NVMM not working in pair with Tee
• Hardware Platform - Jetson
• DeepStream Version - 6.0
• JetPack Version - 32.4
• Issue Type - bug
I’ve encountered a bug in the usage of tee element with NVMM memory.
The issue arises if I drop frames from one branch of the tee, while processing buffers from the other branch. Subsequently, the other part of the queue sends a timeout signal to the GStreamer bus.
It’s worth noting that when only one of the pipelines (either streaming or DeepStream) is active, everything functions correctly.
Steps to Reproduce:
  1. Not working pipeline:
    neural-network-test_not_working.py (2.8 KB)
  2. Working pipeline:
    neural-network-test_working.py (3.1 KB)
  3. Minimum requirement for replicating the behaviour:
    minimumn_example_not_working.py (1.8 KB)
After dropping a specific number of frames, the described timeout behaviour occurs, leading to the bug I have encountered.
After further investigation after dropping continuously buffers, the pipeline goes to VOID_PENDING state.
Looks like a deadlock in my opinion.
The bufferpool size in nvvideoconvert is only 4 by default. You drop 15 frames per 16 frames, there is no buffer available in the bufferpool. Please enlarge the bufferpool size according to your scenario.
