Nvtracker obj_id <65536
Description
What could be the potential reasons for the obj_id range being limited to 0-65535 after adding the nvtracker plugin to deepstream in Python?
Environment
Hi @1170041523 ,
Deepstream Forum should be able to assist you better here.
Please refer to below links related custom plugin implementation and sample:
While IPluginV2 and IPluginV2Ext interfaces are still supported for backward compatibility with TensorRT 5.1 and 6.0.x respectively, however, we recommend that you write new plugins or refactor existing ones to target the IPluginV2DynamicExt or IPluginV2IOExt interfaces instead.
