Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Dear Support!
This is a follow up topic of: Using NvSIPLPipelineConfiguration to crop on ISP level
Input crop is not working as expected. Could you clarify the other dependencies?
Blockquote
We have tried some crops and it is still not working as expected. For example:
Setting up ispInputCrop.y0 (OR ispInputCrop.y1 to maxheight-256), the driver gives back the following error:
Module_id 30 Severity 2 : src/control/common/camrangecheck.cpp 33
Module_id 30 Severity 2 : parameter is too large 1702 1620
Module_id 30 Severity 2 : src/control/common/camrangecheck.cpp 681
Module_id 30 Severity 2 : Bad input parameter : Rectangular Mask y1
Module_id 30 Severity 2 : src/control/isp/settings/camstats.cpp 54
Module_id 30 Severity 2 : Bad parameter : rect Mask
Module_id 30 Severity 2 : src/control/isp/settings/camstats.cpp 72
Module_id 30 Severity 2 : Bad parameter: Rect Mask
Module_id 30 Severity 2 : src/control/isp/settings/camstats.cpp 154
Module_id 30 Severity 2 : Bad parameter: set LAC window
In this case the region of the cropped image should be: [0, 0, 2896, 1620] (or [0, 256, 2896, 1876])
The other crop values are set as described:
x0 = 0
x1 = maxwidth
y0 = 256 (or 0)
y1 = maxheight (or maxheight - 256)
