NvRmGpuLibOpen failed, error=14
Dear Nvidia Team:
we use Drive AGX Orin Developer kit, with camera preview as below:
sudo ./nvsipl_camera -c “ISX031_MAX96717F_RGGB_CPHY_x4” -m “0x0000 0x0010 0x0000 0x0000” -012 -R --showfps -v 4
It is ok; but I do “sudo reboot” , after boot, then with command nvsipl_camera ,
it see :
nvsipl_camera: Setting up master
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 334: GetInstance: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 337: GetInstance: Exiting
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=14
nvsipl_camera: ERROR: NvSciBufModuleOpen failed. nvSciStatus: 50
nvsipl_camera: ERROR: Master setup failed. status: 10
so why GPU libnvrm_gpu.so need power down/on. it is error for reboot command. how to? reboot the system GPU?
Software Version
DRIVE OS 6.0.8.1
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-100)
other
SDK Manager Version
[*] 1.9.3.10904
other
Host Machine Version
[*] other
Dear @yeahjun.wang,
You need to use poweroff/poweron command on aurix console to shutdown and start the board.
Also, you can use common_if_testapp -mcureset command on tegra console to reboot the board.
TKS. it is ok
