Nvsipl_camera example for NvSciSurfSampleType_422
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Can you please help me to use NvSciSurfSampleType_422 type for surfSampleType in nvsipl_camera example?
Dear @wooseok.won,
Let me check if NvSciSurfSampleType_422 is supported format and get back to you.
Hi @SivaRamaKrishnaNV, any update?
Hello @SivaRamaKrishnaNV,
Can you please follow up this ticket?
Are you using ar0820 onsemi ?
AR0820 is a RAW sensor, that outputs Bayer data, that needs to be processed in ISP to produce YUV image. ISP does not support yuv422 output format
I’m using ENTRON AR0820 camera. Don’t you think it’s feasible to modify(or add) the code in nvsipl_camera to have converting an image to required format?
No. The ISP can’t output yuv422 data.
