I am currently debugging a camera module with NvSIPL and using the nvsipl_camera sample application to validate the camera driver and capture raw input.
I am running nvsipl_camera using the platform configuration and link-enable mask, for example:
./nvsipl_camera --platform-config "<platform>" \
--link-enable-masks "<masks>"
The application is running, but I am not able to see messages generated using NvSIPL logging macros such as:
SIPL_LOG_ERR_STR_INT(...)
The messages
are not appearing in:
- The
nvsipl_cameraterminal output - The application log output/files
- The locations where I expected NvSIPL/driver logs to be available
This is making it difficult to debug failures during camera initialization/configuration and raw-input capture.
Questions regarding SIPL logging
- What is the correct mechanism/location to view
SIPL_LOG_ERR_STR_INT()output when runningnvsipl_cameraon DRIVE OS? - Is there any NvSIPL/DRIVE OS logging configuration, environment variable, log-level setting, or service that needs to be enabled for these messages to appear?
- If the camera module driver/CDI is running in a different process or OS domain, where should its
SIPL_LOG_*output be collected? - Is there a recommended way to enable verbose NvSIPL/CDI logging specifically for debugging camera initialization and capture?
Question regarding Revision ID check
While debugging the camera initialization/capture flow, I also noticed a Revision ID check in the camera/device initialization path.
would like to understand the significance of this check in the context of capturing raw input.
Specifically:
- What is the purpose of checking the device/sensor Revision ID?
- Is the Revision ID check only intended to verify that the expected sensor/device is connected, or does it also affect subsequent sensor configuration/capture?
- If the Revision ID does not match the expected value, does NvSIPL/CDI prevent the device from being initialized or prevent raw frames from being captured?
