• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.1.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only): 525.60.13
• Issue Type( questions, new requirements, bugs): Question
I am trying to read multiple rtsp streams → mux togheter → inference → track → demux → sent to different rtmp server
I was able to create a working pipeline from cmd
gst-launch-1.0 filesrc location=sample_1080p_h264.mp4 ! decodebin ! m.sink_0 filesrc location=sample_1080p_h264.mp4 ! decodebin ! m.sink_1 filesrc location=sample_1080p_h264.mp4 ! decodebin ! m.sink_2 filesrc location=sample_1080p_h264.mp4 ! decodebin ! m.sink_3 nvstreammux name=m width=1920 height=1080 batch-size=4 batched-push-timeout=40000 ! queue ! nvinfer config-file-path=/apps/data/deepstream_pgie_config_yolo.txt batch-size=4 ! queue ! nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! nvstreamdemux name=d d.src_1 ! queue ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! flvmux streamable=true name=mux ! rtmpsink location=<rtmp-server>"
I also wanted to re-create this in Python and I have a method that creates everything that’s needed for each stream that is demuxed and send it do a different rtmp server.
def create_rtmp_output_for_nvosd(pipeline, streamdemux, input_file):
if not input_file:
print("No input files provided.")
return
for i, file in enumerate(input_file):
# Create elements with names including the index
nvvideoconvert = Gst.ElementFactory.make("nvvideoconvert", f"nvvideoconvert_{i}")
nvvideoconvert_after_osd = Gst.ElementFactory.make("nvvideoconvert", f"nvvideoconvert_after_osd_{i}")
queue = Gst.ElementFactory.make("queue", f"queue_{i}")
nvdsosd = Gst.ElementFactory.make("nvdsosd", f"nvdsosd_{i}")
nvdsosd.set_property('process_mode', 1)
encoder = Gst.ElementFactory.make("nvv4l2h264enc", f"nvv4l2h264enc_{i}")
h264parse = Gst.ElementFactory.make("h264parse", f"h264parse_{i}")
flvmux = Gst.ElementFactory.make("flvmux", f"flvmux_{i}")
flvmux.set_property('streamable', True)
rtmpsink = Gst.ElementFactory.make("rtmpsink", f"rtmpsink_{i}")
# Check if elements are created
if not nvdsosd or not encoder or not h264parse or not flvmux or not rtmpsink:
print("Failed to create elements.")
return
# Set properties if needed
rtmpsink.set_property('location',
f'rtmp://my-rtmp_{i}') # Set your RTMP URL here
rtmpsink.set_property('sync', False)
rtmpsink.set_property('async', True)
if is_aarch64():
encoder.set_property("preset-level", 1)
encoder.set_property("insert-sps-pps", 1)
pipeline_helper.add_elements(pipeline,
nvvideoconvert,
queue,
nvdsosd,
nvvideoconvert_after_osd,
encoder,
h264parse,
flvmux,
rtmpsink
src_pad_name = f"src_{i}"
demux_src_pad = streamdemux.get_request_pad(src_pad_name)
demux_src_pad.link(queue.get_static_pad('sink'))
queue.link(nvvideoconvert)
nvvideoconvert.link(nvdsosd)
nvdsosd.link(nvvideoconvert_after_osd)
nvvideoconvert_after_osd.link(encoder)
encoder.link(h264parse)
h264parse.link(flvmux)
flvmux.link(rtmpsink)
The creation of all elements and linking those between one another works and my pipeline starts, but it blocks after first 3 frames being processed. Here’s the log after pipeline starts. It was extracted with GST_DEBUG=3
Starting pipeline
0:00:00.110473916 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_1:sink> Unable to try format: Unknown error -1
0:00:00.110496310 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_1:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.110510095 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_1:sink> Unable to try format: Unknown error -1
0:00:00.110594817 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_1:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.110607780 5527 0x380c890 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x3753e20 Failed to determine interlace mode
0:00:00.110734371 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_1:sink> Unable to try format: Unknown error -1
0:00:00.110751208 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_1:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.110762887 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_1:sink> Unable to try format: Unknown error -1
0:00:00.110771568 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_1:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.110784170 5527 0x380c890 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x3753e20 Failed to determine interlace mode
0:00:00.110859697 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_1:src> Unable to try format: Unknown error -1
0:00:00.110874112 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_1:src> Could not probe minimum capture size for pixelformat H264
0:00:00.110885875 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_1:src> Unable to try format: Unknown error -1
0:00:00.110899716 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_1:src> Could not probe maximum capture size for pixelformat H264
0:00:00.111046863 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_0:sink> Unable to try format: Unknown error -1
0:00:00.111058894 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_0:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.111065583 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_0:sink> Unable to try format: Unknown error -1
0:00:00.111076367 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_0:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.111088650 5527 0x380c890 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x3719820 Failed to determine interlace mode
0:00:00.111107732 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_0:sink> Unable to try format: Unknown error -1
0:00:00.111119854 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_0:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.111130860 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_0:sink> Unable to try format: Unknown error -1
0:00:00.111142955 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_0:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.111155698 5527 0x380c890 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x3719820 Failed to determine interlace mode
