Nvsipl_camera test failed using sensor SG8-AR0820C-5300-GMSL2 and sensor SG2-AR0233C-5200-GMSL2
Hi Team, we are testing the cameras ,used the nvsipl_camera command, sensor is : SG8-AR0820C-5300-GMSL2 (H30/H60/H120)and sensor SG2-AR0233C-5200-GMSL2 . Three AR0820C sensors connected to port 0 and four AR0233C sensors connected to port 1. We have tried the platform config :
SG0820C5300Mx1_SG0233C5200Mx3_DPHY_x4, VC0820C030R24_CPHY_x2 not work. Please help us and give some advices.
Regards,
Joney
Hi there @qiuwen, welcome to the NVIDIA developer forums.
Am I mistaken or is Thor not even available yet?
If you have a pre-release version on hand I assume you got that through direct channels with NVIDIA in which case you should use the same for any kind of support. You might break NDA by discussing it here.
We have a orinX platform , We would like to use the i2c-tools in a Linux system to directly access the deserializer’s I2C address. However, we’ve seen posts mentioning that the deserializer’s power must be turned on first . Could you please confirm the correct procedure for this operation? Thank you.
Issue is related with Drive Orin platform, please open your topic at Latest DRIVE AGX Orin/DRIVE AGX Orin General topics - NVIDIA Developer Forums. Sorry for the late response. Thanks
