• Hardware Platform: GPU
• DeepStream Version: 6.3
• TensorRT Version: 8.5.3.1
• NVIDIA GPU Driver Version: 530.41.03
• Issue Type: Bug
• How to reproduce the issue ? See below
When the pipeline is in state PLAYING with no sources active the new nvstreammux logs the following warning every 5 milliseconds:
nvstreammux gstnvstreammux.cpp:1392:gst_nvstreammux_src_push_loop: warning: No Sources found at the input of muxer [videomux]
In our application sources are added on request. The nvstreammux option drop-pipeline-eos is enabled to make it possible to keep the pipeline running continuously. As soon as there are no sources the above message is logged every 5 milliseconds from nvstreammux. This makes it difficult to use GST_DEBUG=2 and above, which is otherwise useful to get a log of any real problems.
We did not see this behaviour with DeepStream 6.2, so we think it was introduced in DeepStream 6.3. Ideally this log message should be at a lower GST_DEBUG level such as TRACE instead.
