I’m having trouble getting the example provided with the Matlab Plug-in to mex (read: compile). The problems mentioned by other users do not appear to be related.
mexing the FFT code works fine, e.g.:
mex fft2_cuda.c -IC:\CUDA_TK\include -LC:\CUDA_TK\lib -lcudart -lcufft
But when I try and compile Szeta.cu I get:
nvmex -f nvmexopts.bat Szeta.cu -IC:\cuda_tk\include -LC:\cuda_tk\lib -lcufft -lcudart
WARNING: $ARCH (UNKNOWN) not set correctly [win64]
C:\PROGRA~1\MATLAB\R2007B\BIN\NVMEX.PL:
Error: Using options file:
nvmexopts.bat
You cannot use this file with the UNKNOWN architecture because it enables
a compiler for a different architecture.
Choose a file that is compatible with the UNKNOWN architecture.
??? Error using ==> nvmex at 206
Unable to complete successfully.
I’ve tried playing with {nvmex.m, nvmex_helper.m, nvmex.pl} since they changed from R2006 -> R2007, but to no avail.
I’ve also tried hardcoding $ARCH to win64 at the beginning of nvmex.pl, only to get a different error.
I’m running 64bit Windows, MS VS 2005, Matlab R2007b.
Thanks,
Danny
