685B 1126512B/s 013%
0210s 113815B 1324918B/s 013%
0211s 114346B 1305366B/s 013%
0212s 113992B 1187666B/s 013%
0213s 115133B 1283430B/s 013%
0214s 114018B 1217483B/s 013%
0215s 107755B 1297262B/s 013%
0216s 114697B 1231441B/s 013%
0217s 103928B 1317905B/s 013%
0218s 104914B 1196093B/s 013%
0219s 120428B 1296508B/s 013%
0220s 112720B 1192130B/s 013%
0221s 113640B 1319267B/s 013%
0222s 118263B 1249822B/s 013%
0223s 101992B 1250972B/s 013%
0224s 113172B 1327490B/s 013%
0225s 38186B 1265114B/s 014%
0226s 42394B 1305618B/s 014%
0227s 35227B 1295832B/s 014%
0228s 34687B 1319500B/s 014%
0229s 38242B 1307921B/s 014%
0230s 38984B 1340925B/s 014%
0231s 47258B 1274375B/s 014%
0232s 44193B 1313375B/s 014%
0233s 38656B 1410499B/s 014%
0234s 34420B 1368743B/s 014%
0235s 36241B 1276434B/s 014%
0236s 27209B 1148958B/s 014%
0237s 35508B 0936039B/s 014%
0238s 46435B 1164045B/s 014%
0239s 44988B 1211163B/s 014%
0240s 47963B 1313901B/s 014%
0241s 45856B 1258566B/s 015%
0242s 44825B 1305953B/s 015%
0243s 35881B 1355245B/s 015%
0244s 48435B 1199218B/s 015%
0245s 48357B 1242852B/s 015%
0246s 51241B 1371046B/s 015%
0247s 48492B 1428682B/s 015%
0248s 38533B 1278672B/s 015%
0249s 38435B 1147598B/s 015%
0250s 41195B 1184304B/s 015%
0251s 42084B 1360281B/s 015%
0252s 41442B 1387331B/s 015%
0253s 45869B 1243329B/s 015%
0254s 45004B 1250144B/s 015%
0255s 47457B 1404398B/s 015%
0256s 40126B 1152539B/s 016%
0257s 48829B 1329392B/s 016%
0258s 40298B 1152282B/s 016%
0259s 36133B 1361746B/s 016%
0260s 35622B 1225839B/s 016%
0261s 37504B 1163970B/s 016%
0262s 48011B 1108925B/s 016%
0263s 48173B 1206105B/s 016%
0264s 50203B 1260878B/s 016%
0265s 51510B 1383962B/s 016%
0266s 56091B 1201070B/s 016%
0267s 62496B 1340252B/s 016%
0268s 61274B 1469144B/s 016%
0269s 42529B 1367618B/s 016%
0270s 43546B 1270725B/s 016%
0271s 43293B 1314489B/s 016%
0273s 39010B 1248678B/s 017%
0274s 38832B 1300334B/s 017%
0275s 43187B 1201496B/s 017%
0276s 44959B 1218955B/s 017%
0277s 39635B 1158208B/s 017%
0278s 45654B 1213280B/s 017%
0279s 45563B 1348424B/s 017%
0280s 42338B 1196013B/s 017%
0281s 46789B 1331892B/s 017%
0282s 41198B 1156147B/s 017%
0283s 65223B 1045207B/s 017%
0284s 100774B 1264316B/s 017%
0285s 112924B 1344628B/s 017%
0286s 124929B 1237861B/s 017%
0287s 104365B 1296438B/s 017%
0288s 112832B 1208027B/s 017%
0289s 132589B 1302321B/s 018%
0290s 124381B 1237607B/s 018%
0291s 105858B 1299895B/s 018%
0292s 108091B 1201485B/s 018%
0293s 114409B 1317000B/s 018%
0294s 112961B 1234137B/s 018%
0295s 116849B 1259376B/s 018%
0296s 112201B 1212060B/s 018%
0297s 113129B 1335523B/s 018%
0298s 104180B 1182231B/s 018%
0299s 96538B 1442561B/s 018%
0300s 37190B 1191600B/s 018%
0301s 36753B 1310212B/s 018%
0302s 35068B 1362055B/s 018%
0303s 39389B 1221477B/s 018%
0304s 40744B 1319564B/s 018%
0305s 46203B 1235381B/s 019%
0306s 43471B 1289946B/s 019%
0307s 37388B 1397667B/s 019%
0308s 36159B 1413050B/s 019%
0309s 32843B 1384684B/s 019%
0310s 30739B 1228568B/s 019%
0311s 32279B 0863539B/s 019%
0312s 38725B 1105026B/s 019%
0313s 46217B 1172217B/s 019%
0314s 49229B 1277323B/s 019%
0315s 47171B 1221929B/s 019%
0316s 49265B 1256359B/s 019%
0317s 41163B 1351793B/s 019%
0318s 42606B 1279181B/s 019%
0319s 47976B 1209781B/s 019%
0320s 50676B 1297909B/s 019%
0321s 51889B 1449471B/s 020%
0322s 37134B 1317143B/s 020%
0323s 40403B 1264463B/s 020%
0324s 41190B 1152862B/s 020%
0325s 40549B 1245919B/s 020%
0326s 39637B 1424405B/s 020%
0327s 44004B 1329476B/s 020%
0328s 45166B 1232785B/s 020%
0329s 49102B 1348938B/s 020%
0330s 41568B 1217327B/s 020%
0331s 44023B 1123438B/s 020%
0332s 36711B 1339972B/s 020%
0333s 39693B 1207884B/s 020%
0334s 36316B 1330883B/s 020%
0335s 35054B 1203480B/s 020%
0336s 39982B 1119549B/s 021%
0337s 50319B 1157813B/s 021%
0338s 49487B 1272996B/s 021%
0339s 51417B 1259237B/s 021%
0340s 58182B 1444691B/s 021%
0341s 57152B 1119177B/s 021%
0342s 60505B 1461193B/s 021%
0343s 40411B 1354257B/s 021%
0344s 42327B 1326117B/s 021%
0345s 40543B 1266993B/s 021%
0346s 43080B 1262604B/s 021%
0347s 41763B 1287682B/s 021%
0348s 38751B 1217647B/s 021%
0349s 41554B 1265899B/s 021%
0350s 40267B 1139921B/s 021%
0351s 41208B 1192595B/s 021%
0352s 45051B 1256894B/s 022%
0353s 44195B 1319052B/s 022%
0354s 46829B 1218568B/s 022%
0355s 42423B 1339034B/s 022%
0356s 51380B 0967422B/s 022%
0357s 79349B 1107001B/s 022%
0358s 114829B 1285336B/s 022%
0359s 113619B 1212885B/s 022%
0360s 122802B 1331116B/s 022%
0361s 104520B 1203158B/s 022%
0362s 116903B 1279458B/s 022%
0363s 112874B 1333649B/s 022%
0364s 102829B 1191279B/s 022%
0365s 105984B 1311294B/s 022%
0366s 103123B 1209694B/s 022%
0367s 124887B 1314755B/s 022%
0368s 129642B 1219019B/s 023%
0369s 113759B 1292763B/s 023%
0370s 111123B 1207258B/s 023%
0371s 119821B 1285745B/s 023%
0372s 112193B 1195613B/s 023%
0373s 57327B 1374164B/s 023%
0374s 41111B 1293856B/s 023%
0375s 38828B 1292326B/s 023%
0376s 34473B 1321040B/s 023%
0377s 37637B 1272890B/s 023%
0378s 43344B 1301999B/s 023%
0379s 45333B 1220310B/s 023%
0380s 40420B 1216189B/s 023%
0381s 40084B 1416035B/s 023%
0382s 30927B 1337337B/s 023%
0383s 31122B 1349740B/s 023%