0:00:00.111209401 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_0:src> Unable to try format: Unknown error -1
0:00:00.111220656 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_0:src> Could not probe minimum capture size for pixelformat H264
0:00:00.111232325 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2h264enc_0:src> Unable to try format: Unknown error -1
0:00:00.111243930 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2h264enc_0:src> Could not probe maximum capture size for pixelformat H264
0:00:00.291441962 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291465186 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:00.291483364 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291492329 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:00.291514989 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291526973 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat AV10
0:00:00.291536622 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291547384 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat AV10
0:00:00.291573585 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291586843 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat DVX5
0:00:00.291598820 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291610836 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat DVX5
0:00:00.291629391 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291641651 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat DVX4
0:00:00.291653039 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291660054 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat DVX4
0:00:00.291670554 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291675948 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:00.291681764 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291689324 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:00.291700816 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291713486 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:00.291724562 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291738169 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:00.291758381 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291770304 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat H265
0:00:00.291781162 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291793170 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat H265
0:00:00.291809983 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291820979 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat VP90
0:00:00.291831603 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291842107 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat VP90
0:00:00.291896663 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291908184 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat VP80
0:00:00.291914996 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291921904 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat VP80
0:00:00.291944087 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.291956380 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe minimum capture size for pixelformat H264
0:00:00.292091887 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:sink> Unable to try format: Unknown error -1
0:00:00.292105340 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:sink> Could not probe maximum capture size for pixelformat H264
0:00:00.292167032 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:src> Unable to try format: Unknown error -1
0:00:00.292177358 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:src> Could not probe minimum capture size for pixelformat NM12
0:00:00.292182232 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_0:src> Unable to try format: Unknown error -1
0:00:00.292190831 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_0:src> Could not probe maximum capture size for pixelformat NM12
0:00:00.292205117 5527 0x380c890 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x35f7010 Failed to determine interlace mode
0:00:00.292383869 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292401259 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat MJPG
0:00:00.292412215 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292424756 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat MJPG
0:00:00.292441905 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292451864 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat AV10
0:00:00.292463040 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292473868 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat AV10
0:00:00.292490787 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292503647 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat DVX5
0:00:00.292514769 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292525766 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat DVX5
0:00:00.292545325 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292557326 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat DVX4
0:00:00.292568375 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292579434 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat DVX4
0:00:00.292594879 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292604663 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat MPG4
0:00:00.292614358 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292624712 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat MPG4
0:00:00.292641625 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292652906 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat MPG2
0:00:00.292663470 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292673614 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat MPG2
0:00:00.292690586 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292702638 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat H265
0:00:00.292709795 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292717640 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat H265
0:00:00.292731761 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292743286 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat VP90
