When selecting a different output resolution than input resolution for the LDC API in the mode NVMEDIA_LDC_MODE_GEOTRANS it works perfectly fine.
As soon as the mode is set to NVMEDIA_LDC_MODE_GEOTRANS_TNR3 to enable TNR3 on top of the geotrans feature it fails to work unless the input and output resolutions are identical.
When testing the sample app nvmimg_ldc I get the following error:
I changed the following lines in the ldc_GeoTrans_TNR3.conf
# Params for NvMediaLDCCreate
# srcWidth width of the source image.
srcWidth = 1936
# srcHeight height of the source image.
srcHeight = 1216
# srcRect Structure containing co-ordinates of the rectangle in the source image.
# Left X co-ordinate. Inclusive.
srcRectx0 = 0
# Top Y co-ordinate. Inclusive.
srcRecty0 = 0
# Right X co-ordinate. Exclusive.
srcRectx1 = 1936
# Bottom Y co-ordinate. Exclusive.
srcRecty1 = 1216
Is it possible to run TNR3 while also changing the resolution at the same time?
No the file can also be the original. It should be large enough though to support the larger resolution. You can also go with the original resolution but reduce the target resolution. That will produce the same error code.
Please help modify and share ldc_GeoTrans_TNR3.conf to reproduce the same issue with the original input file (fisheye_1280_1080_yuv420.yuv) for our investigation. Thanks.
I reproduced it using the default files. I reduced the number of frames to process to 1.
Since it is an raw YUV file input it should still work without problems but it does not.
Please run the program with the program with the ldc_GeoTrans_TNR3.conf I attached to my previous message.
It would also be possible to leave the original resolution as is and reduce the target resolution. That results in the same error code.
Thank you for checking. Since the source is RAW input the resolution does not really matter as long as the file is large enough. I reduced the number of frames to 1 so that it only reads the amount for one frame.
Regardless of the content of the RAW file this should work right?
I was talking about input resolutions. I only modified the default configuration file to TNR3 mode (and corrected the file paths) and it ran successfully.
Yes I mean the input resolution as well. It should work as given with this config file in theory.
We want to use GEOTRANS_TNR3 which is throwing an error for us. TNR3 alone is not sufficient for us.
Would you be so kind to run the given config file with adjusted file paths and let me know whether it works for you?
