NVOF plugin on Jetson Orin Nano Developer Kit
I am using the Jetson Orin Nano Developer kit. Even though the nvof plugin page says Orin generation supports nvof plugin I am getting the following error. Is there a way to run optical flow in this board
Device Number: 0
Device name: Orin
Device Version 8.7
ERROR: GSTNVOF Plugin Does NOT Support Optical Flow Functionality On Jetson Orin
• Hardware Platform (Jetson / GPU): Jetson Orin Nano (developer Kit)
• DeepStream Version: 6.2
• JetPack Version (valid for Jetson only): 5.1.1
• TensorRT Version: 8.5.2.2
The DeepStream 6.2 document never mentioned gst-nvof supports Orin Nano. Gst-nvof — DeepStream 6.2 Release documentation.
Can you try DeepStream6.3 + JetPack5.1.2?
The plugin works on DeepStream6.3 + JetPack5.1.2.
