• Hardware Platform (Jetson / GPU) NVIDIA GeForce GTX 1650 • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) • TensorRT Version 8.5 • NVIDIA GPU Driver Version (valid for GPU only) 12.2 • Issue Type( questions, new requirements, bugs) Doubt
I am unable to remove label names only, is there a way to remove label names and keep tracking ID only
and how do i change bbox color dynamically.
You can customize the output yourself.
1.Add a probe function on osd source pad
2.Get the display_meta and traverse the text_params
3.remove the label of the text_params you got
Could you try the workround below to see if it meets your needs?
Replace the lable in the file: ../../../../samples/models/Primary_Detector/labels.txt with a space.
1.Add a probe function. Please refer to the source code in the file: opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-3d-action-recognition\deepstream_3d_action_recognition.cpp
There is currently no such example for python. But the NvDsLabelInfo structure has already been bound in Python. So you can implement that in Python by referring to our C code yourself.
