I tried it outside of the container and it seems to work there. Inside, I randomly gets the following output from the Argus::CameraProvider::create() function:
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
(NvOdmDevice) Error BadValue: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/HotplugMonitor.cpp, function initializeHotplug(), line 201)
After that, the function gets stuck. Any idea what could be wrong?
Ok, maybe it is a permission thing. It does not work if the application is run as normal user inside the container but running it again as root (sudo), it seems to work. Here is the output from the Argus::CameraProvider::create call in that case:
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
Any idea whats wrong with running as normal user? The user inside the container is in the video group, is that enough?
Because this is only printed when it gets stuck. Maybe can you check what could lead to this error message to narrow down the issue?
