Nvphs fails for no clear reason, making cameras unavailable
We are running a gstreamer pipeline based on nvarguscamerasrc.
Periodically, we see the nvphs service failing, which leads to camera instability. If it’s not running when our service starts up, then cameras are not available at all.
We can’t figure out what’s causing to crash, just that it is reporting a watchdog timeout.
Relevant logs:
Apr 13 21:33:22 cheerios-eace313b648c63ff systemd[1]: Starting PHS daemon...
Apr 13 21:33:22 cheerios-eace313b648c63ff systemd[1]: Started PHS daemon.
Apr 13 21:35:11 cheerios-eace313b648c63ff nvphsd[4189]: *** watchdog timer: something has hung this process, committing suicide.
Apr 13 21:35:11 cheerios-eace313b648c63ff systemd[1]: nvphs.service: Main process exited, code=exited, status=1/FAILURE
Apr 13 21:35:11 cheerios-eace313b648c63ff systemd[1]: nvphs.service: Failed with result 'exit-code'.
hello kevin.r,
may I have more details of your environment setup,
for example, is it tested with Nano developer kit. which camera module it is, which JetPack release version you’re using…etc
