NvStreamMux (New) adaptive-batching and NvTracker
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) JetPack 5.1.2 GA
• TensorRT Version
Seems to be a bug in the tracker reference implementation???
I’m running into the exact same issue as posted here
If I set adaptive-batching to true and start the Pipeline with a single source. When you add a new Source the Tracker reports
'Frame number in input batch exceeds maximum batch size'
Which results in additional errors
0:00:06.723566286 27459     0x30339700 WARN                 nvinfer gstnvinfer.cpp:2397:gst_nvinfer_output_loop:<infer-primary-gie-nvinfer> error: Internal data stream error.
0:00:06.723613711 27459     0x30339700 WARN                 nvinfer gstnvinfer.cpp:2397:gst_nvinfer_output_loop:<infer-primary-gie-nvinfer> error: streaming stopped, reason error (-5)
If I remove the Tracker plugin from the Pipeline everything seems to work ok. The only workaround is to set the Streammux gst-property to the max-sources-to add.
I would think you could easily reproduce this with your https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/runtime_source_add_delete example.
Thanks,
Robert.
nvtracker will allocate the memory based on the batch size. Please set the Streammux gst-property to the max-sources-to add.
Hi, @kesong
I have one question.
What is the exact property name of Streammux that should be set as the max sources count?
Hi, @kesong
@sieman216485 The GST property is called batch-size … see here
… and FYI. based on my experience, once the solution box is checked on a topic as above, best to open a new topic if you want NVIDIA to respond.
@prominence_ai
Thanks for your reply.
I already tried setting batch-size but still face the same issue.
Anyway, I will open a new topic to get NVIDIA’s response.
Thanks for your tip.
@sieman216485 make that you’re not setting the batch-size in the Streammux config file as well… as this will override the GST property setting. Or, if you do set it in the config, set it to max-sources-to-add here.
From the docs…
“This value will override plugin property and DS config file key “batch-size” for nvstreammux
If batch-size not specified in the config-file, plugin property batch-size shall override the default.”
Hi, @prominence_ai Thanks again for your reply.
After testing different cases, I confirmed that it only works when I set gst-property, regardless of whether I set the config-file property.
However, according to the documentation, the config-file property value will override the gst-property.
But my testing result shows that it is not.
What do you think about this?