0384s 28081B 1188115B/s 024%
0385s 34618B 0878063B/s 024%
0386s 37068B 1127982B/s 024%
0387s 46463B 1231926B/s 024%
0388s 48910B 1313555B/s 024%
0389s 48713B 1257016B/s 024%
0390s 44165B 1305053B/s 024%
0391s 37048B 1324043B/s 024%
0392s 47404B 1274320B/s 024%
0393s 50460B 1206033B/s 024%
0394s 51220B 1338129B/s 024%
0395s 50418B 1430434B/s 024%
0396s 36644B 1298407B/s 024%
0397s 37501B 1209372B/s 024%
0398s 41688B 1204780B/s 024%
0399s 39985B 1285861B/s 024%
0400s 38826B 1426213B/s 025%
0401s 40102B 1249510B/s 025%
0402s 47314B 1252732B/s 025%
0403s 47790B 1320194B/s 025%
0404s 45386B 1192685B/s 025%
0405s 46062B 1200921B/s 025%
0406s 36524B 1254320B/s 025%
0407s 38962B 1230707B/s 025%
0408s 36000B 1287545B/s 025%
0409s 34751B 1153381B/s 025%
0410s 39789B 1066303B/s 025%
0411s 50413B 1172741B/s 025%
0412s 48935B 1244552B/s 025%
0413s 55437B 1304853B/s 025%
0414s 43892B 1383951B/s 025%
0416s 61920B 1181401B/s 025%
0417s 62922B 1423720B/s 026%
0418s 41090B 1378882B/s 026%
0419s 38440B 1316251B/s 026%
0420s 42812B 1301924B/s 026%
0421s 43094B 1236940B/s 026%
0422s 44166B 1371291B/s 026%
0423s 39075B 1142957B/s 026%
0424s 43836B 1294958B/s 026%
0425s 39861B 1114689B/s 026%
0426s 45320B 1218337B/s 026%
0427s 47283B 1259375B/s 026%
0428s 43737B 1331079B/s 026%
0429s 45806B 1212073B/s 026%
0430s 43768B 1352229B/s 026%
0431s 50961B 0929327B/s 026%
0432s 99232B 1199218B/s 026%
0433s 112244B 1240909B/s 027%
0434s 113846B 1274675B/s 027%
0435s 112756B 1175154B/s 027%
0436s 121457B 1287115B/s 027%
0437s 114858B 1185274B/s 027%
0438s 114649B 1305231B/s 027%
0439s 119066B 1232005B/s 027%
0440s 104948B 1319060B/s 027%
0441s 103105B 1306906B/s 027%
0442s 130966B 1226654B/s 027%
0443s 112227B 1329231B/s 027%
0444s 113157B 1226900B/s 027%
0445s 118095B 1293446B/s 027%
0446s 103134B 1197043B/s 027%
0447s 112922B 1389043B/s 027%
0448s 39230B 1226777B/s 027%
0449s 41956B 1331896B/s 028%
0450s 37993B 1265261B/s 028%
0451s 36730B 1330773B/s 028%
0452s 38747B 1277834B/s 028%
0453s 45419B 1348515B/s 028%
0454s 48326B 1235546B/s 028%
0455s 43356B 1274065B/s 028%
0456s 36692B 1398688B/s 028%
0457s 32529B 1350044B/s 028%
0458s 30607B 1254774B/s 028%
0459s 30904B 1189660B/s 028%
0460s 32710B 0808223B/s 028%
0461s 46807B 1119279B/s 028%
0462s 44961B 1174310B/s 028%
0463s 49194B 1300851B/s 028%
0464s 44105B 1241980B/s 028%
0465s 53456B 1312292B/s 029%
0466s 45357B 1358468B/s 029%
0467s 47599B 1247197B/s 029%
0468s 49886B 1250516B/s 029%
0469s 49132B 1337824B/s 029%
0470s 50807B 1463165B/s 029%
0471s 37693B 1280933B/s 029%
0472s 37808B 1191150B/s 029%
0473s 42453B 1203972B/s 029%
0474s 46908B 1317387B/s 029%
0475s 43647B 1423015B/s 029%
0476s 43322B 1261853B/s 029%
0477s 47903B 1239078B/s 029%
0478s 49825B 1355678B/s 029%
0479s 38176B 1138674B/s 029%
0480s 44313B 1249109B/s 030%
0481s 33488B 1196166B/s 030%
0482s 37292B 1256752B/s 030%
0483s 36329B 1232444B/s 030%
0484s 37652B 1188880B/s 030%
0485s 36837B 1046513B/s 030%
0486s 49560B 1198542B/s 030%
0487s 50018B 1201914B/s 030%
0488s 52997B 1288662B/s 030%
0489s 46789B 1348263B/s 030%
0490s 59475B 1215732B/s 030%
0491s 59840B 1477892B/s 030%
0492s 39501B 1382457B/s 030%
0493s 36358B 1317251B/s 030%
0494s 43365B 1276963B/s 030%
0495s 42962B 1263685B/s 030%
0496s 38652B 1338999B/s 031%
0497s 39348B 1157237B/s 031%
0498s 40863B 1299754B/s 031%
0499s 41012B 1160191B/s 031%
0500s 40265B 1191079B/s 031%
0501s 40883B 1338405B/s 031%
0502s 42628B 1291796B/s 031%
0503s 44253B 1268466B/s 031%
0504s 43423B 1280297B/s 031%
0505s 59919B 0941035B/s 031%
0506s 99053B 1144872B/s 031%
0507s 125130B 1303588B/s 031%
0508s 113813B 1174500B/s 031%
0509s 120197B 1283035B/s 031%
0510s 113693B 1209958B/s 031%
0511s 113827B 1287204B/s 031%
0512s 106053B 1189064B/s 032%
0513s 127338B 1341619B/s 032%
0514s 103623B 1174377B/s 032%
0515s 105503B 1276791B/s 032%
0516s 125467B 1238221B/s 032%
0517s 124723B 1336026B/s 032%
0518s 104337B 1215890B/s 032%
0519s 116558B 1335399B/s 032%
0520s 114297B 1316126B/s 032%
0521s 105275B 1362027B/s 032%
0522s 44099B 1227201B/s 032%
0523s 38587B 1320373B/s 032%
0524s 36709B 1368790B/s 032%
0525s 36826B 1299013B/s 032%
0526s 41642B 1301953B/s 032%
0527s 47093B 1295344B/s 032%
0528s 45065B 1269687B/s 033%
0529s 42932B 1335164B/s 033%
0530s 34642B 1372051B/s 033%
0531s 32150B 1370621B/s 033%
0532s 29440B 1236927B/s 033%
0533s 29322B 1050537B/s 033%
0534s 35552B 0956793B/s 033%
0535s 44667B 1190759B/s 033%
0536s 49331B 1202097B/s 033%
0537s 36063B 1300614B/s 033%
0538s 48372B 1233715B/s 033%
0539s 43069B 1308010B/s 033%
0540s 41791B 1294005B/s 033%
0541s 47662B 1227437B/s 033%
0542s 48679B 1251984B/s 033%
0543s 50029B 1419403B/s 033%
0544s 39600B 1438239B/s 034%
0545s 37472B 1289042B/s 034%
0546s 38803B 1185907B/s 034%
0547s 40779B 1205681B/s 034%
0548s 40245B 1402251B/s 034%
0549s 38554B 1388482B/s 034%
0550s 44665B 1266768B/s 034%
0551s 46581B 1285453B/s 034%
0552s 45575B 1329056B/s 034%
0553s 37119B 1093663B/s 034%
0554s 41630B 1382926B/s 034%
0555s 35042B 1101729B/s 034%
0556s 37632B 1365556B/s 034%
0557s 37246B 1204929B/s 034%
0558s 38613B 1149548B/s 034%
0559s 46388B 1052219B/s 034%
