Nvstreamer example doesn't work on JP 6.0
I am trying to run the nvstreamer application as
https://docs.nvidia.com/moj/nvstreamer/moj-nvstreamer.html
on a Jetson Orin AGX machine.
When I run:
sudo docker compose -f compose_nvstreamer.yaml up -d --force-recreate
the server doesn’t start. The logs are throwing this error:
sudo docker logs -f d472d8b529b7
exec /usr/bin/sh: exec format error
Is there a problem with the image: nvcr.io/e7ep4mig3lne/release/vst:nvstreamer_v0.2.24_aarch64
It works fine on my setup: AGX Orin with Jetpack 6.0 DP. I can check it with Chrome: http://:31000
$ sudo docker compose -f compose_nvstreamer.yaml up -d --force-recreate
[+] Running 25/26
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 95.4s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 96.2s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 96.7s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 97.3s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 97.6s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 97.8s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 98.0s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 98.2s
[+] Running 25/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 98.5s
[+] Running 26/26layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulling 98.8s
✔ nvstreamer 25 layers [⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿] 0B/0B Pulled 292.3s
✔ a1df1d4a17c6 Pull complete 3.6s
✔ 2b0563ef01e4 Pull complete 11.9s
✔ 35cf4428605b Pull complete 1.7s
✔ f984f6904015 Pull complete 3.2s
✔ ee29ad409ce6 Pull complete 4.6s
✔ 94b37c87e1fc Pull complete 5.3s
✔ eb7eb1554f9f Pull complete 6.1s
✔ e112f72d3c9c Pull complete 7.2s
✔ a426abae9274 Pull complete 7.7s
✔ 66922cdd8477 Pull complete 8.7s
✔ 6cf7cd6fad37 Pull complete 13.9s
✔ 2f6bd5c54b49 Pull complete 10.7s
✔ 668b4fcdc91a Pull complete 13.1s
✔ 7d783d6bb97b Pull complete 13.7s
✔ c2b95538e8d2 Pull complete 57.8s
✔ e152abff8577 Pull complete 15.9s
✔ 7949d1215524 Pull complete 15.6s
✔ 4f4fb700ef54 Pull complete 17.0s
✔ 4e952234ff1c Pull complete 17.3s
✔ d1006010d4f8 Pull complete 18.8s
✔ c0ac5d7fc992 Pull complete 24.7s
✔ e7fc3fea65bb Pull complete 24.5s
✔ 3798dc44cc23 Pull complete 27.9s
✔ 5a64cf7490ac Pull complete 26.1s
✔ e5ea3027a935 Pull complete 28.1s
[+] Running 1/1
✔ Container nvstreamer Started 0.1s
kevin@agx-orin:~/nvstreamer$ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
77de6089133e nvcr.io/e7ep4mig3lne/release/vst:nvstreamer_v0.2.24_aarch64 “sh -c '/root/vst_re…” 23 seconds ago Up 21 seconds nvstreamer
kevin@agx-orin:~/nvstreamer$ docker logs nvstreamer
tee: /root/vst_release/webroot/log/vst.log: No such file or directory
Host HTTP port: 31000
Recorded Video Root: /root/store/nvstreamer_videos
stunurl list: stun.l.google.com:19302, stun1.l.google.com:19302
static_turnurl_list:
use_coturn_auth_secret: 0
use_twilio_stun_turn: 0
coturn_turnurl_list_with_secret:
Thanks. I deleted all the container images and restarted to make it work.
Glad to know it works. Close the topic.
