Hi, sometimes when starting an application using libargus, I get the following error:
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
(NvOdmDevice) Error BadValue: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/HotplugMonitor.cpp, function initializeHotplug(), line 201)
After printing these lines, the application gets stuck. The application is running inside a container. Sometimes, restarting the container helps, but not always. What could be the reason of that issue?