0560s 49818B 1234279B/s 035%
0561s 49512B 1202040B/s 035%
0562s 52880B 1416876B/s 035%
0563s 46098B 1132708B/s 035%
0564s 59056B 1344497B/s 035%
0565s 55778B 1421295B/s 035%
0567s 40624B 1338765B/s 035%
0568s 40834B 1285358B/s 035%
0569s 43093B 1330974B/s 035%
0570s 42379B 1289220B/s 035%
0571s 41992B 1319722B/s 035%
0572s 40202B 1216761B/s 035%
0573s 40097B 1199949B/s 035%
0574s 43205B 1224698B/s 035%
0575s 41330B 1227491B/s 035%
0576s 43621B 1392349B/s 036%
0577s 44202B 1224877B/s 036%
0578s 43006B 1343019B/s 036%
0579s 47337B 1092810B/s 036%
0580s 71424B 1065388B/s 036%
0581s 112030B 1285997B/s 036%
0582s 112285B 1250013B/s 036%
0583s 111511B 1313477B/s 036%
0584s 101779B 1163228B/s 036%
0585s 114972B 1299600B/s 036%
0586s 117333B 1217822B/s 036%
0587s 104336B 1292859B/s 036%
0588s 103130B 1178944B/s 036%
0589s 118979B 1293656B/s 036%
0590s 113802B 1219466B/s 036%
0591s 113878B 1294811B/s 036%
0592s 118046B 1168064B/s 037%
0593s 123037B 1350699B/s 037%
0594s 123580B 1195314B/s 037%
0595s 107993B 1306448B/s 037%
0596s 83854B 1423699B/s 037%
0597s 40121B 1197984B/s 037%
0598s 36587B 1346509B/s 037%
0599s 34304B 1387807B/s 037%
0600s 37905B 1276041B/s 037%
0601s 37385B 1315374B/s 037%
0602s 49057B 1255814B/s 037%
0603s 42926B 1244853B/s 037%
0604s 42143B 1422589B/s 037%
0605s 31426B 1377570B/s 037%
0606s 30824B 1366021B/s 037%
0607s 27220B 1202747B/s 037%
0608s 36232B 0866879B/s 038%
0609s 38074B 1087051B/s 038%
0610s 45813B 1222801B/s 038%
0611s 46135B 1304250B/s 038%
0612s 47793B 1218142B/s 038%
0613s 47130B 1292652B/s 038%
0614s 42443B 1342520B/s 038%
0615s 46673B 1260224B/s 038%
0616s 47641B 1181332B/s 038%
0617s 54398B 1297993B/s 038%
0618s 48033B 1428879B/s 038%
0619s 40943B 1307214B/s 038%
0620s 37558B 1253008B/s 038%
0621s 41411B 1197485B/s 038%
0622s 42381B 1255399B/s 038%
0623s 42316B 1461382B/s 038%
0624s 37485B 1312453B/s 039%
0625s 44125B 1269314B/s 039%
0626s 49542B 1417235B/s 039%
0627s 41532B 1185711B/s 039%
0628s 44019B 1201665B/s 039%
0629s 32915B 1270564B/s 039%
0630s 37853B 1231546B/s 039%
0631s 33421B 1302243B/s 039%
0632s 34967B 1191131B/s 039%
0633s 39131B 1071713B/s 039%
0634s 48235B 1197343B/s 039%
0635s 51758B 1224412B/s 039%
0636s 51810B 1273898B/s 039%
0637s 54749B 1374965B/s 039%
0638s 57465B 1176548B/s 039%
0639s 58028B 1440065B/s 040%
0640s 42849B 1363680B/s 040%
0641s 44356B 1325903B/s 040%
0642s 43040B 1286833B/s 040%
0643s 44211B 1243689B/s 040%
0644s 41380B 1326534B/s 040%
0645s 37871B 1182267B/s 040%
0646s 41214B 1298434B/s 040%
0647s 40835B 1168008B/s 040%
0648s 43394B 1223958B/s 040%
0649s 43131B 1339176B/s 040%
0650s 42780B 1299347B/s 040%
0651s 44334B 1255395B/s 040%
0652s 43162B 1322093B/s 040%
0653s 59474B 0963958B/s 040%
0654s 100509B 1256949B/s 040%
0655s 127264B 1226344B/s 041%
0656s 113862B 1308330B/s 041%
0657s 125353B 1197445B/s 041%
0658s 144698B 1309542B/s 041%
0659s 114369B 1231653B/s 041%
0660s 114308B 1282602B/s 041%
0661s 103039B 1232800B/s 041%
0662s 109026B 1286943B/s 041%
0663s 113224B 1217630B/s 041%
0664s 115355B 1324221B/s 041%
0665s 123986B 1216912B/s 041%
0666s 113668B 1290637B/s 041%
0667s 112435B 1198687B/s 041%
0668s 115180B 1284208B/s 041%
0669s 114195B 1402303B/s 041%
0670s 36074B 1172997B/s 041%
0671s 39855B 1283367B/s 042%
0672s 37706B 1419675B/s 042%
0673s 38504B 1326460B/s 042%
0674s 40673B 1259884B/s 042%
0675s 41009B 1302786B/s 042%
0676s 47317B 1253656B/s 042%
0677s 41715B 1348253B/s 042%
0678s 40507B 1396415B/s 042%
0679s 32034B 1389461B/s 042%
0680s 32862B 1268962B/s 042%
0681s 28640B 1031919B/s 042%
0682s 38406B 1041933B/s 042%
0683s 48633B 1141037B/s 042%
0684s 49672B 1254961B/s 042%
0685s 45149B 1256422B/s 042%
0686s 45429B 1265713B/s 042%
0687s 47906B 1311589B/s 043%
0688s 37325B 1316679B/s 043%
0689s 48345B 1206316B/s 043%
0690s 50737B 1235494B/s 043%
0691s 51812B 1379368B/s 043%
0692s 44953B 1388062B/s 043%
0693s 40568B 1244077B/s 043%
0694s 42873B 1171903B/s 043%
0695s 40914B 1160473B/s 043%
0696s 40584B 1368068B/s 043%
0697s 39849B 1353555B/s 043%
0698s 43963B 1277177B/s 043%
0699s 43960B 1280503B/s 043%
0700s 49523B 1346158B/s 043%
0701s 38774B 1106614B/s 043%
0702s 46942B 1324501B/s 043%
0703s 35329B 1125743B/s 044%
0704s 41120B 1343924B/s 044%
0705s 34007B 1216398B/s 044%
0706s 37395B 1180803B/s 044%
0707s 41117B 1060320B/s 044%
0708s 48604B 1225921B/s 044%
0709s 50691B 1192175B/s 044%
0710s 52758B 1389948B/s 044%
0711s 47082B 1199213B/s 044%
0713s 59428B 1275699B/s 044%
0714s 55364B 1451754B/s 044%
0715s 39765B 1340616B/s 044%
0716s 39385B 1252565B/s 044%
0717s 45701B 1303609B/s 044%
0718s 43112B 1223437B/s 044%
0719s 42728B 1310590B/s 044%
0720s 39752B 1157766B/s 045%
0721s 39997B 1259265B/s 045%
0722s 40961B 1108414B/s 045%
0723s 43797B 1176371B/s 045%
0724s 44517B 1329810B/s 045%
0725s 45149B 1288178B/s 045%
0726s 44932B 1261256B/s 045%
0727s 43137B 1289522B/s 045%
0728s 58294B 0937044B/s 045%
0729s 103607B 1213454B/s 045%
0730s 113202B 1317163B/s 045%
0731s 114870B 1222361B/s 045%
0732s 117224B 1282633B/s 045%
0733s 114142B 1201499B/s 045%
0734s 113488B 1326357B/s 045%
0735s 106463B 1202641B/s 045%
