Nvmultiurisrcbin can't play new stream after RTSP disconnection
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version 8.6.1
• Issue Type( questions, new requirements, bugs) questions
When the RTSP server goes offline, nvmultiurisrcbin automatically removes the source.
After that, adding a new URI with add-uri does not work — the new stream is added but never goes to the PLAYING state.
Is there any way to recover or re-add a new stream successfully after the auto-remove event?
Can you upgrade the DeepStream version to the latest DeepStream version which support your device? Installation — DeepStream documentation
Thank you for your reply. Our models are tied to a specific TensorRT version and can only run correctly with TensorRT 8.6.1. Therefore, upgrading to a newer DeepStream release is not currently possible for us. We’d like to find a workaround or solution within the current DeepStream version if possible.
The DeepStream 6.2 is too old to be supported through forum. And the nvmultiurisrcbin is alpha version with DeepStream 6.2.
Another suggestion is that the nvmultiurisrcbin plugin is open source. You can try to fix the problem with the latest DeepStream package and compare the nvmultiurisrcbin source code of the two versions.
Thank you for the response.
I’d also like to ask whether nvmultiurisrcbin supports dynamic resolution changes in the video stream.
If the resolution change is inside the RTSP stream, it is supported.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
