Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi, I’m trying to run the nvsipl_camera sample with an Entron F003A208RM0A camera which should be supported by the system.
From Entron I recieved the .nito file as well as the nvsiple_devblk_drv and libnvsipl_qry for the camera sensor and installed them on the system.
When running nvsipl_query_sample it does find the platform configuration AR0233_GRBG_DPHY_x4 for the camera sensor.
But when i run the camera sample I receive following error:
sudo /opt/nvidia/drive-linux/samples/nvmedia/nvsipl/test/camera/nvsipl_camera --platform-config "AR0233_GRBG_DPHY_x4" --link-enable-masks "0x0000 0x0001 0x0000 0x0000" --disableISP2Output --disableISP1Output --enableRawOutput -v 4
Platform configuration name: AR0233_GRBG_DPHY_x4
Verbosity level: 4
Raw output: enabled
ISP0 output: enabled
ISP1 output: disabled
ISP2 output: disabled
Disabled FPS logging
Disabled Metadata logging
Disabled automatic recovery
Disabled NvSci
Disabled profiling
Disabled ISP Statistics settings override
Subframe : disabled
Disabled Passive mode
Authentication: controlled by Platform Config
Disabled retrieving/displaying NITO Metadata
nvsipl_camera: Setting up signal handler
nvsipl_camera: Getting platform configuration for AR0233_GRBG_DPHY_x4
nvsipl_camera: Setting link masks
libnvsipl_query.so: CNvMPlatformCfgInfo.cpp : 91: ApplyMask: block:1 enabled
libnvsipl_query.so: CNvMPlatformCfgInfo.cpp : 100: ApplyMask: module:0 enabled
nvsipl_camera: Creating camera master
nvsipl_camera: Setting up master
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 334: GetInstance: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 337: GetInstance: Exiting
nvsipl_camera: Creating consumers
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 593: SetPlatformCfg: Entering DevBlkQueues variant
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 532: SetPlatformCfg: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 365: LogPlatformCfg: ---------- START PLATFORM CONFIGURATION ----------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 366: LogPlatformCfg: platform:
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 367: LogPlatformCfg: platformConfig: AR0233_GRBG_DPHY_x4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 368: LogPlatformCfg: description: AR0233 GRBG module in 4 lane DPHY mode
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 369: LogPlatformCfg: numDeviceBlocks: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 372: LogPlatformCfg: DeviceBlockInfo deviceBlockList[0]
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 373: LogPlatformCfg: csiPort: 5
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 374: LogPlatformCfg: phyMode: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 375: LogPlatformCfg: i2cDevice: 3
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 377: LogPlatformCfg: DeserInfo deserInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 378: LogPlatformCfg: name: MAX96712
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 379: LogPlatformCfg: description: Maxim 96712 Aggregator
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 380: LogPlatformCfg: i2cAddress: 0x29
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 382: LogPlatformCfg: errGpios.size(): 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 384: LogPlatformCfg: errGpios[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 384: LogPlatformCfg: errGpios[1]: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 386: LogPlatformCfg: useCDIv2API: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 387: LogPlatformCfg: resetAll: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 388: LogPlatformCfg: numCameraModules: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 391: LogPlatformCfg: CameraModuleInfo cameraModuleInfoList[0]
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 392: LogPlatformCfg: name: AR0233_GRBG
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 393: LogPlatformCfg: description: OnSemi AR0233 GRBG module - 120-deg FOV, MIPI-AR0233, MAX9295
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 394: LogPlatformCfg: linkIndex: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 396: LogPlatformCfg: SerInfo serInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 397: LogPlatformCfg: name: MAX9295
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 398: LogPlatformCfg: description: Maxim 9295 Serializer
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 399: LogPlatformCfg: i2cAddress: 0x62
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 400: LogPlatformCfg: longCable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 402: LogPlatformCfg: errGpios.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 406: LogPlatformCfg: useCDIv2API: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 408: LogPlatformCfg: serdesGPIOPinMappings.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 415: LogPlatformCfg: isEEPROMSupported: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 425: LogPlatformCfg: SensorInfo sensorInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 426: LogPlatformCfg: id: 4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 427: LogPlatformCfg: name: AR0233
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 428: LogPlatformCfg: description: OnSemi AR0233 Sensor
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 429: LogPlatformCfg: i2cAddress: 0x10
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 431: LogPlatformCfg: SensorInfo::VirtualChannelInfo vcInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 432: LogPlatformCfg: cfa: 35
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 433: LogPlatformCfg: embeddedTopLines: 4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 434: LogPlatformCfg: embeddedBottomLines: 4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 435: LogPlatformCfg: inputFormat: 8
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 436: LogPlatformCfg: resolution.width: 1920
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 437: LogPlatformCfg: resolution.height: 1080
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 438: LogPlatformCfg: fps: 30.000000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 439: LogPlatformCfg: isEmbeddedDataTypeEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 440: LogPlatformCfg: isTriggerModeEnabled: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 442: LogPlatformCfg: errGpios.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 446: LogPlatformCfg: useCDIv2API: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 447: LogPlatformCfg: isTPGEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 448: LogPlatformCfg: patternMode: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 450: LogPlatformCfg: desI2CPort: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 451: LogPlatformCfg: desTxPort: 4294967295