0736s 118004B 1343644B/s 046%
0737s 103544B 1178311B/s 046%
0738s 104407B 1282102B/s 046%
0739s 119179B 1204249B/s 046%
0740s 113717B 1310963B/s 046%
0741s 103434B 1195499B/s 046%
0742s 130147B 1319692B/s 046%
0743s 112921B 1157865B/s 046%
0744s 103108B 1415579B/s 046%
0745s 37547B 1149421B/s 046%
0746s 38730B 1304991B/s 046%
0747s 36949B 1315892B/s 046%
0748s 39640B 1297086B/s 046%
0749s 42581B 1233331B/s 046%
0750s 43699B 1318088B/s 046%
0751s 45018B 1242814B/s 046%
0752s 39657B 1297856B/s 047%
0753s 39549B 1394757B/s 047%
0754s 34006B 1383218B/s 047%
0755s 37445B 1259320B/s 047%
0756s 27582B 1138913B/s 047%
0757s 35156B 0904796B/s 047%
0758s 42187B 1147545B/s 047%
0759s 44625B 1211947B/s 047%
0760s 47795B 1314918B/s 047%
0761s 46991B 1217479B/s 047%
0762s 44588B 1306970B/s 047%
0763s 40200B 1292153B/s 047%
0764s 49835B 1222276B/s 047%
0765s 48126B 1202196B/s 047%
0766s 51729B 1356169B/s 047%
0767s 48902B 1399328B/s 047%
0768s 40017B 1301456B/s 048%
0769s 36744B 1139907B/s 048%
0770s 40947B 1212301B/s 048%
0771s 43928B 1295040B/s 048%
0772s 39947B 1392830B/s 048%
0773s 43709B 1231721B/s 048%
0774s 44186B 1259195B/s 048%
0775s 47700B 1324989B/s 048%
0776s 39499B 1138310B/s 048%
0777s 46343B 1241797B/s 048%
0778s 34685B 1250730B/s 048%
0779s 36869B 1278080B/s 048%
0780s 35251B 1254768B/s 048%
0781s 36841B 1186514B/s 048%
0782s 42392B 1097937B/s 048%
0783s 49835B 1224896B/s 049%
0784s 47255B 1203517B/s 049%
0785s 51624B 1306296B/s 049%
0786s 47042B 1322158B/s 049%
0787s 57686B 1200341B/s 049%
0788s 61321B 1430607B/s 049%
0789s 39427B 1310815B/s 049%
0790s 38901B 1267479B/s 049%
0791s 40242B 1257313B/s 049%
0792s 43466B 1256328B/s 049%
0793s 39268B 1295333B/s 049%
0794s 42025B 1190285B/s 049%
0795s 40453B 1289322B/s 049%
0796s 40768B 1101058B/s 049%
0797s 46516B 1182899B/s 049%
0798s 44218B 1274233B/s 049%
0799s 45400B 1306743B/s 049%
0800s 46924B 1205871B/s 050%
0801s 41695B 1320695B/s 050%
0802s 51678B 0940218B/s 050%
0803s 87649B 1124090B/s 050%
0804s 122981B 1331255B/s 050%
0805s 124571B 1185047B/s 050%
0806s 115410B 1313262B/s 050%
0807s 113987B 1199924B/s 050%
0808s 112724B 1321111B/s 050%
0809s 108407B 1168590B/s 050%
0810s 123753B 1334193B/s 050%
0811s 105281B 1239815B/s 050%
0812s 106385B 1260385B/s 050%
0813s 112529B 1218671B/s 050%
0814s 111721B 1326964B/s 050%
0815s 117365B 1277098B/s 051%
0816s 111423B 1180562B/s 051%
0817s 113069B 1307377B/s 051%
0818s 102813B 1217833B/s 051%
0819s 39923B 1318374B/s 051%
0820s 41571B 1285787B/s 051%
0821s 35026B 1273487B/s 051%
0822s 37459B 1323825B/s 051%
0823s 39220B 1249166B/s 051%
0824s 40303B 1340162B/s 051%
0825s 48719B 1166902B/s 051%
0826s 43333B 1252425B/s 051%
0827s 38757B 1384266B/s 051%
0828s 33414B 1335025B/s 051%
0829s 34467B 1356291B/s 051%
0830s 29939B 1211550B/s 051%
0831s 32092B 0846324B/s 051%
0832s 37451B 1116509B/s 052%
0833s 46056B 1192211B/s 052%
0834s 44748B 1294919B/s 052%
0835s 44805B 1258607B/s 052%
0836s 44190B 1281793B/s 052%
0837s 40702B 1361214B/s 052%
0838s 45682B 1215534B/s 052%
0839s 48310B 1200765B/s 052%
0840s 50354B 1289340B/s 052%
0841s 49168B 1483525B/s 052%
0842s 37074B 1266692B/s 052%
0843s 39435B 1240656B/s 052%
0844s 42128B 1137462B/s 052%
0845s 41066B 1247633B/s 052%
0846s 39701B 1415281B/s 052%
0847s 45014B 1308208B/s 053%
0848s 44678B 1209166B/s 053%
0849s 47437B 1343860B/s 053%
0850s 41651B 1226073B/s 053%
0851s 44059B 1115898B/s 053%
0852s 33716B 1317503B/s 053%
0853s 40081B 1164996B/s 053%
0854s 37530B 1279537B/s 053%
0855s 35327B 1221992B/s 053%
0856s 38641B 1096484B/s 053%
0857s 49665B 1135084B/s 053%
0858s 49230B 1233818B/s 053%
0859s 52528B 1276662B/s 053%
0860s 50914B 1433770B/s 053%
0861s 57558B 1143207B/s 053%
0862s 61829B 1405554B/s 053%
0863s 48099B 1396366B/s 054%
0864s 44111B 1314437B/s 054%
0865s 43080B 1306973B/s 054%
0866s 43356B 1284740B/s 054%
0867s 41042B 1296859B/s 054%
0868s 37928B 1255659B/s 054%
0870s 42360B 1261202B/s 054%
0871s 41549B 1158995B/s 054%
0872s 45572B 1200988B/s 054%
0873s 45629B 1248699B/s 054%
0874s 46451B 1329452B/s 054%
0875s 46254B 1187668B/s 054%
0876s 41607B 1344571B/s 054%
0877s 51687B 0982167B/s 054%
0878s 79116B 1083656B/s 054%
0879s 112322B 1305146B/s 054%
0880s 119486B 1199518B/s 055%
0881s 113704B 1294440B/s 055%
0882s 103987B 1222851B/s 055%
0883s 117638B 1316297B/s 055%
0884s 115482B 1267184B/s 055%
0885s 114663B 1312293B/s 055%
0886s 96851B 1196152B/s 055%
0887s 114813B 1339228B/s 055%
0888s 124975B 1326817B/s 055%
0889s 111861B 1214520B/s 055%
0890s 112049B 1313927B/s 055%
0891s 112431B 1214220B/s 055%
0892s 113424B 1302058B/s 055%
0893s 119329B 1284682B/s 055%
0894s 41189B 1314393B/s 055%
0895s 41661B 1305207B/s 055%
0896s 36209B 1291185B/s 056%
0897s 35654B 1331416B/s 056%
0898s 39817B 1298817B/s 056%
0899s 43897B 1328146B/s 056%
0900s 48510B 1244846B/s 056%
0901s 40662B 1286871B/s 056%
0902s 38808B 1414178B/s 056%
0903s 31917B 1341380B/s 056%
0904s 31806B 1287745B/s 056%
0905s 27594B 1197979B/s 056%
0906s 34417B 0821260B/s 056%
0907s 46253B 1143303B/s 056%
0908s 42532B 1182299B/s 056%
0909s 51128B 1342156B/s 056%
0910s 43626B 1231660B/s 056%
0911s 45858B 1318072B/s 056%