0:00:00.292754430 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292765271 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat VP90
0:00:00.292778941 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292788698 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat VP80
0:00:00.292795650 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292807506 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat VP80
0:00:00.292821837 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292833137 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe minimum capture size for pixelformat H264
0:00:00.292841492 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:sink> Unable to try format: Unknown error -1
0:00:00.292853133 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:sink> Could not probe maximum capture size for pixelformat H264
0:00:00.292889480 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:src> Unable to try format: Unknown error -1
0:00:00.292900008 5527 0x380c890 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:src> Could not probe minimum capture size for pixelformat NM12
0:00:00.292907406 5527 0x380c890 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2-decoder_1:src> Unable to try format: Unknown error -1
0:00:00.292919483 5527 0x380c890 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2-decoder_1:src> Could not probe maximum capture size for pixelformat NM12
0:00:00.292952091 5527 0x380c890 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x3620170 Failed to determine interlace mode
Unknown key rtsp for group [sensor0]
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[include/modules/NvMultiObjectTracker/NvTrackerParams.hpp, getConfigRoot() @line 52]: [NvTrackerParams::getConfigRoot()] !!![WARNING] Invalid low-level config file caused an exception, but will go ahead with the default config values
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
Deserialize yoloLayer plugin: yolo
0:00:02.837000602 5527 0x380c890 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/apps/detecteve/model_b1_gpu0_fp16.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT data 3x640x640
1 OUTPUT kFLOAT num_detections 1
2 OUTPUT kFLOAT detection_boxes 8400x4
3 OUTPUT kFLOAT detection_scores 8400
4 OUTPUT kFLOAT detection_classes 8400
0:00:02.880626320 5527 0x380c890 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /apps/detecteve/model_b1_gpu0_fp16.engine
0:00:02.882604394 5527 0x380c890 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:../data/deepstream_pgie_config_yolo.txt sucessfully
0:00:02.913476004 5527 0x3feff60 FIXME rtpjitterbuffer gstrtpjitterbuffer.c:1553:gst_jitter_buffer_sink_parse_caps:<rtpjitterbuffer0> Unsupported timestamp reference clock
0:00:02.913499321 5527 0x3feff60 FIXME rtpjitterbuffer gstrtpjitterbuffer.c:1561:gst_jitter_buffer_sink_parse_caps:<rtpjitterbuffer0> Unsupported media clock
A new pad recv_rtp_src_0_2185044335_99 was created
Unable to link sinkpad
0:00:02.914241785 5527 0x3fef980 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<nvmsg-broker> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:02.960383113 5527 0x2007c460 FIXME rtpjitterbuffer gstrtpjitterbuffer.c:1553:gst_jitter_buffer_sink_parse_caps:<rtpjitterbuffer1> Unsupported timestamp reference clock
0:00:02.960410204 5527 0x2007c460 FIXME rtpjitterbuffer gstrtpjitterbuffer.c:1561:gst_jitter_buffer_sink_parse_caps:<rtpjitterbuffer1> Unsupported media clock
A new pad recv_rtp_src_0_4128948381_96 was created
0:00:02.961302211 5527 0x3fef980 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<nvmsg-broker> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:03.023753866 5527 0x3fefea0 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation:<nvv4l2-decoder_1> Duration invalid, not setting latency
0:00:03.023801276 5527 0x3fefea0 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:<nvv4l2-decoder_1:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:03.024351498 5527 0x7f64d0331060 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:<nvv4l2-decoder_1:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:03.069111567 5527 0x3fefe40 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation:<nvv4l2-decoder_0> Duration invalid, not setting latency
0:00:03.069152241 5527 0x3fefe40 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:<nvv4l2-decoder_0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:03.069664912 5527 0x7f64dc016980 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:<nvv4l2-decoder_0:pool:src> Driver should never set v4l2_buffer.field to ANY
Frame number: 0 source id: 1, batch id: 0, num objects: 0
Frame number: 0 source id: 0, batch id: 1, num objects: 0
Frame Number = 0
Frame number: 1 source id: 1, batch id: 0, num objects: 0
Frame number: 1 source id: 0, batch id: 1, num objects: 0
Frame Number = 1
Frame number: 2 source id: 1, batch id: 0, num objects: 0
Frame number: 2 source id: 0, batch id: 1, num objects: 0
Frame Number = 2
Frame number: 3 source id: 1, batch id: 0, num objects: 0
Frame number: 3 source id: 0, batch id: 1, num objects: 0
Frame Number = 3
0:00:03.680344910 5527 0x380e240 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<sink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:03.680399704 5527 0x380e240 WARN qtmux gstqtmux.c:2981:gst_qt_mux_start_file:<mp4-muxer_0> Robust muxing requires reserved-moov-update-period to be set
0:02:10.378605030 5527 0x3feff60 WARN rtpjitterbuffer gstrtpjitterbuffer.c:3308:gst_rtp_jitter_buffer_chain:<rtpjitterbuffer0> we are EOS, refusing buffer
0:02:36.314026340 5527 0x7f64c80071e0 WARN rtspsrc gstrtspsrc.c:3458:on_timeout_common:<rtsp-source_1> source 823d216f, stream 823d216f in session 0 timed out
^C[NvMultiObjectTracker] De-initialized
0:05:15.362161878 5527 0x7f64d0331060 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:<nvv4l2-decoder_1> decreasing timestamp (0:00:00.361354522 < 0:00:00.520756356)
0:05:15.364520183 5527 0x7f64dc016980 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:<nvv4l2-decoder_0> decreasing timestamp (0:00:00.432373856 < 0:00:00.552553661)
