- Hardware Platform (Jetson / GPU) - ZOTAC GeForce RTX 2060 SUPER
- DeepStream Version - v5.0.1
- JetPack Version (valid for Jetson only) - N/A
- TensorRT Version - N/A
- Issue Type (questions, new requirements, bugs) - Bug
- How to reproduce the issue?
This issue occurs whenever we are dealing with frames that are copied to GPU memory vianvvideoconvert
with regards to thenvof
element. Two examples of this issue are shown below:
gst-launch-1.0 nvstreammux name=streammux width=800 height=600 batch-size=1 videotestsrc num-buffers=10 ! video/x-raw,framerate=15/1,width=800,height=600 ! nvvideoconvert nvbuf-memory-type=3 ! "video/x-raw(memory:NVMM)" ! streammux.sink_0 streammux.src ! nvof ! fakesink
Setting pipeline to PAUSED ... Device Number: 0 Device name: GeForce RTX 2060 SUPER Device Version 7.5 Device Supports Optical Flow Functionality Pipeline is PREROLLING ... gst_ds_optical_flow_set_caps: Creating OpticalFlow Context for Source = 0 libnvds_opticalflow_dgpu: Setting GPU_ID = 0 Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Got EOS from element "pipeline0". Execution ended after 0:00:00.011969125 Setting pipeline to PAUSED ... Setting pipeline to READY ... ds_optical_flow_destroy_oflib_ctx: Destroying oflib ctx 0x7efddc002000 Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Setting pipeline to NULL ... Freeing pipeline ...
gst-launch-1.0 videotestsrc num-buffers=900 ! video/x-raw,framerate=15/1,width=800,height=600 ! x264enc ! video/x-h264,profile=main ! h264parse ! mp4mux ! filesink location=/tmp/test.mp4 gst-launch-1.0 nvstreammux name=streammux width=800 height=600 batch-size=1 filesrc location=/tmp/test.mp4 ! qtdemux ! h264parse ! avdec_h264 ! videoconvert ! video/x-raw,format=NV12 ! nvvideoconvert nvbuf-memory-type=3 ! "video/x-raw(memory:NVMM)" ! streammux.sink_0 streammux.src ! nvof ! fakesink
Setting pipeline to PAUSED ... Device Number: 0 Device name: GeForce RTX 2060 SUPER Device Version 7.5 Device Supports Optical Flow Functionality Pipeline is PREROLLING ... Redistribute latency... gst_ds_optical_flow_set_caps: Creating OpticalFlow Context for Source = 0 libnvds_opticalflow_dgpu: Setting GPU_ID = 0 Redistribute latency... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Got EOS from element "pipeline0". Execution ended after 0:00:01.230870105 Setting pipeline to PAUSED ... Setting pipeline to READY ... ds_optical_flow_destroy_oflib_ctx: Destroying oflib ctx 0x7f7e8c01ab00 Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Cuda failure: status=1 nvbufsurface: Error(-1) in releasing cuda memory Setting pipeline to NULL ... Freeing pipeline ...
This is a problem for us, as it restricts us to only using the nvv4l2decoder
element, as nvof
has no issues with GPU buffers allocated with that element. As a result, we cannot use software decoding for H264 or other formats; limiting us to whatever formats nvv4l2decoder
supports.