0912s 36550B 1331097B/s 057%
0913s 47377B 1259159B/s 057%
0914s 48267B 1202509B/s 057%
0915s 52003B 1382354B/s 057%
0916s 51461B 1471732B/s 057%
0917s 40341B 1273823B/s 057%
0918s 38755B 1179836B/s 057%
0919s 41288B 1198742B/s 057%
0920s 40087B 1345522B/s 057%
0921s 37980B 1394719B/s 057%
0922s 44181B 1284966B/s 057%
0923s 48091B 1252486B/s 057%
0924s 47822B 1375728B/s 057%
0925s 35194B 1140348B/s 057%
0926s 43068B 1285955B/s 057%
0927s 32391B 1164894B/s 057%
0928s 40207B 1310531B/s 058%
0929s 31818B 1192105B/s 058%
0930s 34662B 1172619B/s 058%
0931s 39066B 1047980B/s 058%
0932s 50763B 1213422B/s 058%
0933s 49205B 1201945B/s 058%
0934s 53122B 1357715B/s 058%
0935s 43460B 1322810B/s 058%
0936s 61745B 1249900B/s 058%
0937s 61349B 1498947B/s 058%
0938s 41689B 1348485B/s 058%
0939s 37534B 1335426B/s 058%
0940s 44077B 1297341B/s 058%
0941s 44543B 1286372B/s 058%
0942s 42017B 1328152B/s 058%
0943s 46212B 1202204B/s 059%
0944s 40429B 1241938B/s 059%
0945s 39507B 1180282B/s 059%
0946s 45534B 1198410B/s 059%
0947s 43614B 1355807B/s 059%
0948s 42279B 1273655B/s 059%
0949s 46039B 1298074B/s 059%
0950s 44431B 1197249B/s 059%
0951s 65373B 1003267B/s 059%
0952s 102028B 1256063B/s 059%
0953s 129958B 1221031B/s 059%
0954s 136871B 1268499B/s 059%
0955s 102930B 1208761B/s 059%
0956s 129653B 1282812B/s 059%
0957s 113581B 1204453B/s 059%
0958s 102875B 1287111B/s 059%
0959s 107714B 1220739B/s 060%
0960s 104893B 1329027B/s 060%
0961s 115159B 1234140B/s 060%
0962s 127991B 1324792B/s 060%
0963s 113734B 1348384B/s 060%
0964s 123636B 1226462B/s 060%
0965s 116146B 1296772B/s 060%
0966s 112808B 1191202B/s 060%
0967s 104755B 1457429B/s 060%
0968s 40322B 1128048B/s 060%
0969s 39696B 1379286B/s 060%
0970s 37553B 1377338B/s 060%
0971s 38137B 1245183B/s 060%
0972s 38475B 1293106B/s 060%
0973s 45562B 1276567B/s 060%
0974s 43585B 1242268B/s 060%
0975s 40470B 1372084B/s 061%
0976s 34997B 1382125B/s 061%
0977s 30882B 1366714B/s 061%
0978s 30732B 1234833B/s 061%
0979s 31705B 0952332B/s 061%
0980s 37285B 1069691B/s 061%
0981s 46767B 1139671B/s 061%
0982s 49046B 1259965B/s 061%
0983s 43215B 1231182B/s 061%
0984s 47745B 1259948B/s 061%
0985s 41105B 1321448B/s 061%
0986s 42428B 1334492B/s 061%
0987s 47538B 1181521B/s 061%
0988s 49878B 1267769B/s 061%
0989s 50037B 1429866B/s 061%
0990s 38693B 1396666B/s 061%
0991s 37310B 1258184B/s 062%
0992s 41916B 1173020B/s 062%
0993s 39264B 1225167B/s 062%
0994s 40883B 1421704B/s 062%
0995s 44341B 1391250B/s 062%
0996s 43915B 1262331B/s 062%
0997s 48513B 1341536B/s 062%
0998s 41207B 1273973B/s 062%
0999s 45463B 1117382B/s 062%
1000s 40871B 1379725B/s 062%
1001s 38307B 1153597B/s 062%
1002s 35394B 1328372B/s 062%
1003s 35286B 1200086B/s 062%
1004s 36425B 1106722B/s 062%
1005s 55276B 1144517B/s 062%
1006s 44805B 1222367B/s 063%
1007s 54723B 1260984B/s 063%
1008s 54002B 1477292B/s 063%
1009s 56753B 1080731B/s 063%
1010s 61855B 1360206B/s 063%
1011s 51397B 1409368B/s 063%
1012s 40244B 1347483B/s 063%
1013s 42530B 1305097B/s 063%
1014s 43249B 1324455B/s 063%
1015s 43872B 1304270B/s 063%
1016s 43421B 1258010B/s 063%
1017s 39350B 1262126B/s 063%
1018s 40511B 1171941B/s 063%
1019s 41076B 1206364B/s 063%
1020s 41940B 1271311B/s 063%
1021s 40377B 1350202B/s 063%
1022s 46526B 1201930B/s 064%
1023s 41724B 1375913B/s 064%
1024s 46086B 0952798B/s 064%
1025s 101531B 1196406B/s 064%
1027s 113244B 1223658B/s 064%
1028s 114501B 1285168B/s 064%
1029s 104493B 1240164B/s 064%
1030s 114474B 1282638B/s 064%
1031s 113404B 1227380B/s 064%
1032s 112817B 1299467B/s 064%
1033s 115560B 1201170B/s 064%
1034s 103320B 1283941B/s 064%
1035s 104004B 1204695B/s 064%
1036s 119510B 1315147B/s 064%
1037s 112111B 1224635B/s 064%
1038s 123460B 1308655B/s 064%
1039s 127005B 1208876B/s 065%
1040s 114116B 1320970B/s 065%
1041s 104202B 1341918B/s 065%
1042s 38818B 1293427B/s 065%
1043s 40430B 1349853B/s 065%
1044s 37520B 1286277B/s 065%
1045s 38429B 1360871B/s 065%
1046s 36220B 1288656B/s 065%
1047s 44200B 1368730B/s 065%
1048s 48179B 1280308B/s 065%
1049s 42659B 1293440B/s 065%
1050s 34859B 1417551B/s 065%
1051s 32125B 1362102B/s 065%
1052s 31414B 1266437B/s 065%
1053s 27337B 1125053B/s 065%
1054s 35246B 0936108B/s 065%
1055s 45391B 1127966B/s 066%
1056s 49343B 1240195B/s 066%
1057s 36330B 1281979B/s 066%
1058s 51133B 1260362B/s 066%
1059s 42961B 1295720B/s 066%
1060s 42076B 1351333B/s 066%
1061s 48900B 1219860B/s 066%
1062s 48747B 1199649B/s 066%
1063s 50358B 1366191B/s 066%
1064s 39460B 1444491B/s 066%
1065s 40026B 1319192B/s 066%
1066s 38273B 1140019B/s 066%
1067s 42661B 1242581B/s 066%
1068s 41036B 1341540B/s 066%
1069s 41637B 1433672B/s 066%
1070s 43475B 1277873B/s 066%
1071s 46890B 1305715B/s 067%
1072s 44338B 1351456B/s 067%
1073s 36357B 1118183B/s 067%
1074s 43876B 1341797B/s 067%
1075s 34854B 1135390B/s 067%
1076s 37648B 1368691B/s 067%
1077s 36331B 1225592B/s 067%
1078s 40216B 1161343B/s 067%
1079s 46033B 1071918B/s 067%
1080s 48604B 1242316B/s 067%
1081s 48905B 1219480B/s 067%
1082s 52805B 1415165B/s 067%
1083s 53542B 1137523B/s 067%
1084s 59619B 1359003B/s 067%
1085s 56301B 1436743B/s 067%
1086s 39738B 1339861B/s 068%
