Nvmimg_cc sample getting failed
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to run the nvmimg_cc sample but getting the following error:
nvidia@tegra-ubuntu:~/drive-t186ref-linux/samples/nvmedia/img_cc$ sudo ./nvmimg_cc -wrregs ddpx-a/dvp_m_ar0231_rccb_raw12_1920x1236_ab_ta.script -d 0 -w 1
[sudo] password for nvidia:
Module_id 22 Severity 6 : ICP Major version number 4
Module_id 22 Severity 6 : ICP Minor version number 22
Module_id 22 Severity 6 : NvMediaICPCreateEx 76
Module_id 22 Severity 6 : T19x VI version 0x000019
Module_id 22 Severity 2 : SetChannelConfig 761
Module_id 22 Severity 2 : Sensor framerate is below minimum to guarantee VI PFSD FDTI
nvmedia: ERROR: DisplayInit: No display created
nvmedia: ERROR: DisplayInit: Failed to initialize Display
nvmedia: ERROR: main: Failed to Initialize Display
Can you please help me with that? I am running it on Drive AGX, target system? Should I run it on host system ubuntu18.04?
Dear @user158496,
Yes. You need to run it on target only. Are you running it remotely/directly on target? Have you enabled display on target? Do you see other samples are running which need camera display?
Hi SivaRam,
I run it on target Drive AGX and the camera sample is working with sample_camera or other samples that require camera.
My Camera is Sekonix SF3325/SF3324, I tried both, and getting the same error. The error is saying “: Sensor framerate is below minimum to guarantee VI PFSD FDTI”. I am not anything regarding the framerate.
I just changed the HDMI port from XA-2 to XA-1 and now it is working.
Just another question: Where can we find the source code of the nvimg_cc?
If we want to use ar0820, is it possible to change it somehow?
Thank you.
Dear @user158496,
The source code is available on host at <path to drive os folder>/drive-t86ref-linux/samples/nvmedia.
Please file a new topic if you have any issues to avoid cluttering of topics.
