NVMeoF with ESX 6.5
Hi, Does any one successfully created a NVMeoF target using a block device in ESX 6.5? If it is even supported? If so can you guide me to setup instructions.
Anil
you can use Esxi6.5 as an initiator (not as a target) for discover, mount and use LUNs over NVMEoF Storage protocol, for instance, when using nvmetcli
use the 2x articles that will guide you through the configuration
How to Monitor and Manage NVMe Devices Using the Command Line Interface – Virtualization Review https://virtualizationreview.com/articles/2017/04/26/how-to-monitor-and-manage-nvme-devices-using-the-command-line-interface.aspx
HowTo Configure NVMe over Fabrics (NVMe-oF) Target Offload https://community.mellanox.com/s/article/howto-configure-nvme-over-fabrics--nvme-of--target-offload