1087s 36316B 1264411B/s 068%
1088s 43591B 1313093B/s 068%
1089s 41654B 1228276B/s 068%
1090s 42011B 1366088B/s 068%
1091s 40681B 1205602B/s 068%
1092s 38727B 1198058B/s 068%
1093s 42203B 1218806B/s 068%
1094s 41060B 1236396B/s 068%
1095s 44448B 1380063B/s 068%
1096s 43645B 1211597B/s 068%
1097s 43989B 1378086B/s 068%
1098s 41911B 1100522B/s 068%
1099s 78845B 1066113B/s 068%
1100s 113687B 1302462B/s 068%
1101s 113347B 1241769B/s 068%
1102s 118245B 1330460B/s 069%
1103s 101960B 1184292B/s 069%
1104s 113548B 1305487B/s 069%
1105s 119462B 1200484B/s 069%
1106s 115373B 1312492B/s 069%
1107s 103887B 1184183B/s 069%
1108s 118830B 1286093B/s 069%
1109s 113022B 1208980B/s 069%
1110s 113339B 1336249B/s 069%
1111s 115380B 1187520B/s 069%
1112s 118703B 1300694B/s 069%
1113s 113481B 1208216B/s 069%
1114s 105727B 1276039B/s 069%
1115s 72612B 1410385B/s 069%
1116s 39892B 1211495B/s 069%
1117s 35396B 1326682B/s 069%
1118s 35714B 1401536B/s 070%
1119s 38073B 1275588B/s 070%
1120s 40436B 1314979B/s 070%
1121s 45276B 1267026B/s 070%
1122s 42520B 1253072B/s 070%
1123s 42097B 1423287B/s 070%
1124s 31912B 1368555B/s 070%
1125s 31180B 1373065B/s 070%
1126s 30105B 1210648B/s 070%
1127s 36636B 0876646B/s 070%
1128s 44327B 1118534B/s 070%
1129s 45506B 1184226B/s 070%
1130s 45369B 1292573B/s 070%
1131s 43140B 1224763B/s 070%
1132s 43562B 1291324B/s 070%
1133s 39717B 1312502B/s 070%
1134s 46995B 1266573B/s 071%
1135s 48229B 1198965B/s 071%
1136s 51465B 1319372B/s 071%
1137s 50436B 1438138B/s 071%
1138s 41178B 1292575B/s 071%
1139s 37544B 1228504B/s 071%
1140s 43167B 1170394B/s 071%
1141s 43173B 1241453B/s 071%
1142s 40423B 1444453B/s 071%
1143s 39262B 1334026B/s 071%
1144s 44955B 1276394B/s 071%
1145s 48042B 1397144B/s 071%
1146s 39321B 1210296B/s 071%
1147s 42681B 1206809B/s 071%
1148s 34608B 1273545B/s 071%
1149s 37218B 1243841B/s 072%
1150s 33318B 1291737B/s 072%
1151s 35234B 1196207B/s 072%
1152s 38040B 1069306B/s 072%
1153s 49117B 1211966B/s 072%
1154s 49351B 1217030B/s 072%
1155s 51602B 1287241B/s 072%
1156s 50862B 1368710B/s 072%
1157s 58406B 1195062B/s 072%
1158s 58834B 1482414B/s 072%
1159s 43935B 1343172B/s 072%
1160s 44742B 1288148B/s 072%
1161s 43057B 1273446B/s 072%
1162s 44333B 1254275B/s 072%
1163s 41715B 1307719B/s 072%
1164s 37929B 1187805B/s 072%
1165s 40139B 1286111B/s 073%
1166s 40462B 1129011B/s 073%
1167s 43220B 1224956B/s 073%
1168s 44903B 1326312B/s 073%
1169s 40382B 1296591B/s 073%
1170s 45280B 1287429B/s 073%
1171s 41832B 1325508B/s 073%
1172s 52622B 0961038B/s 073%
1173s 89003B 1165355B/s 073%
1174s 112528B 1312019B/s 073%
1175s 119250B 1301429B/s 073%
1176s 113964B 1213029B/s 073%
1177s 115947B 1306775B/s 073%
1178s 117482B 1227852B/s 073%
1179s 116096B 1300874B/s 073%
1180s 103330B 1224814B/s 073%
1181s 105544B 1289520B/s 074%
1182s 102786B 1202975B/s 074%
1183s 115396B 1314025B/s 074%
1184s 117688B 1220573B/s 074%
1185s 113566B 1289822B/s 074%
1186s 112130B 1236860B/s 074%
1187s 104627B 1272749B/s 074%
1189s 103646B 1402143B/s 074%
1190s 39820B 1186300B/s 074%
1191s 39192B 1289633B/s 074%
1192s 38013B 1347200B/s 074%
1193s 34571B 1279797B/s 074%
1194s 37149B 1300095B/s 074%
1195s 41438B 1328470B/s 074%
1196s 43762B 1267742B/s 074%
1197s 41981B 1323919B/s 074%
1198s 39041B 1399429B/s 075%
1199s 31868B 1359678B/s 075%
1200s 29406B 1282630B/s 075%
1201s 27915B 1067313B/s 075%
1202s 33192B 1000054B/s 075%
1203s 44118B 1170125B/s 075%
1204s 47044B 1212721B/s 075%
1205s 40831B 1281464B/s 075%
1206s 47907B 1284450B/s 075%
1207s 47026B 1315865B/s 075%
1208s 41876B 1330821B/s 075%
1209s 48297B 1180832B/s 075%
1210s 51071B 1247383B/s 075%
1211s 47922B 1392677B/s 075%
1212s 40909B 1399957B/s 075%
1213s 40022B 1239430B/s 075%
1214s 39136B 1176738B/s 076%
1215s 40617B 1185248B/s 076%
1216s 42015B 1376124B/s 076%
1217s 38405B 1374109B/s 076%
1218s 42560B 1257788B/s 076%
1219s 44549B 1243713B/s 076%
1220s 48383B 1396536B/s 076%
1221s 39823B 1115177B/s 076%
1222s 43116B 1373851B/s 076%
1223s 37133B 1151127B/s 076%
1224s 35592B 1366837B/s 076%
1225s 34988B 1252575B/s 076%
1226s 37666B 1128844B/s 076%
1227s 43459B 1119096B/s 076%
1228s 48836B 1214678B/s 076%
1229s 53727B 1255612B/s 077%
1230s 53880B 1428873B/s 077%
1231s 55714B 1153782B/s 077%
1232s 57844B 1348218B/s 077%
1233s 56566B 1427362B/s 077%
1234s 39214B 1339358B/s 077%
1235s 43615B 1307059B/s 077%
1236s 43323B 1326864B/s 077%
1237s 39802B 1216271B/s 077%
1238s 42620B 1295893B/s 077%
1239s 39237B 1187106B/s 077%
1240s 40843B 1189824B/s 077%
1241s 43375B 1166500B/s 077%
1242s 45724B 1221496B/s 077%
1243s 42932B 1361384B/s 077%
1244s 43676B 1199263B/s 077%
1245s 43842B 1315966B/s 078%
1246s 41940B 1131053B/s 078%
1247s 71570B 1049830B/s 078%
1248s 114924B 1271590B/s 078%
1249s 112483B 1252859B/s 078%
1250s 124227B 1342805B/s 078%
1251s 102732B 1203313B/s 078%
1252s 112663B 1290329B/s 078%
1253s 113692B 1235752B/s 078%
1254s 104922B 1290157B/s 078%
1255s 119044B 1296870B/s 078%
1256s 102599B 1233354B/s 078%
1257s 103264B 1319352B/s 078%
1258s 117240B 1248126B/s 078%
1259s 124016B 1259522B/s 078%
1260s 113491B 1213514B/s 078%
1261s 114862B 1300196B/s 079%