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 452: LogPlatformCfg: pwrPort: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 454: LogPlatformCfg: dphyRate[0]: 2500000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 455: LogPlatformCfg: cphyRate[0]: 2000000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 454: LogPlatformCfg: dphyRate[1]: 2500000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 455: LogPlatformCfg: cphyRate[1]: 2000000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 457: LogPlatformCfg: isSimulatorModeEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 458: LogPlatformCfg: isPassiveModeEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 459: LogPlatformCfg: isGroupInitProg: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 461: LogPlatformCfg: gpios.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 465: LogPlatformCfg: isPwrCtrlDisabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 467: LogPlatformCfg: longCables[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 468: LogPlatformCfg: isSimulatorModeEnabled[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 467: LogPlatformCfg: longCables[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 468: LogPlatformCfg: isSimulatorModeEnabled[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 467: LogPlatformCfg: longCables[2]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 468: LogPlatformCfg: isSimulatorModeEnabled[2]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 467: LogPlatformCfg: longCables[3]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 468: LogPlatformCfg: isSimulatorModeEnabled[3]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 470: LogPlatformCfg: resetAll: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 472: LogPlatformCfg: ----------- END PLATFORM CONFIGURATION -----------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 157: SetConfig: Create device block
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 165: SetConfig: Set device block config
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Checking "/lib" for drivers
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Checking "/lib/nvsipl_drv" for drivers
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�ϻѪ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "༻Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library ""
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "@;�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "���Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "ԻѪ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�X�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "P
�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�A�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�"�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�c�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�d�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "�T�Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library " �Ѫ�"
Main: CDevBlkDriverLibs.cpp: 133: FindFirstLibPath: Loading library "p��Ѫ�"
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Checking "/usr/lib" for drivers
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Checking "/usr/lib/nvsipl_drv" for drivers
Main: CDevBlkDriverLibs.cpp: 121: FindFirstLibPath: Checking "/usr/local/driveworks/lib" for drivers
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0233.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CDevBlkDriverLibs.cpp: 214: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0233.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CNvMDeserializerFactory.cpp: 61: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CDevBlkDriverLibs.cpp: 35: CDevBlkDriverLibs: Driver libraries are already loaded
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "I0OO23111CML1050NB10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "I0OO23111CML1050NB10_30FPS" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-55H" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-55H_L" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "I0OO23111CML1050NB10_E" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-55H_E" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0SIM623S3RU1197NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S1RU3120NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S1RU3070HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S1RU3030NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU1030NB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU3070HB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU3120NB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU3120HB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU2030NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU4070HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU4120NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S2RU4120HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S3RU4120NC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S3RU4120HC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S3RU4070HC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM728S3RU2030NC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V728S1-120V0" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V728S1-120V1-FWC" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V728S1-120V1-SCF" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V728S1-070V1-SCR" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V728S1-030V1-FTC" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V728S1-030V1-RC" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0SIM728S2RU2120NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0SIM728S2RU1070NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0SIM728S2RU2030NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM623S3RU3200NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V1SIM623S4RU5195NB3" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V0SIM623S4RU5195NB3" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A030BM0A_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A030BM0A_24BIT_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A030BM0A_RCCB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120BM0A_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120BM0A_24BIT_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120BM0A_RCCB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A030BM0A_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A030BM0A_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A030BM0A_RGGB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120BM0A_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120BM0A_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120BM0A_RGGB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A070BM0A_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A030RM0A" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A070RM0A" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120RM0A" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120RM0A_SIDE" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "F008A120RM0AV2" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "MAX96712TPG" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "MAX96712TPG_YUV_8" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "DS90UB971TPG" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0OOX05B1CHU1170NA10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0OOX05B1CHU1170NA10_L" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0OOX05B1CHU1170NA10_LL" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "R0OOX05B1CHU1170NB10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0233.