I’ve been trying to recreate the algorithm benchmark values reported on the NVOFA Tracker documentation for the NvOFTracker-YOLOv3. I’ve built the NvOFTracker library and the NvOFTSample executable on a Docker container with the following specs:
- Ubuntu 18.04
- CUDA 11.0
- cuDNN 8.0
- TensorRT 7.2.2
- Video Coded SDK 10.0
- OpenCV 4.5.1
I’ve built the YOLOv3 TensorRT engine as specified in the installation readme, and I’m using the MOT16 training set as specified in the Tracker documentation. First, I stitched all the training set image frames into videos with the command below:
ffmpeg -framerate <framerate> -i <input/frames> -codec copy <output_name>.mkv
Then, I ran ./NvOFTSample
on each of the stitched videos. I modified the DumpTrackedObjects()
function in NvOFTSample.cpp
to produce MOT-16 Challenge format compliant outputs. Then, I ran the output files on py-motmetrics
to obtain the accuracy measurements. These are the values I obtained:
- MOTA: 25.4%
- FP: 20122
- FN: 61489
- ID: 739
I’ve managed to get FN and ID values that are similar to the ones reported in the documentation, but the FP value is much higher, and the MOTA value is much lower by comparison. I was wondering if I am on the right track in obtaining these measurement values? If so, what went wrong that led to such a discrepancy in FP values? And if not, what would be the right way to benchmark the NvOFTracker-YOLOv3?