1262s 113891B 1241955B/s 079%
1263s 102786B 1436159B/s 079%
1264s 40986B 1188384B/s 079%
1265s 34968B 1302457B/s 079%
1266s 36537B 1353850B/s 079%
1267s 40912B 1240734B/s 079%
1268s 37965B 1269814B/s 079%
1269s 47114B 1229996B/s 079%
1270s 43731B 1246263B/s 079%
1271s 44466B 1419594B/s 079%
1272s 34668B 1392393B/s 079%
1273s 32784B 1378888B/s 079%
1274s 27815B 1224044B/s 079%
1275s 35699B 0890865B/s 079%
1276s 40335B 1110013B/s 079%
1277s 45286B 1208880B/s 080%
1278s 50324B 1311319B/s 080%
1279s 43599B 1224224B/s 080%
1280s 45851B 1288662B/s 080%
1281s 39386B 1362408B/s 080%
1282s 47770B 1282307B/s 080%
1283s 48584B 1199384B/s 080%
1284s 51857B 1316201B/s 080%
1285s 48466B 1475950B/s 080%
1286s 41537B 1285736B/s 080%
1287s 38090B 1259851B/s 080%
1288s 42933B 1178265B/s 080%
1289s 40163B 1255001B/s 080%
1290s 40790B 1408805B/s 080%
1291s 39451B 1325162B/s 080%
1292s 43871B 1250056B/s 080%
1293s 48137B 1350556B/s 081%
1294s 38848B 1187347B/s 081%
1295s 45960B 1170954B/s 081%
1296s 35540B 1293101B/s 081%
1297s 37097B 1211771B/s 081%
1298s 32908B 1307647B/s 081%
1299s 36478B 1199624B/s 081%
1300s 38940B 1101388B/s 081%
1301s 48377B 1214871B/s 081%
1302s 53748B 1264370B/s 081%
1303s 51133B 1279669B/s 081%
1304s 51889B 1415746B/s 081%
1305s 58744B 1184970B/s 081%
1306s 56857B 1495153B/s 081%
1307s 39773B 1352280B/s 081%
1308s 40114B 1296025B/s 082%
1309s 40637B 1290079B/s 082%
1310s 43603B 1263465B/s 082%
1311s 38580B 1341338B/s 082%
1312s 36267B 1169048B/s 082%
1313s 43712B 1328166B/s 082%
1314s 40926B 1126507B/s 082%
1315s 46398B 1221192B/s 082%
1316s 43859B 1322524B/s 082%
1317s 45647B 1309867B/s 082%
1318s 44271B 1223598B/s 082%
1319s 42707B 1319977B/s 082%
1320s 58241B 0915927B/s 082%
1321s 90295B 1196071B/s 082%
1322s 113815B 1234522B/s 082%
1323s 114346B 1272577B/s 082%
1324s 113992B 1240764B/s 083%
1325s 115133B 1305397B/s 083%
1326s 114018B 1234519B/s 083%
1327s 107755B 1298949B/s 083%
1328s 124448B 1324824B/s 083%
1329s 103928B 1258372B/s 083%
1330s 86513B 1320776B/s 083%
1331s 83896B 1214656B/s 083%
1332s 83254B 1295988B/s 083%
1333s 75511B 1245083B/s 083%
1334s 84840B 1296648B/s 083%
1335s 75464B 1274916B/s 083%
1336s 69136B 1459930B/s 083%
1337s 22825B 1383622B/s 083%
1338s 22983B 1392484B/s 083%
1339s 23218B 1363668B/s 083%
1340s 23868B 1289094B/s 084%
1341s 22998B 1260497B/s 084%
1342s 21840B 1332957B/s 084%
1343s 22994B 1251830B/s 084%
1344s 23108B 1330120B/s 084%
1345s 23140B 1387473B/s 084%
1346s 25009B 1301656B/s 084%
1347s 22635B 1266201B/s 084%
1348s 21199B 1182427B/s 084%
1350s 21520B 1224727B/s 084%
1351s 20842B 1185611B/s 084%
1352s 19842B 1158836B/s 084%
1353s 22037B 1145952B/s 084%
1354s 22350B 1288002B/s 084%
1355s 23365B 1318193B/s 084%
1356s 21539B 1292596B/s 084%
1357s 24983B 1342029B/s 085%
1358s 23133B 1280829B/s 085%
1359s 24188B 1421202B/s 085%
1360s 25859B 1318344B/s 085%
1361s 22529B 1316727B/s 085%
1362s 21449B 1233066B/s 085%
1363s 19941B 1132973B/s 085%
1364s 24012B 1402287B/s 085%
1365s 23881B 1375104B/s 085%
1366s 24125B 1348420B/s 085%
1367s 22748B 1338322B/s 085%
1368s 23565B 1297723B/s 085%
1369s 22686B 1278425B/s 085%
1370s 21761B 1241744B/s 085%
1371s 22692B 1305267B/s 085%
1372s 21799B 1238151B/s 086%
1373s 22025B 1278966B/s 086%
1374s 22135B 1250160B/s 086%
1375s 23121B 1263624B/s 086%
1376s 22325B 1309990B/s 086%
1377s 22510B 1246494B/s 086%
1378s 24086B 1369050B/s 086%
1379s 22718B 1331462B/s 086%
1380s 22538B 1288859B/s 086%
1381s 21421B 1280040B/s 086%
1382s 22893B 1277297B/s 086%
1383s 23385B 1292648B/s 086%
1384s 23568B 1282872B/s 086%
1385s 23280B 1295907B/s 086%
1386s 22858B 1301435B/s 086%
1387s 23455B 1297477B/s 086%
1388s 22653B 1270617B/s 087%
1389s 22117B 1264083B/s 087%
1390s 23316B 1311457B/s 087%
1391s 22705B 1271560B/s 087%
1392s 23098B 1278216B/s 087%
1393s 23123B 1249213B/s 087%
1394s 25388B 1154918B/s 087%
1395s 40751B 0683153B/s 087%
1396s 68675B 1062655B/s 087%
1397s 76174B 1149116B/s 087%
1398s 82649B 1245920B/s 087%
1399s 74711B 1196391B/s 087%
1400s 76874B 1286590B/s 087%
1401s 85320B 1240515B/s 087%
1402s 84861B 1293615B/s 087%
1403s 86456B 1241632B/s 087%
1404s 87748B 1303819B/s 088%
1405s 83583B 1329090B/s 088%
1406s 83701B 1248648B/s 088%
1407s 76173B 1303629B/s 088%
1408s 74868B 1240644B/s 088%
1409s 75875B 1343127B/s 088%
1410s 65136B 1491034B/s 088%
1411s 22518B 1321350B/s 088%
1412s 23254B 1370637B/s 088%
1413s 23598B 1368876B/s 088%
1414s 21759B 1277280B/s 088%
1415s 22833B 1313797B/s 088%
1416s 23317B 1377351B/s 088%
1417s 23140B 1313955B/s 088%
1418s 22848B 1388617B/s 088%
1419s 24337B 1379150B/s 089%
1420s 22869B 1298661B/s 089%
1421s 21932B 1273076B/s 089%
1422s 21683B 1189266B/s 089%
1423s 21674B 1189992B/s 089%
1424s 20613B 1146038B/s 089%
1425s 20225B 1122161B/s 089%
1426s 20113B 1147686B/s 089%
1427s 23878B 1308748B/s 089%
1428s 22095B 1326975B/s 089%
1429s 24398B 1321671B/s 089%
1430s 23323B 1342648B/s 089%
1431s 21865B 1310093B/s 089%
1432s 23659B 1434183B/s 089%
1433s 22298B 1324644B/s 089%
1434s 22547B 1330998B/s 089%
1435s 21405B 1222812B/s 090%
1436s 21940B 1208443B/s 090%
1437s 23781B 1423929B/s 090%
1438s 23985B 1385471B/s 090%
