NvOSD_MaskParams - missing from Python Bindings
• Hardware Platform (Jetson / GPU) Orin
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 5.01
• TensorRT Version 8.4
• Issue Type( questions, new requirements, bugs) Bug
Attempt to obtain NvOSD_MaskParams through Python bindings
Hi
I’m trying to implement (in Python) a MRCNN model built with TAO (appropriate libs for the parser applied and working) however, during debugging it is noted that when attempting to obtain the mask parameters the debugger reports
Unable to convert function return value to a Python type!
I checked the forums and there was a suggestion that the bindings for maskParams is missing from the python bindings src and that the user needed to implement this further. On inspection of the
bindnvosd.cpp
source, there does not seem to be any entry for the mask params (that would need additional modification).
How do we proceed, or how do we get the masks to appear (the model is displaying bounding boxes). I do not want to drop back to a C++ solution? I do not think this is a config issue, rather a missing piece to the python bindings.
Thank you.
The pyds python bindings are open source deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com), you can add the binding and build the pyds library.
