NvRmMemInit Failed
Has anybody else seen similar error on boot:
Error found when loading /etc/profile:
****NvRmMemInit failed****
As a result the session will not be configured correctly. You should fix the problem as soon as feasible.
Not sure if your case is similar to this one.
