**• Hardware Platform ** dGPU • DeepStream Version 6.3
I am trying to start a pipeline using nvmsgconv → nvmsgbroker. I am hosting a rabbitmq server on my machine which I have configured the plugin to connect to. Here is my cfg_amqp.txt:
This works perfectly outside of a Docker container but inside of the container I get the message “error: unable to connect to broker library.”
My docker container is run with the argument “–network host” so the IP and port should be the same for the configuration. I have librabbitmq-c installed both inside and outside the container. I can ping the rabbitmq server successfully from inside the docker container and I even ran tests using another amqp library that I can send amqp messages to the rabbitmq server successfully from the Docker container.
I tested and this script runs successfully. This script creates a connection inside the docker container. I am trying to communicate from inside the docker container to the server outside the container. This is where the plugin fails. I see other people having a similar issue:
do you mean using test_amqp_proto can send messages successfully?
as you know, nvmsgbroker plugin also uses libnvds_amqp_proto.so to send messages. nvmsgbroker is opensource. can you debug nvmsgbroker to narrow down this issue? especially, please check if nvds_msgapi_connect’s parameter is correct.
