NVPARSER: HEVC: Seeking is not performed on IRAP picture
Jetson Nano
• DeepStream Version
6.0.1
32.7.4
• TensorRT Version
Bug
What triggers the following message when decoding a RTSP H.265 stream? It causes frame drops which in turn results in bad tracker performance (duplicates).
2024-02-10T17:53:28+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-10T17:53:51+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-10T17:54:56+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-10T17:59:20+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T07:49:19+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T07:49:31+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T07:53:11+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T08:03:20+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T08:04:32+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T08:08:09+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T08:08:14+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
2024-02-11T08:08:15+01:00  deepstream  NVPARSER: HEVC: Seeking is not performed on IRAP picture
rtspsrc location=rtsp://admin:password@192.168.1.1:554/Streaming/Channels/101
    latency=500
    drop-on-latency=True
    buffer-mode=0 !
parsebin !
nvv4l2decoder ! video/x-raw(memory:NVMM) !
    videorate skip-to-first=true !
    video/x-raw(memory:NVMM), framerate=10/1 !
    nvstreammux.sink_0
nvstreammux
    name=nvstreammux
    width=640
    height=480
    batch-size=1
    batched-push-timeout=40000
    attach-sys-ts=true
    live-source=True
    sync-inputs=False
    interpolation-method=6
Besides, it creates image artifacts.
sorry for the late reply! please refer to this topic.
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
hi @fanzh
we are still unable to run our pipeline with RTSP inputs with h265 encoding using Hikvision camera’s as it results in the above issues.
  1. could you dump some stream by the following method?
gst-launch-1.0 <your different source> ! \
rtph265depay ! \
h265parse ! 'video/x-h265,stream-format=byte-stream' !  \
filesink location=test.h265
  1. About “artifacts”, do you mean In one frame, the both sides are from the same source. but at the different time?
  2. could you try drop-on-latency=False? wondering if it is caused by The Network.
another issue we encounter in production with h265 streams is the following message upon which the stream image freezes but connection remains. This happens either at starting the pipeline or at random while connection remains. It sometimes requires multiple pipeline restarts.
deepstream Stream format not found, dropping the frame
this log means decoder failed to decode. to narrow down this issue.
  1. will the rendering return normal after that reporting this error at starting the pipeline or at random?
  2. if using software decoder avdec_h265, can the app still report this error? wondering it is decoder bug or stream issue.