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "AR0233_GRBG" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0233.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "AR0233_16BIT_GRBG" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0233.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "IMX728_FPDLINK_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "V623S2-195V1-SVS" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "AR0820C120FOV_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "AR0820C70FOV_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "VC0820C120R24" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "VC0820C070R24" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "VC0820C030R24" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-60H" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-60H_L" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "SIM_V1SIM623S3RU3200NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 131: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "SIM_V1SIM728S1RU3120NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "SIM_V1SIM728S1RU3070HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 177: LoadDriver: Mapping module name "SIM_V1SIM728S1RU3030NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 582: SetPlatformCfg: Exiting
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 621: SetPlatformCfg: Exiting DevBlkQueues variant
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 691: SetPipelineCfg: Entering for pipeline: 4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 637: LogPipelineCfg: -------- START PIPELINE 4 CONFIGURATION --------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 638: LogPipelineCfg: captureOutputRequested: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 639: LogPipelineCfg: isp0OutputRequested: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 640: LogPipelineCfg: isp1OutputRequested: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 641: LogPipelineCfg: isp2OutputRequested: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 643: LogPipelineCfg: NvSIPLDownscaleCropCfg downscaleCropCfg
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 644: LogPipelineCfg: ispInputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 648: LogPipelineCfg: isp0OutputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 652: LogPipelineCfg: isp1OutputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 656: LogPipelineCfg: isp2OutputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 660: LogPipelineCfg: isp0DownscaleEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 665: LogPipelineCfg: isp1DownscaleEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 670: LogPipelineCfg: isp2DownscaleEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 676: LogPipelineCfg: NvSIPLIspStatsOverrideSetting statsOverrideSettings
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 677: LogPipelineCfg: enableHistStatsOverride[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 678: LogPipelineCfg: enableHistStatsOverride[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 679: LogPipelineCfg: enableLacStatsOverride[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 680: LogPipelineCfg: enableLacStatsOverride[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 681: LogPipelineCfg: enableBpStatsOverride[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 682: LogPipelineCfg: (imageGroupWriter != nullptr): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 683: LogPipelineCfg: --------- END PIPELINE 4 CONFIGURATION ---------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 856: SetPipelineCfg: Exiting for pipeline: 4
nvsipl_camera: Creating consumer for output:0 of sensor:4
nvsipl_camera: Consumer initialization for output:0 of sensor:4
nvsipl_camera: Creating consumer for output:1 of sensor:4
nvsipl_camera: Consumer initialization for output:1 of sensor:4
nvsipl_camera: GetPtpDeviceNode() selected /dev/ptp2
nvsipl_camera: Using PTP clock
nvsipl_camera: Initializing master interface
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1151: Init: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 242: Init: Initializing worker thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 34: ThreadCreate: Creating thread:DEVBLK_WORKER_0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 248: Init: Initialized worker thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 205: WorkersDoAction: All worker threads starting action:1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 130: m_FuncStatic: Thread created
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 117: ThreadSetName: Setting thread name:DEVBLK_WORKER_0
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 144: m_Func: Running thread:DEVBLK_WORKER_0
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 147: m_Func: Calling ThreadFunc for thread:DEVBLK_WORKER_0
DEVBLK_WORKER_0: CNvMMax20087Factory.cpp: 41: operator(): CNvMMax20087 Driver Factory creating new adapter for CDI root dev 0xffff8c000ca0
DEVBLK_WORKER_0: CNvMMax20087SyncAdapter.cpp: 27: SetConfig: Configure Sync Adapter
DEVBLK_WORKER_0: CNvMMax20087SyncAdapter.cpp: 67: CreatePowerDevice: Create Sync Adapter Driver
DEVBLK_WORKER_0: CNvMMax96712.cpp: 237: DoInit: Check deserializer is present
MAX96722: Revision 5 detected
DEVBLK_WORKER_0: CNvMMax96712.cpp: 244: DoInit: Set deserializer defaults
MAX96712 Link 0: PHY optimization was enabled
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 231: WorkersDoAction: All worker threads finished action:1
nvsipl_camera: ERROR: NvSIPLCamera Init failed
nvsipl_camera: ERROR: Master initialization failed. status: 10
nvsipl_camera: Queue timeout
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3945: Deinit: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 887: Deinit: Quit the thread
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 55: ThreadQuit: Quitting thread:
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 205: WorkersDoAction: All worker threads starting action:4
Illegal instruction
Do you know why this issue appears?
With best regards
Thomas
