Nvphsd
I have an xavier agx running L4T-R32.1. This device is deployed and has been running fine for several weeks. This morning I noticed that the device was very busy doing stuff I had not told it to, symptoms being unresponisive, particular when trying to check some systemd services. In fact I could not at all make changes to systemd services.
Running top I could see that it was very busy doing something with systemd-timesyn and nvphsd. I suspect these are two systemd managed processes (see below top print out). I have several other devices they are not at all occupied with these processes.
Anyone have an idea for the reason, and where to look for a solution to this?
   PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
 4947 62583     20   0   83968   2668   2108 R     99,7        0,0  48:34.82 systemd-timesyn
 6331 root      20   0   77868   1900   1568 R      99,7          0,0  48:50.54 nvphsd
Looks like the thermal problem. Could you check the the system temperature.
