Nvmflash.sh failed on AGX Xavier module
Hi
I run nvmflash.sh and some error happened. I run flash.sh to the same module successfully.
In addition, not all modules are the same, about 20%~30% will fail in nvmflash.sh.
Any suggestion?
The logs is attached
20220706-113049_21669_flash_3-5.1.log (2.5 KB)
Steven Chang
Which jetpack release is in use here?
JetPack_4.6.1_Linux_JETSON_AGX_XAVIER_TARGETS
How many modules were running the flash simultaneously?
42 No device on specified bus-port[3-5.1]
The error said the usb device (jeson) is missing.
Just one module.
Is “lsusb” on your host really showing jetson on this usb port?
