NVML alternative for Jetson
Hello
What is an alternative library to the NVML that I can use on Jetson devices? Especially for Golang.
NVML is not available on Jetson.
Suppose you need it because of the dependency on Golang.
Have you checked with the Golang team to see if it can run without the NVML or does it support the Jetson environment?
Hi!
I’m interested in NVML because I thought that for GPU passthrough in HashiCorp Nomad, it was necessary to use a separate plugin that works through NVML. (Device Plugins: Nvidia | Nomad | HashiCorp Developer)
But as it turned out, the plugin is only required for discrete GPUs, and iGPUs in Jetson work out of the box.
Thank you, the thread can be closed."
