Hi all,
Is nvmex still supported for cuda 3.2? I haven’t been able to compile using my makefile that was previously working when I had cuda 2.3 installed now that I upgraded to 3.2. I keep getting the following error when I run my makefile:
./nvmex -f nvopts.sh LDPCGF.cu -I/usr/local/cuda/tk3.2/include -L/usr/local/cuda/tk3.2/lib64 -lcufft -lcudart -Wl,-rpath,/usr/local/cuda/tk3.2/lib64
./nvmex: line 936: -c: command not found
mex: compile of ‘cudacode.cu’ failed.
make: *** [LDPCGF.mexa64] Error 1
I can run the SDK examples so I know my install is fine and the PATH and LD_LIBRARY_PATH environment variables are set correctly.
I’ve pasted my Makefile below, maybe there’s something that I’m missing that I need to change?
# Define installation location for CUDA and compilation flags compatible
# with the CUDA include files.
#CUDAHOME = /usr/local/cuda
CUDAHOME = /usr/local/cuda/tk3.2
INCLUDEDIR = -I$(CUDAHOME)/include
INCLUDELIB = -L$(CUDAHOME)/lib64 -lcufft -lcudart -Wl,-rpath,$(CUDAHOME)/lib64
CFLAGS = -fPIC -D_GNU_SOURCE -pthread -fexceptions
COPTIMFLAGS = -O3 -funroll-loops -msse2
# Define installation location for MATLAB.
export MATLAB = /opt/matlab2011a
#export MATLAB = /usr/local/matlab
#export MATLAB = /Applications/MATLAB_R2007b
MEX = $(MATLAB)/bin/mex
MEXEXT = .$(shell $(MATLAB)/bin/mexext)
#export PATH=$(PATH):$(CUDAHOME)/bin
#export LD_LIBRARY_PATH=$(LD_LIBRARY_PATH):$(CUDAHOME)/lib
# nvmex is a modified mex script that knows how to handle CUDA .cu files.
NVMEX = ./nvmex
# List the mex files to be built. The .mex extension will be replaced with the
# appropriate extension for this installation of MATLAB, e.g. .mexglx or
# .mexa64.
MEXFILES = cudacode.mex
all: $(MEXFILES:.mex=$(MEXEXT))
clean:
rm -f $(MEXFILES:.mex=$(MEXEXT))
.SUFFIXES: .cu .cu_o .mexglx .mexa64 .mexmaci
.c.mexglx:
$(MEX) CFLAGS='$(CFLAGS)' COPTIMFLAGS='$(COPTIMFLAGS)' $< \
$(INCLUDEDIR) $(INCLUDELIB)
.cu.mexglx:
$(NVMEX) -f nvopts.sh $< $(INCLUDEDIR) $(INCLUDELIB)
.c.mexa64:
.cu.mexa64:
.c.mexmaci:
.cu.mexmaci:
