What’s the meaning of the following error message from nvcamera-daemon ?
(NvOdmDevice) Error BadParameter: 0x32314142 pixelFormat not found under current active buffer type (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setActivePixelFormat(), line 1440)
please access [Sensor Driver Programming Guide] from the [L4T Documentation]
please check the Property-Value Pairs descriptions of these properties.
thanks
I have checked kernel sources (l4t 28.2.1 version) and noticed that the kernel uses mode_type, csi_pixel_bit_depth, and pixel_phase only if pixel_t is not defined.
nvcamera-daemon (l4t 28,2,1) however uses pixel_phase even if pixel_t is defined.
That’s an unexpected discrepancy.
