I’m using custom carrier board without any display/hdmi port. TX2NX on Jetpack 4.6.2.
But nvphs service looks failed to run
● nvphs.service - NVIDIA PHS daemon
Loaded: loaded (/lib/systemd/system/nvphs.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-11-10 16:52:03 CET; 1min 59s ago
Process: 3690 ExecStartPre=/usr/sbin/nvphsd_setup.sh (code=exited, status=0/SUCCESS)
Main PID: 4021 (nvphsd)
Tasks: 2 (limit: 3688)
Memory: 2.1M
CGroup: /system.slice/nvphs.service
├─4021 /usr/sbin/nvphsd
└─4024 /usr/sbin/nvphsd
Nov 10 16:52:02 Orbit-3900 systemd[1]: Starting NVIDIA PHS daemon...
Nov 10 16:52:03 Orbit-3900 systemd[1]: Started NVIDIA PHS daemon.
Nov 10 16:52:03 Orbit-3900 phs[4024]: W/ nvphs:machine: config is missing "display_state_fmt" (/dvs/git/dirty/git-master_linux/services-partner/ussrd/machine.c:725):
Nov 10 16:52:03 Orbit-3900 phs[4024]: E/ nvphs: Failed to initialize sysfs readers. Exiting.
Nov 10 16:52:03 Orbit-3900 phs[4024]: E/ nvphs: Initialization Failed! Entering Zombie mode
And on nvargus-daemon
log, it has some errors when opening camera
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: NvPclHwGetModuleList: No module data found
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: ---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: E/ libnvphs:socket: Error[111]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: Connection refused
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: CAM: serial no file already exists, skips storing again=== camera-streamer[4228]: CameraProvider initialized (0x7f948c5900)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
Nov 10 16:52:04 Orbit-3900 nvargus-daemon[3956]: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_ms=1000]: queue_or_send() failed
Tried to set display_state_fmt=/dev/null
in /etc/nvphsd_common.conf
file. The nvphs
service looks running, no error log in nvargus-daemon
, but nvphs
service generates error log every second:
Nov 10 16:57:56 Orbit-3900 phs[4907]: E/ nvphs:parse: could not parse integer ""
Nov 10 16:57:56 Orbit-3900 phs[4907]: E/ nvphs: could not update display state
Nov 10 16:57:57 Orbit-3900 phs[4907]: E/ nvphs:parse: could not parse integer ""
Nov 10 16:57:57 Orbit-3900 phs[4907]: E/ nvphs: could not update display state
Nov 10 16:57:58 Orbit-3900 phs[4907]: E/ nvphs:parse: could not parse integer ""
Nov 10 16:57:58 Orbit-3900 phs[4907]: E/ nvphs: could not update display state
Nov 10 16:57:59 Orbit-3900 phs[4907]: E/ nvphs:parse: could not parse integer ""
Nov 10 16:57:59 Orbit-3900 phs[4907]: E/ nvphs: could not update display state
Does this error log impact other parts? Or how to configure nvphs correctly for system without display?
This issue doesn’t happen on JP4.5.