1439s 23572B 1357173B/s 090%
1440s 23026B 1317273B/s 090%
1441s 23293B 1274258B/s 090%
1442s 22323B 1283047B/s 090%
1443s 22223B 1258960B/s 090%
1444s 22778B 1290595B/s 090%
1445s 20838B 1237766B/s 090%
1446s 22280B 1309089B/s 090%
1447s 21371B 1214188B/s 090%
1448s 23249B 1303636B/s 090%
1449s 20846B 1231370B/s 090%
1450s 23930B 1269826B/s 091%
1451s 22874B 1305810B/s 091%
1452s 22698B 1303669B/s 091%
1453s 21975B 1282004B/s 091%
1454s 22803B 1290638B/s 091%
1455s 22395B 1301998B/s 091%
1456s 23220B 1289822B/s 091%
1457s 22686B 1312878B/s 091%
1458s 23754B 1284579B/s 091%
1459s 23044B 1316511B/s 091%
1460s 23030B 1306222B/s 091%
1461s 22504B 1276327B/s 091%
1462s 22995B 1277995B/s 091%
1463s 23166B 1295108B/s 091%
1464s 22642B 1271968B/s 091%
1465s 22750B 1271527B/s 091%
1466s 22226B 1250769B/s 092%
1467s 25471B 1074379B/s 092%
1468s 55860B 0707165B/s 092%
1469s 75550B 1135778B/s 092%
1470s 74089B 1151543B/s 092%
1471s 76757B 1257657B/s 092%
1472s 84837B 1220174B/s 092%
1473s 82825B 1287425B/s 092%
1474s 83830B 1208529B/s 092%
1475s 79616B 1273698B/s 092%
1476s 94018B 1239332B/s 092%
1477s 101875B 1297231B/s 092%
1478s 81673B 1227129B/s 092%
1479s 94634B 1323108B/s 092%
1480s 74949B 1239049B/s 092%
1481s 75962B 1376909B/s 092%
1482s 76812B 1292068B/s 093%
1483s 71997B 1512074B/s 093%
1484s 23526B 1368549B/s 093%
1485s 22384B 1339666B/s 093%
1486s 23981B 1392442B/s 093%
1487s 20808B 1242626B/s 093%
1488s 23172B 1350829B/s 093%
1489s 23845B 1372305B/s 093%
1490s 23498B 1284531B/s 093%
1491s 24299B 1414571B/s 093%
1492s 22364B 1345325B/s 093%
1493s 22160B 1292449B/s 093%
1494s 21865B 1255980B/s 093%
1495s 22709B 1183417B/s 093%
1496s 21262B 1151856B/s 093%
1497s 21135B 1175366B/s 094%
1499s 20160B 1124006B/s 094%
1500s 21567B 1175510B/s 094%
1501s 23001B 1323042B/s 094%
1502s 23654B 1280989B/s 094%
1503s 23876B 1338863B/s 094%
1504s 21942B 1295088B/s 094%
1505s 24226B 1362489B/s 094%
1506s 23582B 1415878B/s 094%
1507s 22437B 1328332B/s 094%
1508s 22463B 1317121B/s 094%
1509s 21393B 1179814B/s 094%
1510s 23079B 1319688B/s 094%
1511s 23655B 1425123B/s 094%
1512s 23826B 1392256B/s 094%
1513s 23699B 1387914B/s 094%
1514s 23261B 1305979B/s 095%
1515s 22513B 1282423B/s 095%
1516s 21752B 1283987B/s 095%
1517s 22512B 1269178B/s 095%
1518s 22167B 1296634B/s 095%
1519s 22159B 1270436B/s 095%
1520s 21793B 1291237B/s 095%
1521s 21301B 1187555B/s 095%
1522s 23119B 1329721B/s 095%
1523s 22284B 1210542B/s 095%
1524s 22974B 1315980B/s 095%
1525s 22567B 1289002B/s 095%
1526s 22316B 1246497B/s 095%
1527s 22112B 1236943B/s 095%
1528s 22357B 1259043B/s 095%
1529s 21891B 1246087B/s 095%
1530s 22547B 1275508B/s 096%
1531s 22574B 1314566B/s 096%
1532s 23660B 1296722B/s 096%
1533s 22723B 1316841B/s 096%
1534s 23247B 1274135B/s 096%
1535s 23456B 1292101B/s 096%
1536s 23473B 1296803B/s 096%
1537s 23132B 1316754B/s 096%
1538s 22754B 1284665B/s 096%
1539s 22655B 1263756B/s 096%
1540s 23123B 1244762B/s 096%
1541s 25545B 0952528B/s 096%
1542s 68727B 0847307B/s 096%
1543s 69638B 1103475B/s 096%
1544s 76180B 1245938B/s 096%
1545s 78091B 1202968B/s 097%
1546s 84036B 1282885B/s 097%
1547s 83717B 1231332B/s 097%
1548s 86947B 1279336B/s 097%
1549s 84988B 1204940B/s 097%
1550s 85580B 1291124B/s 097%
1551s 84730B 1219977B/s 097%
1552s 95633B 1296184B/s 097%
1553s 74788B 1201957B/s 097%
1554s 74467B 1273487B/s 097%
1555s 75992B 1313203B/s 097%
1556s 71756B 1352953B/s 097%
1557s 38400B 1487344B/s 097%
1558s 24131B 1378706B/s 097%
1559s 23966B 1338504B/s 097%
1560s 23879B 1402069B/s 097%
1561s 20755B 1264288B/s 098%
1562s 23829B 1401306B/s 098%
1563s 23421B 1376289B/s 098%
1564s 23655B 1267566B/s 098%
1565s 23643B 1410419B/s 098%
1566s 22588B 1355284B/s 098%
1567s 21850B 1275095B/s 098%
1568s 22259B 1284025B/s 098%
1569s 20621B 1166889B/s 098%
1570s 21645B 1148062B/s 098%
1571s 21482B 1151398B/s 098%
1572s 20688B 1129722B/s 098%
1573s 21512B 1178221B/s 098%
1574s 22813B 1281387B/s 098%
1575s 23555B 1282205B/s 098%
1576s 23162B 1330673B/s 098%
1577s 21865B 1261283B/s 099%
1578s 24954B 1315223B/s 099%
1579s 23421B 1370625B/s 099%
1580s 21937B 1304113B/s 099%
1581s 22815B 1282856B/s 099%
1582s 21701B 1180661B/s 099%
1583s 23051B 1319099B/s 099%
1584s 23842B 1384607B/s 099%
1585s 23960B 1373750B/s 099%
1586s 23651B 1400926B/s 099%
1587s 23017B 1337960B/s 099%
1588s 22694B 1296640B/s 099%
1589s 22707B 1309372B/s 099%
1590s 21737B 1285251B/s 099%
1591s 21794B 1290395B/s 099%
Correct, you’ve managed to reproduce the issue.
Here’s the plot for the biggest size per second from your log:
You can easily see where the issue begins.
Any updates regarding this?
@raul.tambre.clevon ,
To be honest, this is in our bug list but we haven’t had a chance to fix it yet.
We will reprioritize it and squeeze time to root cause the issue recently.
Sorry for any inconvenience.
Hi @raul.tambre.clevon
Because there is no more release for Xavier, our developer will check this on Orin.
Hope it won’t impact your project.
@raul.tambre.clevon
This bug was fixed. The fix will be available in the next release of Orin (the current one is DRIVE OS 6.0.4 Linux SDK, FYI).
