I am trying to run the nvmipp_raw sample application on Tegra B with one “SVC210” camera connected to camera group A, connection 0.
using the following command:
“./x11/nvmipp_raw -cf e2379b_c01.conf -c dvp-svc210-raw12-1280x1080-cd -d 0 --aggregate 1 --nvplugin"
And tried with a different camera “SVC212” using this command:
“./x11/nvmipp_raw -cf e2379b_c01.conf -c dvp-svc212-raw12-1280x1080-cd -d 0 --aggregate 1 –nvplugin”
And in both cases, I got the same error messages:
***** aurix state *****
CAM_PWR_ON: 0x0
TEGRA_GMSL: TEGRA B
TEGRA_FPDL: TEGRA B
TEGRA_A_HDMI: MXM
TEGRA_B_HDMI: MXM
TEGRA_PCI: TEGRA B
FAN_STATE: UNKNOWN
nvmedia: ERROR: SetupVideoLink: Can’t detect config link(0)
nvmedia: ERROR: Init: Failed to setup video link
CAM_PWR_ON: 0x0
TEGRA_GMSL: UNKNOWN
TEGRA_FPDL: UNKNOWN
TEGRA_A_HDMI: UNKNOWN
TEGRA_B_HDMI: UNKNOWN
TEGRA_PCI: UNKNOWN
FAN_STATE: UNKNOWN
nvmedia: ERROR: IPPInit: Failed to initialize ISC devices
[NvMediaIPPManagerDestroy:189] Bad parameter
nvmedia: ERROR: main: Error in IPPInit
The setup is as follows:
-Tegra-B is running PDK 4.1.8
-Tegra-A is running PDK 4.1.8
-Aurix version is 4.2.2
-Camera sensor used: Continental SVC210 and SVC212, connected to camera group A, connection 0.
-The display is connected through HDMI.
-I made sure I am only using one camera at a time, and that it is connected to connection 0 and that the IP address in the tacp.cfg file is vaild.
Dear OmarAlfarouk.Alhaffa,
Can you please check with the below command on Tegra B where one camera connect to A0.
./x11/nvmipp_raw -cf drive-px2-b.conf -c dvp-svc210-raw12-1280x1080-ab -d 0 --aggregate 1 --nvplugin
Dear Omar,
The commands ./x11/nvmipp_raw -cf e2379b_c01.conf -c dvp-svc210-raw12-1280x1080-ab -d 0 --aggregate 1 --nvplugin looks correct(When one Continental OV10640 (Module name: SVC210)camera connected to A0 port on Tegra B).
Can you double check the camera setup and also can you check running any other sample with this camera
