Hi, NVIDIA:
We update DriveOS to 5.2.6 vesion and we want to use NvSciStream multicast to build our image process pipeline.
When we test nvscistream_multicast_sample in SDK and start 4 consumers, got err below:
Module_id 24 Severity 2 : Failed to set PreFence as the Max preFences are set already
It seems multicast mode has some limitation? Could you please give me some suggestions if we have more than 4 consumers in different process?
Looking forward your reply. Thanks !
Dear @yangyanlin,
Could you share the used command?
Hi, Nvidia. Thanks for reply.
My apology. I’ve modify the sample code lead to this error.
But I wanna ask the same question. It seems multicast mode has some limitation:
// we necessarily need a channel name
// and only for either producer or consumer
if (isConsumerChannel == false &&
(nConsumer < 1|| nConsumer > 4)) {
// wrong the number of consumer.
optcnt--;
If I delete the code upon, this will lead to this error
channel_producer.cpp (66), createBlocks: NvSci error 100
Is this means multicast has 4 consumers at most ?
If we really need more than 4 consumers, is there any other way to solve the problem ?
