NVPACK NDK problem debugging native code
I have the latest NVPACK installed on a Windows 7 machine and an Android app with some native code.
I’m using Eclipse that came with the NVPACK for debugging. I can start the debugging session with the option to “Debug as Android App” and step through the JAVA code. It won’t step into the native code.
When I started the debugging session using the “Debug as Android NDK App”, there were some problems.
Here is the error output I got and I hope someone here might know how to solve the problems:
[2014-01-24 10:36:40 - NDKAndroid] NDK: ------------------------------
[2014-01-24 10:36:40 - NDKAndroid] NDK: NVIDIA Debug Manager for Android NDK!
[2014-01-24 10:36:40 - NDKAndroid] NDK: adb is running normally...
[2014-01-24 10:36:40 - NDKAndroid] NDK: Performing com.example.ndkandroid.MainActivity activity launch
[2014-01-24 10:36:40 - NDKAndroid] NDK: Automatic Target Mode: using device '44f46f03'
[2014-01-24 10:36:40 - NDKAndroid] NDK: Check if there arealready running gdbservers 0.0040
[2014-01-24 10:36:40 - NDKAndroid] NDK: Running gdbserver processes not found.
[2014-01-24 10:36:40 - NDKAndroid] NDK: Check if there is running application com.example.ndkandroid 0.116
[2014-01-24 10:36:40 - NDKAndroid] NDK: Running application is not found
[2014-01-24 10:36:40 - NDKAndroid] NDK: Uninstalling package com.example.ndkandroid 0.534
[2014-01-24 10:36:43 - NDKAndroid] NDK: Syncing app 3.445
[2014-01-24 10:36:44 - NDKAndroid] NDK: Uploading NDKAndroid.apk onto device '44f46f03'
[2014-01-24 10:36:45 - NDKAndroid] NDK: Installing NDKAndroid.apk...
[2014-01-24 10:36:52 - NDKAndroid] NDK: Success!
[2014-01-24 10:36:52 - NDKAndroid] NDK: Retrieving shared libs if necessary 12.582
[2014-01-24 10:36:52 - NDKAndroid] NDK: Using C:\Users\xxx\workspace\.metadata\.plugins\com.nvidia.ndklaunch\avd_44f46f03 as shared libs cache.
[2014-01-24 10:36:52 - NDKAndroid] NDK: Computing solib search path 12.582
[2014-01-24 10:36:52 - NDKAndroid] NDK: Launching app 12.601
[2014-01-24 10:36:52 - NDKAndroid] NDK: Starting activity com.example.ndkandroid.MainActivity on device
[2014-01-24 10:36:52 - NDKAndroid] NDK: Executing shell command: am start -D -n com.example.ndkandroid/com.example.ndkandroid.MainActivity -a android.intent.action.MAIN -c android.intent.category.LAUNCHER
[2014-01-24 10:36:53 - NDKAndroid] ActivityManager: Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] cmp=com.example.ndkandroid/.MainActivity }
[2014-01-24 10:36:53 - NDKAndroid] NDK: Attempting to connect debugger to 'com.example.ndkandroid' on port 8600
[2014-01-24 10:36:53 - NDKAndroid] NDK: Start GDB when before JDB
[2014-01-24 10:36:53 - NDKAndroid] NDK: Performing port forwarding 13.498
[2014-01-24 10:36:53 - NDKAndroid] NDK: Executing command: C:\NVPACK\android-sdk-windows\platform-tools\adb.exe forward tcp:12345 localfilesystem:/data/data/com.example.ndkandroid/gdbsocket
[2014-01-24 10:36:53 - NDKAndroid] NDK: Computing PID of launched application 13.539
[2014-01-24 10:36:54 - NDKAndroid] NDK: Found PID of launched application: 16321
[2014-01-24 10:36:54 - NDKAndroid] NDK: Starting up run-as com.example.ndkandroid lib/gdbserver +/data/data/com.example.ndkandroid/gdbsocket --attach 16321 13.675
[2014-01-24 10:36:54 - NDKAndroid] GdbServerReceiver: run-as: Package 'com.example.ndkandroid' is unknown
[2014-01-24 10:37:00 - NDKAndroid] NDK: Gdbserver not started properly
[2014-01-24 10:37:00 - NDKAndroid] NDK: Launch error: Failed to connect to remote VM
