NVML nvmlInit_v2() was blocked
I write a gpu info lib with nvml, dynamic load the nvml.dll to execute nvml api.
here is demo:
 const auto nvmlModuleName = "nvml.dll";
    m_nvmlModule = ::LoadLibraryA(nvmlModuleName);
    if (m_nvmlModule == nullptr) {
        auto lastError = ::GetLastError();
            qDebug().noquote() << "Loading " << nvmlModuleName
                               << " failed with error code: " << lastError;
        return;
    qDebug().noquote() << "Successfully loaded " << nvmlModuleName;
   m_nvmlInit_v2 =  GetProcAddress(m_nvmlModule, "nvmlInit_v2")));// get nvmlInit_v2 function point by GetProcAddress.
    if (m_nvmlInit_v2 == nullptr)
        qDebug().noquote() << "NVML loaded but initialization failed";
    else {
        auto result = m_nvmlInit_v2(); //Block here
        if (result == NVML_SUCCESS)
            return;
        qDebug().noquote() << "NVML loaded but initialization failed with : " << result;
This code works , but some time m_nvmlInit_v2() will be blocked in some platform with nvidia gpu(no drive too).
as blow:
any help will be appreciate!
Dear @user107981
I have moved this issue to the NVML section for better traction.
Thank you.
